Old 01-09-2015, 01:10 PM   #2605
Shiro86
Shiro86's Avatar
I know that the search function exists so please just tell me the answer if you know it. It takes the same amount of effort as telling me to use the search function. Thank you.
What tires will fit with no rubbing on Enkei NT03s, +40, on a car dropped on Tein S-Tech springs?
Gracias.
It's MS. Chanandler Bong!
Shiro86 is offline   Reply With Quote
Old 01-09-2015, 01:27 PM   #2606
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Gracias.
What size wheels? What offset?
Are you already dropped on those springs? Camber settings?
But I will still tell you to use the search, best way is to look below at the wheel directory and your particular wheel to see what others are using.
http://www.ft86club.com/forums/showthread.php?t=7535
It's already stickied in this forum category...
Slick is offline   Reply With Quote
Old 01-09-2015, 01:53 PM   #2607
Slick
Slick's Avatar
Originally Posted by VakaGT View Post
Would 18x9.75 +20 fit in the rear!?
I have a feeling it won't but I really want to run staggered
18x8.75 +33 in front
And
18x9.75 +20 in rear
I'm about to buy in a few days, but if it'll rub. And cause issues I guess I'll get 8.75 +33 all around
Lowered on sportlines about 1.5 inches
Edit:
225/40/18 front
245/40/18 rear
I think
Will poke quite a bit without extra camber. I'd stick to the square setup as it will also be easier to rotate and maximize the life of your tires.
Go with a 245/35R18 series, not 40-series as it is too tall.
Old 01-09-2015, 01:58 PM   #2608
Slick
Slick's Avatar
Originally Posted by jaw_knee View Post
I'm considering the following square set up: 18x9 ET +33. I'm going to lower the car an 1" to 1.5" with some ST Coilovers, and will also be installing rear LCA and, if need be, front camber bolts. So my questions are:
1. Do you guys think 235/40/18 tire would be okay or should i do a 245/40?
2. Would i have to run an excessive negative camber to have a flush appearance?
Thanks
Good wheel setup.
I'd recommend front camber bolts to gain a bit of extra camber up front. You will probably be okay in the rear though without LCAs as you will gain the camber you need just from your drop. 1-1.5" drop in the rear will bring you to around -2 camber or a tad more.
As per above post, run a 245/35R18, not a 40. You could even fit a 255/35R18 in there since you will have extra clearance inside with the coilovers. (I'd start with 245/35 first and see)
Old 01-09-2015, 02:01 PM   #2609
jaw_knee
Drives: 2014 Scion FR-S Raven
Originally Posted by Slick View Post
Good wheel setup.
Thanks Slick!
jaw_knee is offline   Reply With Quote
Old 01-09-2015, 02:04 PM   #2610
Slick
Slick's Avatar
Originally Posted by Defuser View Post
I am putting 17 x 9 et 42 wheels (OZ Formula HLT) on, I have Eibach Pro springs on.
Questions:
Will I need spacers and/or camber bolts? I've read about 1.325 million posts regarding similar situations, but haven't found an answer.
What tire size would you guys recommend? Tire Rack recommends 245/40, but I'd rather hear from people who drive these cars.
Thanks in advance!
With this setup, you will be very close to or touching the spring perch with the tire.
This wheel size/offset works on stock suspension, but as you lower, your inside clearance shrinks.
Camber bolts will make it worse (closer to the perch).
I would recommend 5mm spacers to start, which should give you enough clearance and will still work with stock studs (enough wheel stud engagement).
Or, if you didn't get the wheels yet, go for something closer to a +35 to +38 offset.
Old 01-09-2015, 05:11 PM   #2611
VakaGT
VakaGT's Avatar
Drives: None
Can I use 225/40/18? For a kind of stretch look
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Old 01-09-2015, 06:34 PM   #2612
Slick
Slick's Avatar
225/40R18 is a good OEM diameter.
Old 01-11-2015, 10:01 AM   #2613
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
Thanks Slick, I went ahead and ordered 5mm spacers for the front, and 12mm spacers for the back. Won't be perfectly even, but close. Will effectively change the offset to +37 in front and +30 in the rear. Perfect would be +48 and +38 according to the "flush" chart, but I don't mind a bit of poke.
This is my 17th car. Most fun so far!
Defuser is offline   Reply With Quote
Old 01-11-2015, 06:49 PM   #2614
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
Stock suspension I'm going to be buying 17'' x 7.5'' et35 with a 225/45/17 tire.
According to will they fit I should be poking 19 mm/.75 in more than stock. No plans to lower the car, but I'd like to get the fitment more flush. I think I'd be more or less there with this set-up. Agree/disagree?
Another question for the experts here - will I have issues with a wider tire like a 235 and would that be a poor choice for a 7.5'' wheel? I do autox some but no track and no plans for FI or a tremendous power upgrade other than maybe an OFT.
Thanks in advance
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 01-12-2015, 04:57 AM   #2615
FrSnake
Resident Noob
FrSnake's Avatar
Drives: Satin White BRZ Limited
255/35/18 w/18x9.5 +45 on stock suspension.. most likely doing 10mm spacers; just checking in to see if they'd rub or not.
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust
“Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson
FrSnake is offline   Reply With Quote
Old 01-12-2015, 08:40 AM   #2616
krimsonmedic
Drives: 2013 Scion Frs.
Will 255/40/18 on 18/8.5 motegi m116 +35 fit without rubbing on stock height. If not what would be the widest? would I need to drop down to a shorter wall height?
krimsonmedic is offline   Reply With Quote
Old 01-12-2015, 11:31 AM   #2617
SilverBullet86Z
SilverBullet86Z's Avatar
Drives: '14 Subaru BRZ Sport-Tech SSM
Hey guys, I'm looking to get Rays 57DR wheels 17x9.0 with 235/40/17 tires, my car is lowered on eibach pro kit. Will I need to get camber bolts or it would fit just fine with enough clearance?
Thanks!!
SilverBullet86Z is offline   Reply With Quote
Old 01-14-2015, 10:25 PM   #2618
SpeedFromSwede
SpeedFromSwede's Avatar
Drives: WRB BRZ
Would a staggered setup of Enkei Raijin's (18x8.5 front, 18x9.5 rear with 235/45 in front and 265/35 in the rear) work on stock suspension or with just lowering springs? Both have a +45 offset I think.
SpeedFromSwede is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
