Old 01-15-2015, 08:32 AM   #71
GT86_PRAGUE
Drives: GT86
Originally Posted by AJPG View Post
This will be interesting
If you are running a bicycle (road bike or mountain bike it doesn't matter) and you couldn't go up hill then down shift does it give you more power???
More like mechanical advantage I think.
Anyway I'm with the 4.88 since it release (more than one year I think) and I love it, also due to my short commute and frequent back road use I couldn't stop thinking on how it will behave with a 5.1
Congrats on your mod and enjoy
AT or 6MT?
So you would go for extra 5% from 5.1?
GT86_PRAGUE is offline   Reply With Quote
Old 01-15-2015, 09:06 AM   #72
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Originally Posted by KoolBRZ View Post
I got my 4.88 FD parts today. They were sent to Maryland by mistake, so they got here today instead of Monday. I'm leaving my car with Wryann of VIP performance in Portland OR. tomorrow at 9:00 AM. I'm also going to ask for before and after dyno runs in 4th gear to estimate the comparative power increase. I'll be giving feedback this weekend after I've driven it a bit. I think this is going to be the best improvement I've bought for my car.
Say hi to Wryann for me.
Lunatic is offline   Reply With Quote
Old 01-15-2015, 12:13 PM   #73
AJPG
Drives: 22RE, FA20, 4G63
Originally Posted by GT86_PRAGUE View Post
AT or 6MT?
AT + FI
AJPG is offline   Reply With Quote
Old 01-15-2015, 03:38 PM   #74
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
You won't get more hp per se but you should get more torque. I think that's what he's talking about
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
Old 01-15-2015, 04:44 PM   #75
AJPG
Ok
Will see with the before and after dyno
But the thing is mechanical advantage.
And I really believe this is one of the best mods for the AT.
The Following 2 Users Say Thank You to AJPG For This Useful Post:
el-92 (12-07-2015), fatalelement (01-16-2015)
Old 01-16-2015, 02:08 PM   #76
fatalelement
Ok
I agree. The 0-60 changes a lot. I'm planning to do 4.88 sometime in the near future.
Old 01-20-2015, 06:58 AM   #77
AJPG
Hi
Any dyno info to share?
How do you like it?
Old 01-20-2015, 01:37 PM   #78
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
I want this but everyone tells me that my highway mpg will suck a lot and that my top speed will also be a lot less and that my powerband will shift so ill have no top end torque
904FRSlow is offline   Reply With Quote
Old 01-20-2015, 01:39 PM   #79
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Hi
How do you like it?
Still waiting for install. All goes well I'll be picking it up today. If there's enough time Wryann will put it on the dyno for a before and after comparison. Depending on the compensation within the dyno, there might or might not be any difference. I wish I'd thought to get torque app before and after readings. That would definitely show a difference.
I might need to undo the changes I made to my DBW tables, since the engine will pull the short-shifts better, now that the final drive has given the engine more leverage.
KoolBRZ is offline   Reply With Quote
Old 01-20-2015, 03:17 PM   #80
kodyo
Drives: Scion FR-S
It will not shift the powerband, it's essentially a torque multiplyer. Torque will be higher over all gears and the whole RPM range. It will make your top speed less, say 130 mph instead of 145. It will affect gas mileage, but not a ton. It really only affects highway mileage for me (that's when I actually run out of gears to reduce RPM), and not very much (2-3 mpg maybe).
kodyo is offline   Reply With Quote
Old 02-07-2015, 04:54 AM   #81
AJPG
WAT?
It's is simple, lest not complicate things more than they are. OK?
If you change your FD (final drive) you have done nothing to the engine so expect NO change in power, however with a higher FD your car could pull each gear more easily. (Like now (FD 4.88) my car pull 4th gear as it was 3rd gear with the 4.1 final drive) and get to 114mph at red line
MPGs...
If you have good manner with your right foot you should have good MPGs "on full auto mode" but if you change the FD and enjoy the new found desire for acceleration (from the car) then bye MPGs. Even better buy an intake and some tune then go enjoy your car and forget about MPGs this weekend!
Old 02-07-2015, 11:44 PM   #82
KoolBRZ
KoolBRZ's Avatar
My Final Drive is finally installed and works great! Every A/T FR-S or BRZ or GT86 owner should get their FD changed to 4.875 immediately. This is the way it should have come stock off the showroom floor. I have to be a lot more careful not to spin my tires now. I was tired of ****** city mileage and being left behind by econocars and minivans at every stop. I had to give it so much gas just to keep up, then slow down after it hit 3rd gear. I needed a lower 1st and 2nd gear to give me an easier launch. This 4.875 FD does just what I wanted.
The dyno results don't show it though. I got tired of waiting and removed the insert of my Skunk2 intake, going from 2.75" to about 3.25". My MAF tuning skills are lacking however, the dyno showed I'd lost about 18HP and 15ft lbs of torque. So when I got home I put the insert back in and loaded an old tune for the insert. Wow, what a difference! Snow tires plus wet pavement = sideways. I'm going to have to put back on my PSS2's, at least in the rear, to keep it on the road. I can just tap the throttle and spin both back tires now.
The Following 4 Users Say Thank You to KoolBRZ For This Useful Post:
AJPG (02-08-2015), drewbot (05-19-2015), kevaughan (06-19-2024), Lonewolf (02-08-2015)
Old 02-08-2015, 01:41 AM   #83
Lunatic
Lunatic's Avatar
Glad you like your new gears. I love mine.
Old 02-08-2015, 06:20 AM   #84
AJPG
Thanks for sharing your opinion on the FD.
But I have to ask for a couple of thinks:
1. Please keep the car on the road! Lol
2. After a couple of gas tanks share your MPGs (at first they will suck, but you will be so fvcking happy that you won't care).
3. Be careful! After such a successful mod there is a chance that you became addicted!
It won't stop!!!
4. It is Sunday
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
CUSCO 4.55 FINAL DRIVE installed. Racecomp Engineering Engine, Exhaust, Transmission 488 06-17-2018 12:14 AM
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 10:18 PM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
Anyone w/ 3.727/3.909 Final Drive Post Boost? Staf00 Engine, Exhaust, Transmission 12 05-02-2013 08:38 PM
