Old 02-10-2015, 11:48 AM   #15
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
Originally Posted by JERM^ View Post
Anyone knows if the long nozzle one sticks out at the bottom for the 86?
it does not, but if you're super low and at all worried about it get the one without the nozzle or nub.
Originally Posted by JohnJuan View Post
Have a read here
The valve is locked in place. You have to move it against the spring, then turn it before it opens. If you felt this, you would likely not question the seal. It's a spherical thing that turns in there. The seal is probably 3/4" thick. any failure would probably include your drain bung being ripped out too.
I do agree that a magnetic drain bolt is more simple. I suppose that the Fumoto valve does add another point of failure to the oil draining system.
On the bright side, once it's threaded in, you don't have to remove it again, and you never have to worry if the drain plug is on tightly enough again, which is nice.
never having to remove it again is a big bonus, never have to deal with crush washers, or stripping the bolt (which after 3 oil changes was already showing how soft the stock drain bolt was.) but the main reason was for just how quick and mess free the oil change process is now with this. no more having oil all over my hands.
Originally Posted by FRSBRZGT86FAN View Post
It's not as simple as a magnetic drain bolt is essentially what I'm saying. What if a seal fails in the drain valve? Is the valve level locked into place as well? What about possible clogging issues?
its a pretty simple design and i'm not at all worried about clogging (honestly if that much crud is in my oil that my quik valve clogged i'm in a world of hurt)
here's a quick video, skip to the 1 minute mark to see how it works.
[ame="https://www.youtube.com/watch?v=VHIoQb2WPL0"]Change Car Oil Quick, Clean & Easy with Fumoto Valve - YouTube[/ame]
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 02-10-2015, 11:56 AM   #16
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
Mine extends past the skid plate by maybe 3-4 mm. They have a short nipple (giggidy) one as well. As someone has mentioned before, if you run over something that will hit the nozzle/valve, you will have to worry about other things breaking before the oil pan.
Shinobu's Smile is offline   Reply With Quote
Old 02-11-2015, 02:44 AM   #17
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Get the F-108S; from what I remember the F-108N (nipple) wouldn't be ideal for our cars. Double check of course.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 02-11-2015, 09:16 AM   #18
JERM^
JERM^'s Avatar
Drives: WRB BRZ Aozora 15'
I bought both. I bought the s version on Amazon but they sent me the wrong one. However I bought it on Amazon us so in order to return it I need to drop if off at an ups in the States. Decided to just keep it.. Wondering if it's of any use to anyone else lol... Ended up getting the one without a nipple at all. Should be fine too.
JERM^ is offline   Reply With Quote
Old 02-13-2015, 02:23 PM   #19
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Where do you guys dispose your oil?
jaorocks1 is offline   Reply With Quote
Old 02-13-2015, 02:35 PM   #20
White64Goat
Check with Auto Zone or Advance Auto Parts. A lot of them take used oils. Or check with your local county services, they may have a place to recycle it.
Old 02-13-2015, 02:46 PM   #21
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I like the thought of oil drained right back into an empty container. This Fumoto valvre thingy does have me intrigued. But I'm too lazy to do my own oil changes anymore as a friend of mine owns an oil change shop.
hmong337 is offline   Reply With Quote
Old 02-13-2015, 03:05 PM   #22
RobertPaulson
Drives: 2017 Golf R
oreilly's near my place takes oil. most auto parts stores will take oil but call around first
Old 02-22-2015, 10:34 AM   #23
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
So I did my oil change today! So damn easy! Subaru makes everything so accessible The only thing is, the techs said it takes 5.3L but I told myself to check the manual just to do my do-diligence and it's 5.4L when you do it with the filter. Sooo just in case y'all were wondering. As well as I documented everything, receipts and what not for warranty stuffs! Thanks again for your inputs!
Wilso is offline   Reply With Quote
Old 02-22-2015, 09:15 PM   #24
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I would put 5 liters into the car and check for level before pouring in more oil. The 5.5 liters is only a reference. It may vary depending on each vehicle.
Muaddib is offline   Reply With Quote
The Following User Says Thank You to Muaddib For This Useful Post:
Wilso (02-23-2015)
Old 02-22-2015, 09:53 PM   #25
tracerit
Drives: '13 SSM BRZ Limited 6MT
Bought some oil filters yesterday from Subaru and the guy asked if I wanted crush filters as well. I told him "don't the oil filters come with them already? i don't recall ever having to buy them in the past". Then I remember I had a Fumoto valve :P
Also when's the best time to check oil level? Before the car has been warmed up or after?
tracerit is offline   Reply With Quote
Old 02-23-2015, 09:38 AM   #26
Wilso
yup! I filled it to 5 to check, was low, checked at 5.3 was just under so I topped it off
Old 02-23-2015, 09:39 AM   #27
Wilso
Best time is when it's warm, so if you're doing an oil change, go for a quick drive, come back, change the oil, let it run, do another quick drive around the block and then check to make sure everything is good well, that's how I do it lol
The Following User Says Thank You to Wilso For This Useful Post:
tracerit (02-23-2015)
Old 06-20-2016, 01:11 AM   #28
SixWho
SixWho's Avatar
Drives: Subaru BRZ 15'
Good Read
Self oil change Pro's; Around $50 ($30 oils, $20 filter) , you know your car was done correctly. Con's self labor. (ehh whatever, lol)
Take it to the shop for an oil change; around $80, you don't know if everything was done correctly, they use a recommended brand you may not agree with. I think I will rather do it my self for the 30 minutes I have to take out of my day. Fine with me.
SixWho is offline   Reply With Quote
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 07:27 PM
Oil change stiboy808 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 05-27-2014 11:26 AM
Oil change stiboy808 Hawaii 6 05-25-2014 03:49 PM
WHAT YOU WILL NEVER CHANGE ON THIS CAR? Mikepage BRZ First-Gen (2012+) — General Topics 28 06-09-2013 11:29 AM
WHAT YOU WILL NEVER CHANGE ON THIS CAR? Mikepage Scion FR-S / Toyota 86 GT86 General Forum 22 06-04-2013 11:32 PM
