Old 01-21-2015, 04:25 AM   #1
slyder
Drives: FR-SLIDN Blue FRS
Check engine, can OFT tune help?
So I'm not sure if this topic has been covered I tried to search couldn't really find the exact answer I was looking for. So I recnet installed skunk 2 headers and put a defouler and now I have a check engine light popping up. I've heard sometimes the lights still Pop up with a defouler and the only true way to get rid of the light is to get a tune. Now I heard ecutek tune can solve this but I was wondering can the Open Flash Tablet get rid of my check engine light with there tune for my car. I'm running an injen intake, skunk 2 catless headers EL, and Takeda catback exhaust as far as engine mods. Any help and input will be greatly appreciated thank you.
slyder is offline   Reply With Quote
Old 01-21-2015, 04:43 AM   #2
steve99
Drives: FT86
short answer yes
the check engine light is a result of the ecu testing cat efficiency and finding its below spec as it no longer exists, 02 spacers or defoulers attempt to fool ecu they dont work all the time.
all you rearly need is to disable the ecu checking for cat cefficiency cel code P 0420.
it would be possible to do this on stock tune if you had an appropiate flashing device.
a tune for catless headers will not only disable the cel code P0420 , but also adjust the fueling ignition and intake and exhaust cxam timings to take advantage of your better flowing header.
catless header without a tune will yeild maybe 8 hp where with a tune it will be arround 20 hp at wheels.
similar results will be achieved with oft tune ecutek tune or most competent tuners.
the injen intake will require the maf sensor to be rescaled for best results.
see links below for more info
The Following 3 Users Say Thank You to steve99 For This Useful Post:
Boofneenee (01-21-2015), chas3wba0 (01-21-2015), Robert@Openflash (01-23-2015)
Old 01-21-2015, 05:54 PM   #3
Tromatic
Carista and a [ame="http://www.amazon.com/ScanTool-427201-OBDLink-Bluetooth-Diagnostic/dp/B00H9S71LW/ref=sr_1_6/176-5415704-0172611?s=automotive&ie=UTF8&qid=1421880706&sr=1-6&keywords=obd2+bluetooth"]dongle[/ame] will also clear CEL's.
I have that dongle, works great with anything but a Crapple product because they don't like standard protocols.
Old 01-21-2015, 07:12 PM   #4
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Your crazy for running all those mods and no tune. Not safe and your car must drive like garbage.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 01-21-2015, 07:56 PM   #5
Tromatic
Shhhh! Want pics of blowed-up-real-good car. And decals on same.
Old 01-22-2015, 06:42 AM   #6
slyder
Too bad. Nobody is gonna have pics of that because I just bought the OFT haha lol. But I will post pics of it sitting pretty on my wheels if you like
Old 01-22-2015, 07:37 AM   #7
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Once you flash stage 2 your going to smack your forehead for not getting the OFT long time ago. You are going to need to adjust your MAF scale to compensate for your CAI. Pay the extra $200 for custom tune or, even better, cheaper put your stock intake back on and sell that CAI to some other shmuck who thinks it makes power.
FRS
The Following 4 Users Say Thank You to Boofneenee For This Useful Post:
JB86'd (01-22-2015), Shiv@Openflash (01-24-2015), slyder (01-22-2015), Thedishdoc (03-26-2019)
Old 01-24-2015, 11:10 AM   #8
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
The injen intake doesn't flow air to the MAF sensor well and causes inconsistent readings from the MAF. The ECU uses the MAF to determine how much fuel to add to the air coming in. Inconsistent MAF makes inconsistent AFR. The stock air box with a drop in and a intake tube is you best intake for N/A. For you I think the OFT or a professional tune is your best bet. OFT if you want the flexibility to flash back a forth between stock and what every tunes OFT has or if you just want a professional tuner to set it and forget it to go fast.
Toyota John is offline   Reply With Quote
The Following User Says Thank You to Toyota John For This Useful Post:
Old 01-24-2015, 12:07 PM   #9
BlackMonarch
Drives: Red BRZ
Not to thread jack, but I'm also about to purchase an OFT, and I was curious... I'll be running a full TopSpeed exhaust (UEL, downpipe, overpipe) as well as my FA20Club CAI. Is this what would be considered "stage 2" on the OFT base tunes?
BlackMonarch is offline   Reply With Quote
Old 01-24-2015, 12:23 PM   #10
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I would ditch the fa20 club intake and run our stage 2 UEL OTS map. The intake will require custom tuning since it interferes with MAF readings and ultimately doesn't improve engine performance.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Old 01-24-2015, 03:11 PM   #11
BlackMonarch
Drives: Red BRZ
Curious though, and I'll run a search, but wouldn't I be throwing a CEL if it was causing a MAF misread? None so far.
Old 01-24-2015, 04:05 PM   #12
Shiv@Openflash
Drives: 2013 FRS
Nope. It would take a huge MAF misreading error to cause a MAF related CEL. But only a very small misreading to have a significant effect on open loop fueling.
BlackMonarch (01-24-2015)
Old 01-20-2021, 09:20 PM   #13
Deathghat
Deathghat's Avatar
Drives: 92 civic, 13 brz
Hey Shiv, if I have a full catless exhaust, and install a drop in air filter instead of a CAI, should I go Stage 2+ OTS map? I’m gonna get Tomei UEL, Tomei Over pipe, Invidia Front pipe and have a Borla Catback.
Deathghat is offline   Reply With Quote
Old 01-22-2021, 06:55 PM   #14
czellers
czellers's Avatar
Drives: 2K19 GT86
Its just a header and intake... I'd bet the vast majority of cars across all makes/models with those mods (since they're very common and affordable) don't have any custom or OTS tune. Im not saying what you said is right or wrong, just seems a bit over the top..
Also, its "You're crazy..."
czellers is offline   Reply With Quote
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Can someone check their engine for me? Carlitoz3 Issues | Warranty | Recalls / TSB 13 04-10-2014 03:10 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Check engine light? czar07 AUSTRALIA 0 09-01-2012 02:50 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
