Old 03-04-2015, 12:11 PM   #15
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I've been using these 3mm spacers up front w/ stock studs for over a year now with no issues: [ame="http://www.amazon.com/5x100-Hubcentric-Spacers-Subaru-Impreza/dp/B00A7I2SU0/ref=sr_1_3?ie=UTF8&qid=1425489071&sr=8-3"]www.amazon.com/5x100-Hubcentric-Spacers-Subaru-Impreza/dp/B00A7I2SU0/ref=sr_1_3?ie=UTF8&qid=1425489071&sr=8-3[/ame]
Originally Posted by Synack View Post
Reviving this bad boy again. Are we CONFIRMED that 3mm will be just fine? I do take my car out on mountain runs a lot.
Originally Posted by humfrz
I'm old and lazy
Synack (03-04-2015)
Old 03-04-2015, 02:26 PM   #16
Synack
Boosted
Synack's Avatar
Drives: Sideways
I've been using these 3mm spacers up front w/ stock studs for over a year now with no issues: www.amazon.com/5x100-Hubcentric-Spacers-Subaru-Impreza/dp/B00A7I2SU0/ref=sr_1_3?ie=UTF8&qid=1425489071&sr=8-3
Any vibrations or noise?
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 03-04-2015, 05:25 PM   #17
wparsons
wparsons's Avatar
You wouldn't get noise or vibration from too much spacer thickness on the stock studs...
The only thing that would happen is the lugs coming off from not enough thread engagement.
flickr
Old 03-04-2015, 06:38 PM   #18
Sweet48
Sweet48's Avatar
Drives: 2013 Subaru BRZ
I've seen 5MM slip ons done with no problems BUT i havent been updated since after the initial install, I'm still wary of it though, I wouldn't do it. 3mm I'm comfortable with (which is what i'm using unfortunately)
And as others have said. DO NOT cheap out on spacers, I've seen way too many people have cracked and/or warped spacers (some were warped before use). I've also heard of wheels off's from sheared studs on cheap-o spacers. I'll stick with H&R's, and Eibachs (Or Project Kics if I'm feeling sexy :P)
Sweet48 is offline   Reply With Quote
Old 03-04-2015, 06:52 PM   #19
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I've used 5mm spacers on my car. Cross country trips, drift events, daily driven. Zero issues after over 10k miles. Just made sure to properly torque them down to spec.
I wouldn't go any more than 5mm though.
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
batlwagn (06-01-2016), smg1138 (07-02-2017)
Old 06-09-2016, 11:23 AM   #20
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
SOrry for bring up old post, but did u use any of longer studs for 5mm up front?
Thanks
bhbnuckle is offline   Reply With Quote
Old 06-09-2016, 11:45 AM   #21
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
3mm spacer on stock is fine. Any thicker buy quality bolt on spacers, or extended studs with a slip on spacer. Of course the best solution is a wheel that fits correctly.
I have 20mm H&R spacers with the studs pressed out, and ARP extended lugs on my setup. I'm pleased with that.
JazzleSAURUS is offline   Reply With Quote
Old 06-09-2016, 01:02 PM   #22
TylerLieberman
Drives: '24 GR86
Thanks
I ran 15mm spacers with extended studs, but 5mm spacers were used with OEM studs.
The Following User Says Thank You to TylerLieberman For This Useful Post:
bhbnuckle (06-09-2016)
Stock FR-S amp sirhc Electronics | Audio | NAV | Infotainment 36 01-18-2014 08:38 AM
Spacer how to right in your driveway. F3dzo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 10-22-2013 07:31 PM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
[SYD] Swap my stock GTS 17" for your stock GT 16" wheels eckoflyte AUSTRALIA 11 06-18-2012 08:17 AM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
