Old 02-08-2015, 09:59 PM   #1
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Factory amp connector adapter?
Here's a thought that I haven't seen before. Maybe someone mentioned it, but I haven't seen it yet.
I believe the factor unit for the BRZ (not sure about FRS), runs a full spectrum signal to the trunk, where the factory amp sits. The amp then filters the input, and sends a low pass signal to the front door woofers. Is this correct?
My though for a simple/easy/unobtrusive audio upgrade is simply replace stock amp w/ a small 2ch amp around 50wx2 utilizing factory wiring, and upgrading the front door speakers to a set of full range 2-ways.
The main "problem" here of course, would be finding a 2ch amp that would fit in the stock amp location, and an adapter to utilize the stock amp connectors w/o splicing up the factory wires.
Anyone know if this is possible and where to get these adapters?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-08-2015, 11:13 PM   #2
KenTK808
Drives: White 2014 Scion FRS
+1 on this, I would love to do this instead of opting for the OEM Audio+ option.
KenTK808 is offline   Reply With Quote
Old 02-09-2015, 05:45 AM   #3
Chimera
Drives: FRS
http://www.ft86club.com/forums/showthread.php?t=42239
Ktp-445u is bridgable into 2 ch.
DIY: BlackVue DR500GW-HD Car Cam w/Power Magic Pro Using Factory Option Connector ChiefG DIY (Do-It-Yourself) Guides 42 11-28-2017 12:04 AM
ECM Pin Connector simpleisbest Software Tuning 19 01-18-2015 02:13 AM
What's this connector ? mashal Electronics | Audio | NAV | Infotainment 5 12-10-2013 01:13 AM
Help, what connector is this? Hayashi Cosmetic Modification (Interior/Exterior/Lighting) 0 02-26-2013 01:39 AM
VSS Connector AlexTheGreek Engine, Exhaust, Transmission 15 02-02-2013 12:12 PM
