Old 12-25-2014, 03:06 PM   #1
KoolBRZ
KoolBRZ's Avatar
BRZ or FR-S suspension sucks, but put them together...
I've been trying to get a decent ride out of this car ever since I got it. I recently drove an FR-S automatic to compare to my BRZ automatic and was surprised how smooth the ride was. So I got a used set of FR-S suspension for $80.
By mixing and matching struts and springs up, by trial and error, I've found that the BRZ suspension does a porpoise-like bounce over bumps, with the front end bouncing up pushing the back end down so it is already compressed by the time it hits the bump, while the FR-S suspension soaks up the bumps in front, then mule-kicks with the rear.
My goal is to find the least expensive way to get a decent ride out of this car, you know, good enough to drink piping hot coffee in, while driving, without sacrificing handling or cornering ability. Well, you can have one or the other, but you can't have both. So, here are my setups.
I have found that the most comfortable ride is by using the FR-S struts and springs in front, and the BRZ struts and springs in back, with the stock rear sway bar, and softer 225/45/17 tires. However, that won't help you much on the track, or in the twisty's.
My track/twisty setup is BRZ front/FR-S rear struts and springs, a 19mm aftermarket rear sway bar, and 215/45/17 Michelin PSS2's. This yields guite a decent ride on the track, or in the twisty's. Bilstein HD struts also work better with this setup, since they are too firm, in my opinion, for the comfortable setup, but firm up the track setup just right, no more bunny hops over the bumps.
In conclusion, I've created two setups, one for street, and one track/twisty's, without spending too much money on them. I have the comfortable setup, FR-S front/BRZ rear struts and springs, stock rear sway bar, and 225/45/17 summer tires, and I have the BRZ front/FR-S rear struts/springs, 19mm rear sway bar, and 215/45/17 Michelin PSS2 tires for a track/twisty setup.
Old 12-25-2014, 05:12 PM   #2
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
Congratulations you've discovered that the FR-S' softer front springs give a smoother ride than the BRZ's fronts coupled with the BRZ's softer rear springs.
Then your track setup you put the stiffer BRZ springs back in front and FR-S' stiffer springs in rear for a stiffer track biased setup.
Kotu100 is offline   Reply With Quote
The Following 6 Users Say Thank You to Kotu100 For This Useful Post:
BlueDubbinTDI (12-25-2014), Creole (12-28-2014), enjoi23 (01-26-2015), finch1750 (12-25-2014), kiichiro (12-26-2014), Teseo (12-26-2014)
Old 12-25-2014, 06:31 PM   #3
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
laughed pretty hard at this because i find it a spot on description lol
FiRStsc10n is offline   Reply With Quote
The Following 3 Users Say Thank You to FiRStsc10n For This Useful Post:
eddieflyinv (03-12-2015), Kuri (01-27-2015), Teseo (12-26-2014)
Old 12-25-2014, 08:10 PM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I was hoping this thread would disappear without comment.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
continuecrushing (01-26-2015), s0sl0w (03-25-2015)
Old 12-25-2014, 09:07 PM   #5
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
This dude spent a long time typing out what 9/10 of us already knew
Old 12-25-2014, 10:00 PM   #6
Poodles
Drives: 2015 Series.Blue
2015 fixed these issues...
Old 12-25-2014, 10:03 PM   #7
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
The Subaru and Scion shocks and struts are identical. Only the springs are different because of spring rate.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
phobos512 (12-26-2014)
Old 12-25-2014, 10:32 PM   #8
Captain Snooze
Drives: Red Herring
I am suggesting 99.99% of owners don't read this forum and are content with the way their car drives. They don't push,street race or go to the track. The op was not happy with his stock set up. I appreciate that but I don't think he speaks for the majority of owners.
Old 12-25-2014, 10:41 PM   #9
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
I figured someone eventually would think this was a good idea.
I did it the other way around, like over a year ago, and kind of miss it... The soft route is probably strange, might be fun with a lift kit though.
Kostamojen is offline   Reply With Quote
Old 12-25-2014, 10:50 PM   #10
Burrcold
Drives: Subaru BRZ Limited
Stupid question but are the stock alignment settings the same for the FRS and BRZ? If they are different, what settings would you dial in with this set up?
Old 12-26-2014, 12:07 AM   #11
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Can a vendor with a spring rate tester chine in with and proof?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 12-26-2014, 01:18 AM   #12
Digitalanalog
Drives: '13 BRZ Limited, '95 BMW M3
That's a whole lotta alignments you're going to buy/get done weekly
Digitalanalog is offline   Reply With Quote
The Following User Says Thank You to Digitalanalog For This Useful Post:
Captain Snooze (12-26-2014)
Old 12-26-2014, 08:46 AM   #13
Burrcold
And this is what I'm wondering about.
The Following User Says Thank You to Burrcold For This Useful Post:
Digitalanalog (12-26-2014)
Old 12-26-2014, 10:21 AM   #14
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Mystery wheel alignment. You read about it here first.
Fizz is offline   Reply With Quote
The Following 2 Users Say Thank You to Fizz For This Useful Post:
Captain Snooze (12-26-2014), Digitalanalog (12-26-2014)
#derpology, #spidermanthread, letthisthreaddieplease
BRZ suspension sucks! KoolBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 118 12-24-2014 10:54 AM
Well this sucks. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-16-2014 10:18 PM
Getting OLD kinda sucks... blackhawkdown Off-Topic Lounge [WARNING: NO POLITICS] 44 06-13-2014 10:41 AM
NY sucks Hardrock4445 Off-Topic Lounge [WARNING: NO POLITICS] 35 01-18-2013 09:28 AM
