Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
light rattling randomly on acceleration?
Not shifter rattle and doesnt sound to ne coming from engine but maybe something up front...anyond had this issue and if so what did you do to fix it? Sounds likr somethings loose and vibrating around 3k. Only mods are intake exhaust openflash tablet and coilovers.. someone told me it was the stoxk header heat sheild? Also only happens under load
797Performance.com
I would check the heat shield.
Pretty vague description to try to guess anything else.
ya, heat shield or check exhaust gaskets.
Drives: BRZ DGM Limited
can you post a video of the sound? Another rod knock?
Drives: Scion FR-S, Ultramarine
same thing just started with me. It might be a different issue though. It sounds like a loose connection, or some type of leak next to the front pipe. My exhaust is much louder than normal and something rattles when I start the car up. Sometimes it stops, and the exhaust sounds normal once the car warms up, and sometimes it doesnt. I just need to get under the car to find out for sure.
Drives: 2015 FR-S (Halo)
I have always had the exact same thing. Only sometimes, if I lean into the throttle there's a tiny quick rattle, if I let off and tap sharply it might happen one more time but after that if I try to replicate it it won't happen until later. Rarely happens, usually when I'm in a higher gear but that is maybe the only reason I hear it over the exhaust.
Sent from my HTC One_M8 using Tapatalk
#7 | |
Ned flanders
797Performance.com
Drives: Fast
Try flashing it back to stock and see if the noise goes away. Could be the timing advance causing a harmonic noise in the exhaust around that RPM.
Ned flanders
Was going to try that because i was reading another thread where that was the noise! thanks guys ill report back
797Performance.com
#10 |
Drives: Fast
Reason I mention this is because when I flash back to stock for inspection, my car is about 10 times quieter around that rpm. The tune really increases the volume.
#11 |
Drives: 2014 SWP BRZ, MT
The openflash tune's have cam timing in that region which makes a pretty loud metallic rasp like sound. It's not harmful, it's just a sound. But yes flash a stock map and make sure it's not something other than that.
The answer is racecar. Always.
#12 |
Drives: Asphalt FR-S MT
Does it sound anything like this?
I'm on oft stage 1 stock and I'm getting this rattle as well that is most definitely separate from the rasp around 4k you get from the tune https://copy.com/qBQ0lSeoas9OFGSu https://copy.com/JqSNPV1iHHENEg9Y |
#13 |
I'm untuned and I get this noise, so it's probably not entirely the tune
#14 | |
I'm subscribing to this thread because the sound is concerning to me, thank you for bringing this up! |
| Used car from dealership randomly dies, what to do? | mike the snake | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 08-20-2014 07:41 PM |
| AC HVAC turns on randomly | DarkestBuddha | Electronics | Audio | NAV | Infotainment | 0 | 06-28-2014 08:53 PM |
| Rattling noise under Acceleration 5k RPM or more | phuthinhon | Issues | Warranty | Recalls / TSB | 5 | 05-12-2014 12:34 AM |
| Car Alarm Randomly Triggers | nathanR | Electronics | Audio | NAV | Infotainment | 2 | 09-03-2013 10:41 AM |
| Rattling Noise on acceleration | Naughty | AFRICA | 2 | 05-14-2013 11:17 AM |
