#15 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Having camber adjustment on the track/twisty setup would be a distinct advantage, so I will be getting adjustable top hats for the front suspension of that setup. Adjustable top hats have the advantage of being lockable, with bolts that tighten down to lock the camber settings, and they don't affect the toe angle as much as adjustable camber bolts, so I won't need to realign when I switch back to the comfortable setup. As far as the cost of alignment goes, I have a place that aligns all 4 wheels for only $40, and they'll do it my way. I can tell them how many degrees I want, and where. I usually have them align the front perfectly straight and the back with .05 degrees of toe angle on each side. When I have adjustable top hats I'll include -1 degree of camber. That's a better alignment then you'll get from a dealer, and a lot cheaper too.
#16 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#17 |
Drives: 86 GTS
#18 | |
Drives: Firestorm 2013 FR-S
... but had never actually tried what should work on paper and found that it works in reality. I am no stranger to sports cars, but the stock suspension on my '13 FRS is too stiff--- I don't need to feel every 2mm change in the pavement. So I'm glad someone found an inexpensive way to soften the ride a bit.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
#19 |
Because compromise ®
Drives: Red Herring
You have purchased a sports car expecting a limousine ride?
| The Following User Says Thank You to Captain Snooze For This Useful Post: | evan (01-27-2015) |
#20 |
I see you have nothing but sports cars in your garage. I bet your FR-S has the worst ride of all of them. Try changing the rear springs to BRZ rears and get back to me. You'll be surprised how much more oversteer you get just by softening the rear springs.
The surprising thing is that both Subaru and Toyota screwed it up in opposite ways. I made a set of soft coilovers with OEM springs and struts, and a set of firm coilovers with Bilstein HD struts, just by combining FR-S and BRZ stock springs. FR-S front and BRZ rear = soft, BRZ front and FR-S rear = firm. I think the best ride is going to come from a dual rate adjustable coilover with stiffer helper springs. I've just redesigned my HKS hypermax gt iv's by swapping the front with the rear springs. I setup the helper spring preload so there is 1/2" of helper travel before the upper spring begins to compress. If it works out, this is going to be my fair-weather setup, so I'll be swapping to that after I switch out my tires to summer tires. |
| The Following User Says Thank You to KoolBRZ For This Useful Post: | phobos512 (01-29-2015) |
#21 |
Junior
Drives: a car
so your assuming that helper-spring swapping is going to do more than the adjustability of the damping?
#22 | |
Drives: Red Herring
http://www.americanmuscle.com/overst...explained.html "If the car understeers a lot, fit a bigger rear sway-bar." http://www.autospeed.com/cms/article...igans&A=112694 " Increasing the proportion of roll stiffness at the rear axle will have the opposite effect and decrease understeer." https://en.wikipedia.org/wiki/Anti-roll_bar "The following steps can be taken to decrease oversteer:... softer rear springs" http://www.nsxprime.com/FAQ/Track/highperfdriving.htm "Understeer Corrections....Stiffer rear springs" http://www.clarks-garage.com/shop-manual/susp-15.htm "Reducing understeer by adjusting spring rate Increase rear spring rate - this will increase the rear roll resistance which will reduce understeer but increase oversteer." http://www.pugaddicts.co.uk/2014/04/...adjusting.html
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Sideways&Smiling (03-13-2015) |
#23 | |
Junior
Drives: a car
OP, just curious, did you at all calculate the stiffness needed to be at ideal critical damping? (Roughly 65%~+/-2%) as stated in one of the links Snooze quoted, did you find the roll center? Where is it located and how well does it respond to a change of spring stiffness outside of that crit zone? The thought of softer rates is logical since you figure, oh going into the corner harder will give me more travel on the spring right? While that is correct, it won't improve oversteer, stiffer springs won't let the car's weight transfer as 'completely' as softer springs, thus kicking the tail out easier/more/faster you name it.
#24 | |
Softer springs in back let the tracking rods do their job better. The more the rear of the car leans, the further the tracking rods adjust the wheel's camber and toe angles. That is why a BRZ has more oversteer than the FR-S, because the rearend leans farther in corners. |
#25 | |
Drives: FRS RS 1.0
trollolololol ![]() i hope... lol |
#26 | |
Drives: Red Herring
Last edited by Captain Snooze; 01-27-2015 at 12:31 AM. Reason: grammer correction |
| The Following User Says Thank You to Captain Snooze For This Useful Post: | cdrazic93 (01-26-2015) |
#27 |
Drives: 2013 Firestorm FRS
do any of you guys have an issue with your car being becoming fwd if you go in reverse really fast?
| The Following 5 Users Say Thank You to continuecrushing For This Useful Post: | Apoc (01-26-2015), CSG Mike (01-27-2015), evan (01-27-2015), Tcoat (03-11-2015), themajesticone (01-26-2015) |
#28 | |
Junior
Drives: a car
Pobst: "I like the Subaru better, primarily because it's less loose on entry. In the Scion, you feel the back move almost before the front. In the Subaru, it's more one piece. And I can be more aggressive entering turns with the Subaru. It's a decreasing maneuver -- I'm entering on the brakes and cornering -- and because the Subaru isn't as tail-happy, I can use more brakes entering the corner and carry more speed in. It's the same thing coming off the corner. The Subaru doesn't oversteer as easily, so I can get to the power sooner." Lago: "The BRZ seems a bit slower to transition from understeer to oversteer than the FR-S. It stays neutral longer, where the FR-S switches quickly back and forth. I was able to hold the BRZ right in that space between the two extremes longer, and I like that extra stability." You're inclined to disagree with them, but I hope you know that you're just flat out wrong. Randy Pobst's opinion > yours.
| Tags |
| #derpology, #spidermanthread, letthisthreaddieplease |
| BRZ suspension sucks! | KoolBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 118 | 12-24-2014 10:54 AM |
| Well this sucks. | Dave-ROR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 11-16-2014 10:18 PM |
| Getting OLD kinda sucks... | blackhawkdown | Off-Topic Lounge [WARNING: NO POLITICS] | 44 | 06-13-2014 10:41 AM |
| NY sucks | Hardrock4445 | Off-Topic Lounge [WARNING: NO POLITICS] | 35 | 01-18-2013 09:28 AM |
