Old 02-09-2015, 04:02 PM   #1
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
Do it yourself oil change
hey guys/ gals/ things!
I was wondering if there's any real bad thing about doing
An oil change myself as opposed to going to the dealer?
Last time I went to the dealer they overfilled my oil... So I'd rather
Do it myself because I know I would do it right
Thanks in advance
Wilso is offline   Reply With Quote
Old 02-09-2015, 04:11 PM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I suppose the only real bad thing is that you get a little dirt/oil on your hands.
My suggestion:
Buy the fumoto drain valve before doing the oil change and install it when you're changing the oil. It will make every future oil change that much easier.
TylerLieberman is offline   Reply With Quote
Old 02-09-2015, 04:22 PM   #3
Wilso
My suggestion:
I hate getting dirty! lol
I never knew those things existed! Thanks
Old 02-09-2015, 04:33 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
also, the dealer will typically provide free scratches on your car via car wash
So you're missing out on that.
Old 02-09-2015, 05:03 PM   #5
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Thanks in advance
FYI, see this thread:
http://www.ft86club.com/forums/showthread.php?t=11734
Old 02-09-2015, 05:33 PM   #6
was385
Drives: MT WRB BRZ Limited, 2007 911s
They're wonderful. I just flip the valve and go watch TV for 5 or 10 minutes and don't even need so much as a paper towel.
was385 is offline   Reply With Quote
Old 02-09-2015, 06:11 PM   #7
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
oh you want the valve, trust me on that one, best 26$ i spent on the car.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 02-09-2015, 06:50 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I feel like that's a major risk
Old 02-09-2015, 06:58 PM   #9
RobertPaulson
Drives: 2017 Golf R
how so? the nub doesn't extend past the skid plate even though it does appear that way in the picture. its been on my car for 8000 miles, 0 leaks, easiest oil change i've ever had.
you can also get one without the extra nub.
Old 02-09-2015, 07:15 PM   #10
Hippophobia
Drives: 2013 Whiteout FRS
I have one of the short ones. It works just as good as the one with the nub and is barely bigger than the stock drain plug. ALSO, you can order some locking rings from the website if you are worried, but it's actually a little difficult to open and close. So no worries about it "popping" open or getting bumped. They are awesome.
Hippophobia is offline   Reply With Quote
Old 02-09-2015, 07:27 PM   #11
RobertPaulson
Drives: 2017 Golf R
yeah i tested the valve out manually before installing to see how likely it could come undone while driving. and i just don't see how it could be done without someone going down there and doing it.
Old 02-09-2015, 09:13 PM   #12
JERM^
JERM^'s Avatar
Drives: WRB BRZ Aozora 15'
Anyone knows if the long nozzle one sticks out at the bottom for the 86?
JERM^ is offline   Reply With Quote
Old 02-09-2015, 09:47 PM   #13
FRSBRZGT86FAN
It's not as simple as a magnetic drain bolt is essentially what I'm saying. What if a seal fails in the drain valve? Is the valve level locked into place as well? What about possible clogging issues?
Old 02-10-2015, 12:17 AM   #14
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Have a read here
The valve is locked in place. You have to move it against the spring, then turn it before it opens. If you felt this, you would likely not question the seal. It's a spherical thing that turns in there. The seal is probably 3/4" thick. any failure would probably include your drain bung being ripped out too.
I do agree that a magnetic drain bolt is more simple. I suppose that the Fumoto valve does add another point of failure to the oil draining system.
On the bright side, once it's threaded in, you don't have to remove it again, and you never have to worry if the drain plug is on tightly enough again, which is nice.
JohnJuan is offline   Reply With Quote
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 07:27 PM
Oil change stiboy808 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 05-27-2014 11:26 AM
Oil change stiboy808 Hawaii 6 05-25-2014 03:49 PM
WHAT YOU WILL NEVER CHANGE ON THIS CAR? Mikepage BRZ First-Gen (2012+) — General Topics 28 06-09-2013 11:29 AM
WHAT YOU WILL NEVER CHANGE ON THIS CAR? Mikepage Scion FR-S / Toyota 86 GT86 General Forum 22 06-04-2013 11:32 PM
