Old 02-03-2015, 05:15 PM   #43
Antairez
Drives: Mazda 3
Leds could potentially blow ECU or BSI on 86?
http://www.ft86club.com/forums/showthread.php?p=1612550
LED interior light upgrade causes computer failure
http://www.ft86club.com/forums/showthread.php?p=1761758
Diode Dynamic LED blow $400 fuse...
http://www.ft86club.com/forums/showthread.php?t=60355
Solid State Relay to avoid blowing ECU on our cars? anything led
http://www.ft86club.com/forums/showthread.php?p=1626739
I just want to ask a noob question here, why don't car manufacturers use LED lights as standard out of the factory? Is it because the LEDs are significantly more expensive than the traditional bulbs?
Antairez is offline   Reply With Quote
Old 02-03-2015, 05:41 PM   #44
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
So we could have interesting reads like these.
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
Tcoat (02-03-2015)
Old 02-03-2015, 05:43 PM   #45
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I honestly think it's because car manufacturers are perpetually 10 years behind the rest of the tech industry. They sold new cars with cassette players until very recently. They still think CD players are essential. I bought my last CD before they started putting CD players in new cars.
So LED lamps and customizable touch screens will replace bulbs and dials. Within the next decade or so, after we started to see them as old and quaint.
The Following User Says Thank You to Sarlacc For This Useful Post:
Koa (02-19-2015)
Old 02-03-2015, 05:52 PM   #46
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
I would think it has to do with production and warranty cost.
The Following 2 Users Say Thank You to ZOMFGAARON For This Useful Post:
Caspeed (02-19-2015), Tcoat (02-03-2015)
Old 02-03-2015, 06:02 PM   #47
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
s
Look at your tailights...they're LEDs. Auto mfgr's have increasingly used LEDs in recent years, commonly used in taillights, parking lights, accent lights, center brake lights, etc.
My '06 350Z had LED taillights.
billwot is offline   Reply With Quote
Old 02-03-2015, 06:53 PM   #48
Tromatic
Unfortunately, a modern car is designed as a system controlled in one way or another by a computer.
ETA: Zero interest in LED lighting. Are there kits/installs out there that just send you LED's and no supporting hardware?
Old 02-03-2015, 07:15 PM   #49
torqdork
torqdork's Avatar
Drives: RV-7
My '15 Camry has LED DRL's and hi/low headlights from the factory. They throw a more focused, controlled, penetrating beam in all weather than any headlights I've ever used including HID's and high powered off-road incandescents.
Adoption should spread throughout the industry pretty quickly given their low power requirements and manufacturer's trying to squeeze mileage ratings in any way possible to comply with onerous new CAFE regs.
Plus they do have a distinctive look common to high-dollar EU imports until you get closer and realize it's a Kia.
torqdork is offline   Reply With Quote
Old 02-03-2015, 07:19 PM   #50
Antairez
Drives: Mazda 3
That's exactly where my wonder came from, most cars now come equipped with LEDs in the headlight & taillight section, but not for the interior lights or license plates. So I suspect the reason they didn't switch to all LEDs completely might be due to production cost. But I am not in the industry, so I am not sure.
Old 02-03-2015, 08:12 PM   #51
torqdork
torqdork's Avatar
Drives: RV-7
True, LED's currently cost more than incandescents.
I think the gradual fleet switch to all-LED's is mostly for style and somewhat a desire for owners to duplicate the CAFE numbers. The tests are conducted with electrics off except for climate control. City cycle especially benefits from LED's where alternator drag has a greater relative effect than highway numbers that are affected more by wind drag.
The Following 2 Users Say Thank You to torqdork For This Useful Post:
Antairez (02-04-2015), Tcoat (02-03-2015)
Old 02-19-2015, 10:40 AM   #52
blown
Drives: ft86
which fuses are you checking? im having same issue gauge thinks high beams are on.. and the lights wont turn off with key out.. I removed the BIU and dont see anything physically burnt..
blown is offline   Reply With Quote
Old 02-19-2015, 11:23 AM   #53
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I think the lesson he was referring to is :
Dont fuck with the electrical system in a modern car because all that shit is tied together.
Even some light modules and door switches are tied into the OBD computer system.
And if you want help, learn some manners.
I would have gladly helped you out, but based on your comments I think you're just a *&^%&.
You couldn't be more correct
DRLs, headlight auto on timing etc are tied into the OBD system as well and I only know this after using a Bluetooth obdII dongle to disable the DRLs and seatbelt chimes through the ecu, who knows whatever else headlight related is connected to it
Old 02-19-2015, 01:43 PM   #54
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
Originally Posted by babydriver View Post
Not if you're English. Check out the OED; either spelling is acceptable.
Remember the OED is a British publication.
Merriam Webster does show it as a chiefly British word.
Caspeed is offline   Reply With Quote
Old 02-19-2015, 01:51 PM   #55
Koa
As it stands, One for One, LEDs cannot beat HIDs in terms of light output. The Camry LED headlights are cool but watt for watt, a HID setup in a comparable housing will outshine it.
I'm not doubting it throws a more focused, controlled, penetrating beam in all weather than any other headlights you've owned... but what headlights have you owned to compare the Camry ones to? I'm intrigued. For the record, I love my LED DRLs.
Subjective tastes and sentiments aside, it's a matter of Optics.. Actinology scientists and professionals will chime in and offer their perspectives as well. @Diode Dynamics want to offer some insights? I know ya'll recently did an LED/Halo/HID comparison for Low beams in the FR-S/BRZ stock housings using industry standard testing equipment. This will not be completely true to the case at hand because it is not an LED housing, but still it offers some cool perspectives and findings.
Old 02-19-2015, 02:38 PM   #56
torqdork
torqdork's Avatar
Drives: RV-7
Lexus IS and LS HID's, Toyota Prius HID's, Toyota Camry/Highlander/4Runner/Tundra/Sequoia/Land Cruiser/FJ Cruiser incandescents and projectors, Scion FR-S HID's.
Maybe it's the temp of the light, optics, reflectors, who knows, but on an unlit mountain road in rain spray I'm glad to have LED's.
I won't count mega off-road driving lights since they're illegal on road.
But when you say "watt for watt", don't LED's use less power for a given light output? If so, would equivalent wattage LED/HID bulbs still favor HID's?
Turn signal lights whip Cosmetic Modification (Interior/Exterior/Lighting) 13 02-26-2015 10:45 PM
Is there another way to keep the turn signal lights on? DeadStar7 Scion FR-S / Toyota 86 GT86 General Forum 10 06-29-2014 10:43 PM
OEM fog lights to turn on with parking lights subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 7 02-27-2014 06:41 AM
WTB FR-S Turn Signal Lights retrosmiths Want-To-Buy Requests 2 01-08-2014 02:13 PM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
