Old 01-24-2015, 07:15 PM   #407
RelentlessGT
Drives: Toyota GT86 Manual
Hi dj2020.
These oil regulators are used on the WRX STIs (turbo) and the Forester Turbo Diesels so I think the regulator probably does enough heat transfer. The question is whether the radiator can dispel that much heat. The answer is that you should try it and see. Get a cheap OBD2 reader and log the results to see if it is working (and hopefully publish them here for other people).
A good trick is as soon as you have finished driving hard turn on the Air Conditioner as it will engage both the radiator fans and you will be able to dispel much more heat whilst moving slowly.
Cheers
RelentlessGT is offline   Reply With Quote
Old 01-24-2015, 08:16 PM   #408
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Kraftwerks supercharger with upgraded radiator and mishimoto thermostat. Coolant temp sits at 170ish F with oil sitting at 185F. I will do more testing when I get time. I hope the lower opening temp will allow the radiator to stop a run away oil temp.
post_break is offline   Reply With Quote
Old 01-27-2015, 03:42 PM   #409
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Anyone here running this cooler via the throttle body lines? Have you noticed any improvements in keeping temps down? Logic says the oem way will be better as the TB lines are too small, but I'm trying to gather more reviews to see how the "easy" setup compares to the oem setup in terms of overall performance.
Fizz is offline   Reply With Quote
Old 01-27-2015, 03:52 PM   #410
Koa
bruh the vid http://www.ft86club.com/forums/showthread.php?t=73684
I have one installed and ran to the TB lines.. here's a 3rd log- http://datazap.me/u/koa/3rd-pull-stg...t86sfv2-012516
otemps don't veer past 215 even after 10-15mins of 3/4 load runs
The Following User Says Thank You to Koa For This Useful Post:
Fizz (01-27-2015)
Old 02-09-2015, 01:00 PM   #411
post_break
post_break's Avatar
This oil cooler operates better with a lower temp thermostat as bigger radiator as expected. The oil temps are 15F higher than coolant temps on average and the cooler coolant temps are able to bring oil temps down. Now I don't know if there is a runaway if oil temps get too high, but I will have to test on the highway soon.
Ambient temps were 75F, this is city driving.
The Following 4 Users Say Thank You to post_break For This Useful Post:
Koa (02-09-2015), lightdir (02-14-2015), SPCorBUST (02-09-2015), tigermack (02-10-2015)
Old 02-13-2015, 12:46 AM   #412
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Logs via TB method in Winter. I back off for a lap when I see 248/120. So once running that means 1 hot lap, one slow lap, repeat.
http://datazap.me/u/wayne/206-stg2-u...g=0&data=1-8-9
http://datazap.me/u/wayne/206-stg2-u...=0&data=1-9-10
https://www.youtube.com/playlist?lis...4xRVvvU-lG8xlG
For AT owners, consider simply plumbing the cooler in series before the ATF heat exchanger (on the water side of course), or just the TB. It's better than nothing. No T fittings either way. Obviously the lines are much longer from down near the ATF HE, so the pressure won't be great.
I have an air/ATF cooler in series on the oil side, before the ATF HE.
Don't go deleting the ATF HE (tempting). It's does barely any cooling, it's mostly for warming the AT up faster (important).
Don't waste money on a huge, expensive radiator for NA when t-stat is barely open, unless you log 203F/95C.
Don't get a lower temp t-stat and dropping your coolant temp below what the engineers designed for the block.
The good news for lower t-stat is it looks like the ECU gives you full timing above 140F, but that would need to be tested and logged.
Old 02-14-2015, 06:09 PM   #413
smwerner19
Drives: 13 BRZ
So, what's the difference between these two? 14050AA970 OR 14050AB090 - PIPE, WATER
smwerner19 is offline   Reply With Quote
Old 02-15-2015, 02:10 PM   #414
CARNZ
CHECK ENGINE
Drives: 2004 STi
AB090 was a substitute for AA970 because of huge backorders when this was initially written. Since then, supply of the AA970 pipe has been consistent, I left the AB090 pipe up there for reference.
AA970 = early 2014 FXT, AB090 = late 2014-present FXT
They should be basically the same pipe, I've looked at newer FXTs and haven't noticed a difference.
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 02-15-2015, 05:57 PM   #415
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Any updates in potential alternative parts now that the 2015 WRX has been out for a while?
mit_peid is offline   Reply With Quote
Old 02-15-2015, 06:56 PM   #416
Kostamojen
Its the same as the Forester.
Old 02-17-2015, 10:38 AM   #417
was385
Drives: MT WRB BRZ Limited, 2007 911s
I didn't see this in the thread, but would a local auto parts store have the generic 3/8" and 1/2" heater hose? Anywhere I see it online, the shipping is as much or more than the actual parts.
was385 is offline   Reply With Quote
Old 02-17-2015, 11:05 AM   #418
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Would have really loved to use this upgrade but i can't as the allen fitting sits right where the turbo's oil return passes by. Looks like im stuck with the cusco for triple the price. Unless anyone knows of any alternatives
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-17-2015, 01:01 PM   #419
nunonuna
nunonuna's Avatar
You can replicate Cusco kit.
That is what I did. I even spent less money than OEM kit.
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
yomny (02-17-2015)
Old 02-17-2015, 01:39 PM   #420
yomny
yomny's Avatar
Care to elaborate, any specific couplins to connect the coolant hoses, banjo bolts?
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
