Old 02-23-2015, 06:46 AM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
17x8.25 tire size 225/45, 235/45 or 245/40?
Going to be picking up XXR 527 17x8.25 +35 wheels and the 8.25 seems to be an uncommon width. I read that 225/45 is a recommended size for the stock 17x7 and 245/40 is good for 17x9, would 235/45 fit the bill as it's right in between?
The tires I'm pretty much set on Michelin Pilot Super Sports. I'd prefer the tire to be a bit meatier width wise for rim protection.
tracerit is offline   Reply With Quote
Old 02-23-2015, 09:46 AM   #2
Frsboxer
Drives: 2015 scion frs
235 would be the recommended size for that wheel
Frsboxer is offline   Reply With Quote
The Following User Says Thank You to Frsboxer For This Useful Post:
tracerit (02-23-2015)
Old 02-23-2015, 10:02 AM   #3
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
Any of those sizes will fit that wheel. I have 225s on the 18x8.75 XXRs. If you want a bit more protection for the rim, go with the wider tires though.
FReSh is offline   Reply With Quote
The Following 2 Users Say Thank You to FReSh For This Useful Post:
brianbui23 (01-27-2022), tracerit (02-23-2015)
Old 02-23-2015, 10:03 AM   #4
adamg
Drives: brz
235/45 seems like the widest you could go for that wheel
adamg is offline   Reply With Quote
The Following User Says Thank You to adamg For This Useful Post:
Old 02-23-2015, 01:41 PM   #5
tracerit
Just purchased the wheels and 235/45/17 tires from tirecrazy.com Glad I checked them out before going with the ebay pickup/costco. tirecrazy.com really does have crazy prices, i'm actually surprised they didn't charge me tax since they're just a city away (according to their "contact us" page).
Old 02-23-2015, 02:03 PM   #6
MrBlaze-65
Drives: 2014 Subaru BRZ
just as an fyi I ran a 17x8 enkei nt03+m on my wrx and I fit a 255 on it with 0 issues. Autocrossed with it that way as well. So much tire that I think it actually slowed my stock power car, 245 was always my happy place. Looked very aggressive though. No clue if that would rub on a BRZ but just letting you know that you can go wider.
MrBlaze-65 is offline   Reply With Quote
Old 02-23-2015, 02:28 PM   #7
k.houan
k.houan's Avatar
Drives: BRZZZ
Im running XXR 527 17x8.25. Just mounted a set of Federal 245/40R17's. Works perfectly for me.
k.houan is offline   Reply With Quote
Old 02-28-2015, 12:43 AM   #8
tracerit
Here's how my car stands now with 235/45/17 MPSS and XXR 527 17x8.25 on Eibach Pro Kit springs. Unsure of the alignment numbers.
The Following 5 Users Say Thank You to tracerit For This Useful Post:
brianbui23 (01-27-2022), JonAvalon (02-28-2015), jonzhuxD (02-28-2015), new2subaru (08-14-2020), Teseo (08-11-2017)
Old 02-28-2015, 12:59 AM   #9
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Looks great!
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
The Following User Says Thank You to themajesticone For This Useful Post:
tracerit (02-28-2015)
Old 02-28-2015, 01:10 AM   #10
tracerit
for some reason it looks like it's sitting higher... but i can't go any lower, scraping too often already :P just waiting for some black Muteki lug nuts to come in black STI center cap stickers.
Old 08-10-2017, 11:35 PM   #11
frstnotlast
Drives: 2013 Ultramarine FRS
a while ago, but did you have any rubbing issues on the fronts? ive got 17x8 rota titans being mounted with 235/45/17 MPSS overnight tonight, the mechanic took a look when i dropped them off and said he thought they would rub in the front, but I think hes wrong. just curious, thanks!
frstnotlast is offline   Reply With Quote
Old 08-14-2020, 01:16 PM   #12
G.S202086
Drives: 2020 Toyota 86
I also want to run 235/45 on 17X8+35 to fill the gap on stock suspension, I'm hearing mix messages some say will rub some say it works, don't want to drop to a 40 cause not many brands to choose from
G.S202086 is offline   Reply With Quote
Old 08-14-2020, 02:47 PM   #13
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I run 8's and have used both 225 and 235. the 225 is a more nimble feel and the 235s have better grip however they were different compounds by 2 different manufacturers. Regardless I wouldn't go any wider than 235 on those.
TommyW is offline   Reply With Quote
Old 08-26-2020, 03:10 AM   #14
Randoman5
My 94 trans am came with 245s on 8 inch wheels. I switched to 275s on 9 inch wheels (also a factory offering.) I don’t know why people are telling you 245s won’t work. 235 is an oddball size and selection of tires will be limited.
Randoman5 is offline   Reply With Quote
The Following User Says Thank You to Randoman5 For This Useful Post:
Summerwolf (08-30-2020)
ESM 004 size questions- And 17x8 pic requests newports Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-02-2014 02:19 AM
Tire size TofuAE86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-10-2014 12:03 AM
Tire size for 17x8.5 +32 +42 giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-06-2013 08:17 PM
Which tire size for 17x8.5? giraffee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-11-2013 07:26 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
