Old 01-19-2015, 09:07 PM   #2843
FirestormFRS
The ease of installing this kit is ridiculous...I mean really I could give my girls the instructions and they could have it done in one day.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
Chad86 (01-19-2015)
Old 01-19-2015, 11:21 PM   #2844
SPCorBUST
SPCorBUST's Avatar
Originally Posted by vgi View Post
awesome! i'm curious how much whp my car would've made on that dynopack.
i think that's the highest yet i have ever seen for a c30, both whp and tq.
dynapack's are inflated, so they don't seem that high adjusted to dynojet:
10% adjustment
295 * .9 = 265.5whp (the blog post)
315 * .9 = 283.5whp (the more recently tuned vehicle)
8% adjustment
295 * .92 = 271.4whp (the blog post)
315 * .92 = 289.8whp (the more recently tuned vehicle)
Seems like you could reach 300whp w/ 94 and a few other mods either way though.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
vgi (01-20-2015)
Old 01-19-2015, 11:29 PM   #2845
SPCorBUST
SPCorBUST's Avatar
Originally Posted by digital_assassin View Post
I just installed Perrin mounts yesterday. Haven't drove the car yet but just sitting in the garage I watched the engine and blipped the throttle and no movement. With the stock mounts the engine moved a ton.
Get a chance to drive it? Curious about the nvh, have been thinking about purchasing those.
Old 01-19-2015, 11:45 PM   #2846
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Is it $1500 to upgrade to the C38 down the line? Whereas, at time of purchase it is only an extra $200 to upgrade the blower.
Chad86 is offline   Reply With Quote
Old 01-19-2015, 11:56 PM   #2847
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
People will tell you they melt, but I've had them on mine for about 6-7k miles and no melting signs. The only problem was the engine was vibrating my oil cooler loose. A bit of lock tight will cure that next time I get the bumper off. At a stop light it vibrates but it smoothes out at above 1500 rpms.
Freeman is offline   Reply With Quote
The Following 2 Users Say Thank You to Freeman For This Useful Post:
digital_assassin (01-20-2015), SPCorBUST (01-20-2015)
Old 01-20-2015, 12:01 AM   #2848
SPCorBUST
SPCorBUST's Avatar
In post #2600 and #2601 I confirmed with KW that it would be around $1140 outside of any tax or shipping for an upgrade.
On a different note, looking at that dyno chart again it actually crosses 300whp (dynapack). They probably have a good reason but I wonder why they didn't take that number instead of the 296whp. It does seem like you might be able to get 300whp (dynojet) with bolt-ons and an aggressive tune, but maybe not much more. (barring e85)
Old 01-20-2015, 12:12 AM   #2849
vgi
Drives: frs
there is some, it's not that bad although i have my idle at 900
vgi is offline   Reply With Quote
Old 01-20-2015, 01:31 AM   #2850
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Like the others said, mine too is a bit rough down at low RPM's. Once it hits about 900 RPM the vibrations stop.
digital_assassin is offline   Reply With Quote
Old 01-20-2015, 10:03 AM   #2851
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
This is why I suggested the group N mounts. No vibrations even at stock idle rpm.
post_break is offline   Reply With Quote
The Following User Says Thank You to post_break For This Useful Post:
Old 01-20-2015, 01:19 PM   #2852
themajesticone
themajesticone's Avatar
Drives: '13 UM86
This kit comes with a C30 option right as described here: http://cms.kraftwerksusa.com/id/950/...harger-System/
However, on this page, where you would place the order I assume, they don't show a C30 option or am I blind? http://store.kraftwerksusa.com/super...t-compact.html
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 01-20-2015, 01:27 PM   #2853
Freeman
Freeman's Avatar
Kraftwerks Supercharger Owners Thread
Looking at it, the labeling scheme seems to be, unless otherwise stated as a C38 kit the kit is a C30. Once you click on a kit the discription will tell you if its a C30 or C38.
Example PN: 150-12-1306B states it's a C38 kit while PN: 150-12-1301B just says black housing with tuning, but once you click on the link and read the product description it's says "Kraftwerks is pleased to announce the release of a brand new intercooled supercharger system for the new Subaru BRZ and Scion FR-S. At the heart of the new system is the Rotrex C30-94, which is the same supercharger used in the extremely successful Kraftwerks 2006-2013 Honda Civic Si system."
The Following User Says Thank You to Freeman For This Useful Post:
themajesticone (01-20-2015)
Old 01-20-2015, 02:15 PM   #2854
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
I don't think "inflated" is the correct word to use, Reads higher yes, i would even say more accurate as the wheels and tires do not play a part in the numbers like they can on a roller. But the wording inflated, is like saying a engine dyno is inflated. they read higher for a reason. same car with just a wheel change can read 15-20 hp different going from new tires and heavy stock wheel to a smaller light wheel and tire set up over inflated. I wish everyone used Hub Dyno's. I know that's not what you were talking about on purpose, but i cant stand when people claim Dynapacks are junk, or over rated, or over inflated. they read different because your taking 60-70 lbs of rotational mass out of the equation.
-Thomas
86SPEED is offline   Reply With Quote
The Following 2 Users Say Thank You to 86SPEED For This Useful Post:
CSG Mike (01-20-2015), SPCorBUST (01-20-2015)
Old 01-20-2015, 03:14 PM   #2855
SPCorBUST
SPCorBUST's Avatar
-Thomas
You're right, inflated is not correct here - reads higher is better.
I'm not knocking the dyno, it has it's virtues, just explaining that those numbers aren't as spectacular as they seem because they come from dynos known to read about ten percent higher across the board. In terms of relative scale (accounting for reading higher) the numbers are average.
86SPEED (01-20-2015)
Old 01-20-2015, 04:18 PM   #2856
themajesticone
Drives: '13 UM86
Thanks man - I was on my phone looking at this stuff so it wasn't as convenient to click around from page to page.
The Following User Says Thank You to themajesticone For This Useful Post:
Freeman (01-20-2015)
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
