Old 02-19-2015, 01:33 PM   #1
Yurgle
Drives: 2015 Toyota GT86 (EU Spec)
Small drop alignment
hi guys!
i want to lower my car with RS*R springs (15mm drop)
do the aligment of my car change a lot with such a conservative drop?
do i need to buy some hardware to adjust camber and toe?
Yurgle is offline   Reply With Quote
Old 02-19-2015, 01:39 PM   #2
Koa
1. Probably won't need an alignment with such a conservative drop alone
2. Hardware to adjust camber for Sportline-esque drops or less (<1.3"):
- Camber bolts in front
- Adjustable LCAs in rear (probably can get by with camber bushing kit but those are notorious for sucking)
Toe is adjustable for aforementioned drop or less without any new hardware
I recommend you buy camber bolts and LCAs anyway and get an awesome alignment done. Stock alignment can suck. I went to firestone (a GOOD one, recommended by fellow enthusiasts) for a lifetime alignment package. 4 years of alignments for $170. They typically recommend 4 alignments per year.
I see you're in France- try to find a similar deal and you're good to go
My suspension set-up:
- Eibach Sportlines Springs
- Bilstein B8 Shocks
- RacerX adjustable Lower Control Arms
- Whiteline camber bolts (front, 1 each side)
My alignment settings:
Front
Camber: -1.1
Caster: 5.7
Toe: -0.05 (toe out)
Rear
Camber: -1.3
Toe: 0.10 (toe in)
I can explain why I have the settings as such if you're interested. Good luck!
Old 02-19-2015, 02:01 PM   #3
Yurgle
now that you talk about stock alignment, on my car you can tell just looking with bare eyes that camber in front is near 0° and on the rear camber is far more negative on the passenger side than on the driver's... kinda strange..
Old 02-19-2015, 02:11 PM   #4
vroom4
Get some camber bolts for the front, and then go get an alignment.
Anybody that suggests you don't need an alignment when swapping springs...
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
Koa (02-19-2015)
Old 02-19-2015, 02:39 PM   #5
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by Yurgle View Post
hi guys!
1.) Yes, get an alignment.
2.) I would grab a set of the OEM crash bolts from Subaru. They're cheaper and sturdier than aftermarket camber bolts.
3.) If you're driving on the street with that conservative of a drop, LCAs are complete overkill IMO. The natural camber will be totally fine and toe is already adjustable from the factory.
was385 is offline   Reply With Quote
Old 02-19-2015, 02:45 PM   #6
Yurgle
What is good camber setting for spirited driving on open roads? We have a lot of narrow twisty roads here in France
i'm looking for good grip in sharp turns and minimal tire wear (i guess 0 toe?). I don't plan to go on track for now
Old 02-19-2015, 02:58 PM   #7
Koa
Slight negative camber up front and rear will not hurt your tire wear that much... but pays dividends back in twisty handling and performance
Anything over -1.5 up front probably no good for non-tracker. -1.1 fr/-1.3r and I drive 600-800 miles a week. No complaints here.
slight toe out up front will help with turn in/steering feel and tracking the car in the twisties. The downside is increased wandering and stability at high speeds. -0.05 is very conservative and I recommend it.
Slight toe in the rear will help with braking stability and helps to control rear instability
@vroom4 I should have stated that while many consider a ~half inch drop or less unwarranting of an alignment, I recommend aligning the car with crash bolts even if stock.
Old 02-19-2015, 03:03 PM   #8
wheelhaus
wheelhaus's Avatar
I also understand a drop under 1" does not need rear LCAs. Some neg camber is added from the drop, but it's minimal. Up front, crash bolts/camber bolts are so cheap it's a no brainer, and we need to dial in more neg camber anyways, dropped or not.
The Following User Says Thank You to wheelhaus For This Useful Post:
Koa (02-19-2015)
Old 02-19-2015, 03:18 PM   #9
Koa
whatever you do OP, recommend against just getting camber bolts and having them dial in zero camber up front, with negative camber in the rear. Just doesn't feel right. YMMV
Old 02-19-2015, 03:32 PM   #10
Yurgle
Ok, so just camber bolts up front will do the trick
any cheap way to fix the odd camber mismatch on the rear wheels? or maybe it is set on purpose less negative on the drivers side to compensate the driver's weight? (just wondering...)
Old 02-19-2015, 03:39 PM   #11
Koa
It's definitely not deliberate..
Here's a tip to set things right, though.. address this issue with the alignment shop. If they're competent and patient, they will adjust the crossmember and links on the rear system to arrive at an acceptable rear camber setting that isn't varied. There's no excuse that it should be, but realistically these cars are assembled with variances that aren't all caught before being shipped out
Old 02-19-2015, 04:09 PM   #12
vroom4
The rear crossmember has a ton of slop, you can loosen it and get it close probably. And my you I mean alignment shop.
Old 02-19-2015, 07:00 PM   #13
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
I have a similar question... dont mean to thread jack xD
I was gonna run these springs: http://www.ft86speedfactory.com/rs-r...-frs-1156.html
25-30mm front, 30-35mm rear
Do you think I can get away with no camber adjustment in the rear? I'm guessing it would produce about ~-2.5 of camber in the rear. I have no problem running camber bolts in the front. Just wanted to wait on LCAs.
From what I've read toe will attribute to tire wear more than camber.
Or should I pick different springs for a more ~1" drop.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 02-19-2015, 07:05 PM   #14
vroom4
Rear camber will be fine. Will just not handle optimally at the limit with more negative camber then rear.
Koa (02-21-2015)
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Alignment after 1 inch drop? ang31ito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-09-2014 11:20 AM
Alignment required for different size wheels after drop? Shad0ez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-08-2013 03:30 PM
Drop it Like its Hot! *Lets See Your Drop* VIXEN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 92 09-07-2013 02:53 AM
Who is going to buy the FRS DROP DROP Shop? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-18-2012 05:45 PM
