Old 01-15-2015, 11:23 AM   #2619
kbon
Drives: 2015 Scion FR-S
I'm currently considering to get 18x9.0 with a 40 offset or 18x9.5 with a 43 offset. Both setups would be square and they would be wrapped around in 245/35 tires. I'm lowered on TRD springs. Would I have any issues with either setup? Thanks
kbon is offline   Reply With Quote
Old 01-16-2015, 02:20 PM   #2620
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by PollosHermanos View Post
Stock suspension I'm going to be buying 17'' x 7.5'' et35 with a 225/45/17 tire.
According to will they fit I should be poking 19 mm/.75 in more than stock. No plans to lower the car, but I'd like to get the fitment more flush. I think I'd be more or less there with this set-up. Agree/disagree?
Another question for the experts here - will I have issues with a wider tire like a 235 and would that be a poor choice for a 7.5'' wheel? I do autox some but no track and no plans for FI or a tremendous power upgrade other than maybe an OFT.
Thanks in advance
I think you have a good offset there with this wheel size. If you lower the car, this wheel will work well also.
For a 7.5" wide wheel, I would suggest going with a 225/45R17. You could also use a 235, but they will more expensive and only you will be able to tell the difference at quick glance.
If you do auto-x, you might consider an 8" wide wheel (around +35 offset) with a 245/40R17 tire if that keeps you within the rules.
Slick is offline   Reply With Quote
Old 01-16-2015, 02:27 PM   #2621
Slick
Slick's Avatar
Originally Posted by FrSnake View Post
255/35/18 w/18x9.5 +45 on stock suspension.. most likely doing 10mm spacers; just checking in to see if they'd rub or not.
This is pretty wide for a stock suspension setup. You will poke and also rub on the inside. The 10mm spacers will just give you more poke.
These would fit well if you were lowered and on coilovers:
  • extra tuck from the camber due to the lowering
  • additional inside clearance from the coilovers
Look through the wheel directory here:
http://www.ft86club.com/forums/showthread.php?t=7535
and compare others running the same wheel or a different wheel with the same specs. You'll find that most people running 18x9.5 are running a +38 offset and probably everyone is running coilovers.
Old 01-16-2015, 03:13 PM   #2622
Slick
Slick's Avatar
Originally Posted by krimsonmedic View Post
Will 255/40/18 on 18/8.5 motegi m116 +35 fit without rubbing on stock height. If not what would be the widest? would I need to drop down to a shorter wall height?
On a 8.5" wheel, you could fit a 255, but if you're stock you would be better with a 245/35R18 or a 235/40R18 (less common size). 225/40R18 will also fit but a bit of a stretch.
Old 01-16-2015, 03:16 PM   #2623
Slick
Slick's Avatar
Originally Posted by SilverBullet86Z View Post
Hey guys, I'm looking to get Rays 57DR wheels 17x9.0 with 235/40/17 tires, my car is lowered on eibach pro kit. Will I need to get camber bolts or it would fit just fine with enough clearance?
Thanks!!
+35 or +38 offset?
These should work with the ProKit, you shouldn't need the camber bolts but you'll gain a bit of camber with them which will help them tuck in a bit more (less poke).
Old 01-16-2015, 03:22 PM   #2624
Slick
Slick's Avatar
Originally Posted by SpeedFromSwede View Post
Would a staggered setup of Enkei Raijin's (18x8.5 front, 18x9.5 rear with 235/45 in front and 265/35 in the rear) work on stock suspension or with just lowering springs? Both have a +45 offset I think.
With this staggered setup you may be okay.
You may find you need small spacers to clear inside once you lower (depending how much).
CHeck out the wheel directory here:
and compare the different setups on Raijins.
Here is someone running your combo but looks lowered.
http://www.ft86club.com/forums/showthread.php?t=21697
Old 01-17-2015, 10:48 AM   #2625
SilverBullet86Z
SilverBullet86Z's Avatar
Drives: '14 Subaru BRZ Sport-Tech SSM
Originally Posted by Slick View Post
+35 or +38 offset?
Thanks! I was deciding on that but I think it might be a +38 offset
SilverBullet86Z is offline   Reply With Quote
Old 01-18-2015, 12:11 AM   #2626
FrSnake
Resident Noob
FrSnake's Avatar
Drives: Satin White BRZ Limited
Originally Posted by FrSnake 255/35/18 w/18x9.5 +45 on stock suspension.. most likely doing 10mm spacers; just checking in to see if they'd rub or not.
So the spacers won't make any difference? would going down to 245/35/18 make any difference with the rub? Sorry for all the questions..
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust
“Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson
FrSnake is offline   Reply With Quote
Old 01-18-2015, 03:30 PM   #2627
Slick
Slick's Avatar
These are way too wide for stock suspension.
Pretty much anything up front wider than 9" will rub on coils or stock suspension.
If you fit these, the wheels will contact the spring perch, plus the tires will rub on the outer fender lip.
To make these fit you need to go to coilovers. You will gain extra inside clearance from the smaller suspension components and then, will need extra camber to make sure the outside of the tire doesn't rub, probably somewhere around -2.5 to -3.0 all around.
Read this thread for more info:
http://www.ft86club.com/forums/showthread.php?t=35463
Your options are:
  • get coilovers first and then run these wheels
  • go down to a 8.5 to 9" wheel max, especially on the front where the fitment is a problem. (8.5F/9.5R staggered should work nicely)
Old 01-18-2015, 05:18 PM   #2628
Agent 86
Drives: 2017 Cayman S
Not speaking as an authority, but yes it will work (based on my experience).
I installed a similar setup (exact wheels sizes) (tires: 245/35 & 265/35) about a week ago and on stock suspension I'm clear in the rear, and have roughly 5mm clearance in the front. After 150 + miles no rubbing even at full lock.
My RCE Yellow springs are scheduled to arrive tomorrow. According to RCE, the fitment should remain good. However, Myles says that installing crash bolts will reduce clearance further.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 01-22-2015, 05:40 PM   #2629
FRSBeginner
Drives: Asphalt FR-S 2013
I'm planning on getting ag f440 in 19 x 8.5(front) and 9.5 (rear).
They're custom so I got to choose an offset!
Any recommendations?
I'm looking to flush to fender
FRSBeginner is offline   Reply With Quote
Old 01-24-2015, 02:38 AM   #2630
blindjoker
Drives: FRS
Will this fit? (width, offset and tire size Qs)
I'm trying to buy wheels (looking at the works emotion or the rota torque, depends which one is easier to buy) on my country. but can't decide on the offset. What will be the best offset and tire for 17x9 square setup on stock (trd springs) without any poke. I want a flush or a bit inside the fenders setup. Thanks.
blindjoker is offline   Reply With Quote
Old 01-25-2015, 01:03 AM   #2631
KenN
Drives: Subaru BRZ
Can someone tell me which set up is more flush:
18x7.5 +38 front, 18x8.75 +33 rear like fellow member ericmpena or just 18x8.75 all round. And if 18x8.75 all around should I go for offset +33 or +35.
I'm running Eibach Pro Kit. Wheels I'm considering is the XXR 530.
Also what's the best tyre size, I currently have 225/40 front and 245/35 rear, can I reuse these tyres? Thanks!
KenN is offline   Reply With Quote
Old 01-28-2015, 11:35 PM   #2632
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
wanted to get the rpf1 for tracking my car. i was thinking of getting a 17x9 and running either a 235/35 or 245/35 tire and plan on getting a BBK in the future. I currently have kw v3 coilovers and camber plates.
ExxelDistributions is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
