Old 09-26-2012, 09:20 PM   #1
zooki
Drives: waiting on a 2021...
Installed Perrin shifter bushing & Fumoto oil drain valve
Just finished installing a Fumoto oil drain valve & Perrin's upgraded shifter bushing on my FR-S. On the drain valve, I put a small hose clamp around the body to keep the lever from moving "just in case". No pictures, sorry, but it's pretty self explanatory. I don't really think I will need it, but it didn't hurt to do. The shifter bushing seemed to improve the feel of the shifter, it has less play, and seems more direct. I don't know how much that is true, and how much is attributed to the "I washed my car, and now it's faster" syndrome. But for $35 I think it's worth it.
zooki is offline   Reply With Quote
Old 10-03-2012, 08:36 PM   #2
Burn
Slack Bum
Burn's Avatar
I just installed the bushing while I was doing my own oil change and the feel was much improved and stiffer.. just that the removal of the bolts on the stock bushing is quite a pain though..
Burn is offline   Reply With Quote
Old 10-03-2012, 08:39 PM   #3
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
how good is the fumoto valve hey?>
Surok is offline   Reply With Quote
Old 10-03-2012, 08:50 PM   #4
mike2100
mike2100's Avatar
Drives: 23 BRZ
2 questions:
1) Did you notice if the stock drain valve is magnetic?
2) Do you get any extra vibration in the shifter after the bushing install?
mike2100 is offline   Reply With Quote
Old 10-03-2012, 09:08 PM   #5
wheelhaus
wheelhaus's Avatar
Both are are mods I'm planning on doing, Fumoto valve is already here and waiting. I think someone already posted this before, but how much clearance is under the valve to the belly pan?
Do you have any tips regarding the bushing installtion?
wheelhaus is offline   Reply With Quote
Old 10-03-2012, 10:12 PM   #6
Burn
Slack Bum
Burn's Avatar
The instructions are with the bush and it's quite clear cut and straight forward.. shouldn't be a problem to you
Old 10-03-2012, 10:17 PM   #7
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
I have mentioned this elsewhere, they are pretty pointless, majority of the metal that would be floating around in your oil is not magnetic, the motor is mainly alloy, unless of course i have misslead and they have iron cylinder liners..
Anyway, this is why you have a good quality oil filter
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 10-03-2012, 10:54 PM   #8
wheelhaus
wheelhaus's Avatar
"Alloy" only means any mixture of two or more metals, there are steel alloys, titanium alloys, etc etc. I'm sure you meant "aluminum alloy" which is in fact, non ferrous and thus nonmagnetic, but that doesn't mean magnetic plugs or filter magnets are completely useless, just not as important as they would be in an iron block or iron sleeved block, etc.
Old 10-03-2012, 10:55 PM   #9
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
its good if you snap the dipstick and u want to pull the broken bit out of the sump
Old 10-03-2012, 11:52 PM   #10
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Thats the one
Old 10-04-2012, 12:25 AM   #11
zooki
I don't "think" the stock drain plug is magnetic, but then again I didn't check, no point for me since it's not on the car. I found the easiest way to get to the bushing bolts is a 3/8 ratchet with a long extension and a universal swivel on the end. I have a lift though, so it was pretty easy access for me. I haven't noticed any more vibration, just a more precise shift.
Old 10-04-2012, 12:46 AM   #12
Jimbo
Jimbo's Avatar
Drives: 92 NSX, 08 Accord
Fumoto valves are great. One is going on my BRZ at first oil change.
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ)
2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold)
2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue
Jimbo is offline   Reply With Quote
Old 10-04-2012, 01:44 AM   #13
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Yeah i got one sitting on my oil container waiting for the first change.. which hopefully is soon!
Old 10-04-2012, 05:35 AM   #14
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
I'm putting fumoto valve on all 3 of my cara
RedRocket is offline   Reply With Quote
Does the STI Rear Shifter Bushing fit the BRZ/FRS? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-27-2012 03:48 PM
