Old 02-07-2015, 12:31 AM   #71
steve99
Drives: FT86
Originally Posted by SteveIsBored View Post
Does p0420 put the car in limp mode? It never did on any other Suba but I guess this Suba isn't like any other
correction think it disable cruise control, think you are correct it does not go to limp or low power mode on p0420
Old 02-07-2015, 06:12 AM   #72
Teseo
Drives: frs
if you get cel you will disable cruise control as well, you could try 02 spacer till you get tune but don't always work
may not cause limp home mode, you can reset cel with battery disconnect
Dealer can reset the ecu for clear the cel?
Old 02-07-2015, 05:14 PM   #73
steve99
Drives: FT86
yes dealer can reset cel code.
but so can you by.
useing a cheap obd scan tool that has a rset cel unction
removing ecu fuse for a short time
disconnecting your car battery for a short time
Old 02-07-2015, 06:01 PM   #74
Teseo
Drives: frs
but so can you by.
Thanks so much. Im more close lol
Header and tune Decision Toyota GT 86 Engine, Exhaust, Transmission 24 09-09-2014 05:47 PM
OpenFlash-- header tune mtimney Forced Induction 3 08-07-2014 03:51 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
FI or Tune and Header? RSH Engine, Exhaust, Transmission 30 10-23-2013 05:09 PM
Should I buy my header or get a tune this week? Jtymay92 Engine, Exhaust, Transmission 27 06-20-2013 03:55 PM
