Drives: '15 Hot Lava FRS
Help! My lights won't turn off!
Tried new hyper flash relay and led switchbacks front turn- now I have a loud beep and all my lights will not shut off -- tried everything -- original relay is back in and even took it out
Help. Disconnected Battery. reconnected. headlights will not turn on. thinks high beams are on. and all of the lights are on. blinkers will not work either. checked fuses. nada.
No one!? Fuck !!!!
Drives: 2015 Scion FR-S Firestorm
Sounds like a blown fuse. Probably nothing major, but you should contact your local dealership. I had a similar situation happen to me where the high beams stayed on, beeping in car as if I left my lights on, automatic shifting wouldn't work (had to lift the manual override thing, not sure what it's called), and I think that was all. Turned out to be like $50 or so to fix. Dropped it off at night and got it back early next morning.
Yes! I am stranded by myself with no ride lol. Headlights now won't turn on yet every other light stays on !!! Ugh !!!!
Drives: Toyota GT86 Coupe Red (UK)
Is there not a lesson here somewhere?
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
Drives: 92 Integra
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
Did your braces hit a wire when you were doing the install? That might have shorted something out.
#10 |
#11 |
#12 |
On a more serious note - I know you changed the relay back but did you pull the leds?
Did you check the fuses under the hood (some people don't know they are there)? Trying to think of what it could be but hard to do without seeing it.
#13 | |
tow truck guy and my 4 friends were helpful too. but we are all clueless -- pulled and checked all fuses. even put original relay back on. with relay even off it thinks high beams are on -- blinkers will not blink anymore but just stay on as running lights -- side markers and tails and gauge cluster all stay on as well. but funny thing -- low and high beams won't power on anymore (hence why i had to tow it since I couldnt drive home). it was about to drain the battery since it won't shut off. i pulled and put NEW fuses in even. only thing i can think of is the aftermarket hyperblink relay + switchback leds shorted something and now the car's electrical is freaking. i do have HID -- i took them off and put stock back on -- still nada. let it sit with battery disconnected --- it would then be fine but as soon as i started the car again --- same, the alert alarm beep like i left the lights on and tried locking it and walking away and not being able to turn on low beams. |
#14 |
Strange. Wonder if something messed with the ECU.
Well good luck!
| Turn signal lights | whip | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 02-26-2015 10:45 PM |
| Is there another way to keep the turn signal lights on? | DeadStar7 | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-29-2014 10:43 PM |
| OEM fog lights to turn on with parking lights | subiestyle | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 02-27-2014 06:41 AM |
| WTB FR-S Turn Signal Lights | retrosmiths | Want-To-Buy Requests | 2 | 01-08-2014 02:13 PM |
| Turn signal lights | Brzer | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-18-2012 01:36 PM |
