Old 01-15-2015, 09:02 PM   #43
Originally Posted by Pkush View Post
I get a clunk sound every time I clutch in or out, regardless if its in gear or neutral. Could that be a sign of a problem or is that normal?
That does not sound normal. Do you feel it in the clutch pedal as well?
Old 01-15-2015, 09:05 PM   #44
Pkush
it feels like it's the clunk right when i get to the biting point either on the way in or out, wouldn't say that I feel it in the pedal
Pkush is offline   Reply With Quote
Old 01-15-2015, 09:08 PM   #45
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Is this what you're hearing?
Post #13 has a video. My car makes the same sound (My post is #17).
Old 01-15-2015, 10:29 PM   #46
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
My throw out bearing exploded at 43k. Replaced the clutch assembly with an exedy stg2 clutch. The stock clutch assembly was still in good shape and had a lot of life left when it was removed.
JDKane527 is offline   Reply With Quote
Old 01-16-2015, 01:30 AM   #47
Pkush
I just tried and can't reproduce it...but mine was different though, quieter I think
Old 01-16-2015, 08:36 AM   #48
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Petro, your car is fine, don't worry about it lol
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 01-17-2015, 12:43 AM   #49
Ozzman
Drives: old
Have any of y'all with burnt up throw out bearings, experienced any strange honking noises while shifting prior to the bearing failure?
Ozzman is offline   Reply With Quote
Old 01-19-2015, 09:59 AM   #50
arbnpx
Originally Posted by Shutter View Post
the new clutch has a new/different throw out bearing, right?
Yes; you can see it in the bag above the clutch disc: the throwout bearing (huge bearing, about 2.5" in diameter), the pilot bearing (small bearing), and an alignment tool.
arbnpx is offline   Reply With Quote
Old 01-19-2015, 11:43 AM   #51
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
will the aftermarket ones have the same issue as stock? Melting anyway...
Old 08-17-2015, 05:33 PM   #52
In this post, @LavosTRD explains it pretty well. At 15Kmi I am just now starting to feel an occasional little rumble in my clutch pedal as I depress it. With so much free play in the races coupled with a sloppy plastic guide, I can picture the rotating race sag and make contact with the pressure plate off-center. Is that the rumble I feel? Hmmm...
I suspect this is the beginning of the death march.
Old 08-17-2015, 07:21 PM   #53
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I wish I had one of you forum members/toyota techs at my dealership. Life would be much easier. I'm hoping I didn't get an 86 with the bad rocker arms.
Intent > Content
Old 08-17-2015, 07:48 PM   #54
Meh, life's too short but I sympathize. Then again, if everyone gave a shit, I wouldn't be nearly so appreciated at my work.
Old 08-18-2015, 09:11 AM   #55
solidONE
solidONE's Avatar
Yeah or if there weren't these dismissive jackasses that think they know everything, trolling people every chance they get. Knowledgeable honest folks/techs are hard to come by.
Intent > Content
Old 08-19-2015, 10:03 AM   #56
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
There is not a bad batch of rocker arms. The reason they are failing are because they are losing oil pressure to them at higher rpm and they spit out. On toyotas other motor where I have seen it happen it harmlessly falls into a void in the cylinder head. But because of our boxer engine, gravity decides to give us the royal middle finger and blow shit up.
LavosTRD is offline   Reply With Quote
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
Muffler delete on track (melted bumper?) celica73 Tracking / Autocross / HPDE / Drifting 12 04-01-2014 04:27 PM
Thrust Bearing Going Out >(559)< FR-s Issues | Warranty | Recalls / TSB 22 06-19-2013 08:23 PM
bearing identification paraguin Other Vehicles & General Automotive Discussions 7 04-16-2013 10:18 AM
Blown wheel bearing =( silverbullet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-23-2013 10:34 PM
