Old 02-08-2015, 12:28 PM   #15
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
light rattling randomly on acceleration?
For me the sound comes from the foot well on drivers side more than passenger side. And it's only under accelerateion too. I wonder if it could be the heat shield like mentioned above
Kronos is offline   Reply With Quote
Old 02-09-2015, 01:32 PM   #16
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Originally Posted by ali View Post
Yes! I've been hearing this for a while, I'm on a stock '15 BRZ. I am able to recreate this sound continuously by jerking the car using acceleration, around 3k on the 4th/5th gears, accelerate then lift off, and repeat.
I'm subscribing to this thread because the sound is concerning to me, thank you for bringing this up!
Yes this. Havent flashed back fo stock yet cause im lazy and it stopped doing it and started again today. So not sure if its the tune.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 02-10-2015, 07:46 PM   #17
maj75
Drives: Blue FRS 6sp, 95 M3
Just had this issue with CEL. Dealership was ready to replace transmission, but it turned out to be a melted Teflon seal on one of the direct injectors, causing detonation. If this issue is not present when the engine is cold, but gets worse as the engine heats up, you may want to look at the DI seals.
maj75 is offline   Reply With Quote
The Following User Says Thank You to maj75 For This Useful Post:
Kronos (02-10-2015)
Old 02-10-2015, 08:20 PM   #18
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
What year? 2013?
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
Old 02-12-2015, 09:31 AM   #19
ali
Originally Posted by nickmerronesucks View Post
Yes this!! Been trying to record it for two days now and it wont happen. Def not a rodknock or exhaust leak. just annoying
https://soundcloud.com/ali87sa/brz-acceleration-rattle
Here ya go, the constant ticking.
ali is offline   Reply With Quote
Old 03-10-2015, 04:31 PM   #20
Ethereal05
Ethereal05's Avatar
Drives: 2015 BRZ Series.Blue
Originally Posted by Kronos View Post
Does it sound anything like this?
I'm on oft stage 1 stock and I'm getting this rattle as well that is most definitely separate from the rasp around 4k you get from the tune
https://copy.com/qBQ0lSeoas9OFGSu
https://copy.com/JqSNPV1iHHENEg9Y
I have the same thing here as well. It definitely sounds like an exhaust vibration under load. I am going to have a shop make sure all of my exhaust is tight as well as the heat shield. I don't think its really a major issue just a vibration under load. My old car (Mitsubishi) had a similar noise during load.
Ethereal05 is offline   Reply With Quote
Old 03-10-2015, 04:47 PM   #21
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
I believe I'm having the same issue, a light rattling that sounds like it's from up front (perhaps slightly towards the passenger's side) when driving. Rattling usually comes up in 3rd or 4th gear around 3k RPM but seems to die down if I rev it higher. The videos posted by Kronos sound pretty much the same as what I'm hearing.
Stock 2015 BRZ, no performance mods whatsoever.
Lelantas is offline   Reply With Quote
Old 05-05-2015, 12:02 PM   #22
Rosticles
Drives: 1966 Mustang, 2013 FR-S
I just started getting this exact noise on my car as well. No tunes or engine mods.
Rosticles is offline   Reply With Quote
Old 05-06-2015, 05:58 AM   #23
Jamesbrz
Drives: White BRZ
Yeah mine does it only under hard acceleration off take off in first and second gear, having my mechanic test drive it and inspect it tomorrow, will let you know how it goes.
Jamesbrz is offline   Reply With Quote
The Following User Says Thank You to Jamesbrz For This Useful Post:
carma143 (05-10-2015)
Old 05-06-2015, 06:45 AM   #24
steve99
Drives: FT86
Log engine parameters FLKC Knock correction and IAM
could be knock
these motors do knock around 3000 rpm under high load
Old 05-07-2015, 03:16 PM   #25
nickmerronesucks
Ned flanders
mine is a tune related noise. vvt
797Performance.com
The Following User Says Thank You to nickmerronesucks For This Useful Post:
golfyankee2121 (05-15-2015)
Old 05-08-2015, 04:30 AM   #26
Jamesbrz
Drives: White BRZ
I took the bottom stone tray off and noise is gone, so need to find out we're it is touching under hard acceleration.
Kronos (05-08-2015)
Old 05-10-2015, 04:54 PM   #27
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Same deal with me. It just started about a week ago and occurs at about 6k rpm.
carma143 is offline   Reply With Quote
Old 05-14-2015, 12:33 AM   #28
carma143
carma143's Avatar
What is that? The rubber thing that helps hold small things in the middle in front of the shifter?
Used car from dealership randomly dies, what to do? mike the snake Off-Topic Lounge [WARNING: NO POLITICS] 11 08-20-2014 08:41 PM
AC HVAC turns on randomly DarkestBuddha Electronics | Audio | NAV | Infotainment 0 06-28-2014 09:53 PM
Rattling noise under Acceleration 5k RPM or more phuthinhon Issues | Warranty | Recalls / TSB 5 05-12-2014 01:34 AM
Car Alarm Randomly Triggers nathanR Electronics | Audio | NAV | Infotainment 2 09-03-2013 11:41 AM
Rattling Noise on acceleration Naughty AFRICA 2 05-14-2013 12:17 PM
