Old 03-06-2015, 07:16 AM   #127
Tor
Tor's Avatar
Drives: Toyota GT86
I think it would be tough to program into a manual because it has no way of predetermining if you're shifting up or down when the clutch is pressed in...it also has no idea how long it will take you to select your gear and let the clutch out so I think it'll be damn near impossible to put it into an OFT (or any other, for that matter) tune for the 6MT.
It's in the EcuTek tune, see below from approx. 2:25 and again from 3:00
[ame="https://www.youtube.com/watch?v=ONQSXDAr9A0"]Scion FRS / Subaru BRZ ECUtek RaceROM Feature Demonstration - YouTube[/ame]
Looks like it triggers when brake is pressed and the clutch is pressed too.
Tor is offline   Reply With Quote
The Following User Says Thank You to Tor For This Useful Post:
ImBatman (03-06-2015)
Old 03-06-2015, 10:00 AM   #128
ImBatman
My Tumbler is an FRS
Drives: exclusively in the fast lane
I've been wondering the same thing... seems like an awesome feature.
I'm a little torn on whether I would want it all the time, however. I do really enjoy heel/toeing and rev-matching manually because it's so damn gratifying to get it just right and have that perfectly smooth downshift. BUT, it would be a nice feature when I'm just running around town. I doubt it is something that could be turned on/off whenever you would like to use it though.
To summarize, it would definitely modernize the driving experience and be more user-friendly for those of us that daily our 86, but one of the best parts of this vehicle is the pure, technologically-unmolested sports-car driving experience that reminds you of the good ole days before paddle shifters and launch control.
Just my .02 cents
ImBatman is offline   Reply With Quote
Old 03-06-2015, 12:12 PM   #129
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can have it active on any particular mapswitch mode, so you don't have to have it active all the time. By default it also doesn't work under 3k and lower than 30mph, but you can change that if you want.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-06-2015, 03:26 PM   #130
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Shiv stated he is really hesitant to do auto rev-matching because he doesn't want to take away control of the throttle from the user, which I can understand from his point of view.
Jyn is offline   Reply With Quote
Old 03-06-2015, 11:12 PM   #131
SoCalArgento
Drives: 2014 Argento FRS
I'm sure this is on here somewhere but couldn't find it on my phone:
When is it safe to unplug the oft? Meaning if I was using it for real-time data/data-logging for a few miles and got what I needed and want to unplug it. Is it okay to just unplug with car running/driving as long as it's in the home page and Not writing/reading the ecu?
Any input is greatly appreciated 👍
SoCalArgento is offline   Reply With Quote
Old 03-06-2015, 11:44 PM   #132
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by s2d4 View Post
Yes, heel toe works.
Shiv@Openflash is offline   Reply With Quote
Old 03-06-2015, 11:51 PM   #133
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
As long as you aren't doing a read/write, it is safe to unplug.
Before the recent update, I've shut the car off before saving the data log a few times with no issues as well (the log didn't save but nothing was messed up in the process).
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
kevin.nguyen (03-07-2015), SoCalArgento (03-07-2015)
Old 03-07-2015, 12:35 AM   #134
SoCalArgento
Thank You Sir
Old 03-07-2015, 01:18 AM   #135
steve99
Drives: FT86
Any input is greatly appreciated ��
correct do not unpluig during read\write of a rom.
if you do unplug before saving log or while oft saving log it will be lost,
however plugging in or unplugging and obd port devices especially if its interrogating ecu for logging data can cause a hickup on the CAN bus and maywill trigger U0155 cel code.
the oft guys usually disable this cel code in oft roms to stop the cel being tripped if its not disabled it can cause limp home mode requiring a cel code clear or ecu reset by battery terminla removal.
Probably wont happen on oft roms as its usually disabled but if you were logging your mates car that was not tuned and unplugg oft while engine on you might give them a fright when it goes limp home mode and rpm limited to 4000 and cel code. no damage is done jist reset cel with oft and you all good.
Old 03-07-2015, 01:25 AM   #136
SoCalArgento
Awesome info @steve99 👌
Old 03-19-2015, 09:15 PM   #137
Carmaniac 86
Drives: Frs
Are the tunes out for D00C yet for 2015?
Carmaniac 86 is offline   Reply With Quote
Old 03-19-2015, 09:24 PM   #138
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Also if you reset a code, it seems to reset all your learned data - LTFT, etc.
Old 03-19-2015, 09:30 PM   #139
steve99
Drives: FT86
Yes, talk to Openflash guys
Old 03-19-2015, 09:32 PM   #140
steve99
Drives: FT86
Ok will add that.
That was just resetting with oft/torque app and not battery removal ?
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
