Old 02-18-2015, 02:00 PM   #29
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Originally Posted by BRZFanatix View Post
Are the ones I posted the newest ones?
Honestly, I'm pretty sure they phased the old ones out by now. Its been a while since they made the previous version. You should be good.
ApolloSki is offline   Reply With Quote
The Following User Says Thank You to ApolloSki For This Useful Post:
BRZFanatix (02-18-2015)
Old 02-18-2015, 04:13 PM   #30
Panman
Panman's Avatar
Drives: 86 GTS
Can I suggest that you get your car and drive it for a reasonable period of time getting used to the characteristics of the suspension and ride/handling that you do and don't like.
Making decisions on suspension and major wheel size changes before you know what you really want to change seems a little..... Premature.
Panman is offline   Reply With Quote
The Following User Says Thank You to Panman For This Useful Post:
Old 02-19-2015, 10:49 AM   #31
AlexWood
Drives:
I ran an 18x9.5 +34 with 235's and had slight rubbing issues. I'm lower than a 35mm drop though so that might not help. I would say you'll have to throw a decent amount of camber at it to make it work, but it's do-able.
AlexWood is offline   Reply With Quote
Old 02-19-2015, 10:55 AM   #32
Racecomp Engineering
Thanks good to know! And I will talk so them!!! So at least I don't have to buy a camber kit for the front, which kit in the back would be better than WL since you said some shops don't like adjusting it? Is there a better choice than WL?
Thanks for your patients with me andy! I really appreciate you taking the time to respond to my newbie questions.
Edit:
Andy I found these Adjustable rear arms? These good ones? Cusco Lateral Arm Rear Adjustable
SPC rear arms will be fine for the street. Whiteline is a great choice but a little bit more monies. I'm sick and out of the office but if you call in Myles or Larry can help you out or put a package together for you.
- Andy
BRZFanatix (02-19-2015)
Old 02-19-2015, 12:13 PM   #33
AlexWood
Drives:
The Following User Says Thank You to AlexWood For This Useful Post:
Old 02-19-2015, 09:44 PM   #34
BRZFanatix
Drives: Soon to be BRZ
- Andy
Thanks andy for all your help! I decided on these what do you think:
ST Suspension Coilovers
SPC Performance Adjustable arms for the REAR
and
SPC Performance Cam Bolts for the front
What do you think? 255.35.18 All around and I wouldn't need adjustable arms in the front? Only the camber bolts right? Thanks again!
BRZFanatix is offline   Reply With Quote
Old 02-19-2015, 10:32 PM   #35
ApolloSki
Stealth
ApolloSki's Avatar
and
I'm pretty sure ST has adjustable slots for the front so you wont be needing camber bolts. Just need the coils and SPC LCA.
Old 02-19-2015, 11:00 PM   #36
BRZFanatix
So the front coils on the ST have adjustable slots then?
Old 02-19-2015, 11:34 PM   #37
Yes, similar to KW.
Give us a call tomorrow and Myles or Larry can put together a package for you.
- Andy
newbie OFT question 2much Software Tuning 5 11-13-2014 08:59 PM
newbie NA Tune Question eguzman6 BRZ First-Gen (2012+) — General Topics 2 11-12-2014 03:55 PM
Newbie Question! ButtonMasher Tracking / Autocross / HPDE / Drifting 5 04-10-2014 04:20 PM
Newbie question: what is an ecu tune Dispect Engine, Exhaust, Transmission 1 11-30-2012 01:35 PM
question about frs for a newbie enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 18 08-04-2012 05:42 PM
