Old 01-11-2015, 10:21 PM   #29
BRZlimited
BRZlimited's Avatar
Drives: 2013 Subaru BRZ limited
Sorry to revive an old thread but this is something I always wondered. If we add distilled water to our batteries wouldn't that freeze if the car was sitting during the winter?
BRZlimited is offline   Reply With Quote
Old 01-12-2015, 08:18 AM   #30
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Had two occasions in two weeks when the battery died. Car was sitting out in 20F weather without being driven. Guess I will just call Subi Roadside assistance each time this happens until they decide to put a real battery in it under warranty.
ntron1 is offline   Reply With Quote
Old 01-13-2015, 04:42 PM   #31
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Water in a battery is a sulfuric acid / water mix.
High acid = charged. Higher water ratio = discharged.
The acid mix has a much lower freezing point than distilled water alone.
The battery won't freeze even if discharged to the point that it won't crank.
It's not all water in there even at that point.
Old 01-13-2015, 09:03 PM   #32
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I left my car in garage with dome light on for like 2 or 3 day then battery is dead.
It is pretty weak I guess?
Old 01-13-2015, 09:07 PM   #33
Fastbrew
Drives: 2014 Pearl White BRZ
Doesn't sound right. I think that dome will cut off after 20 minutes.
http://www.joomag.com/magazine/subar...10946?page=257
Fastbrew is offline   Reply With Quote
Old 01-14-2015, 01:25 PM   #34
Foobar
SLO NO MO
Foobar's Avatar
Only when switch is on door mode. If you manually turn it on, it kills the battery. Happened to me in the JFK long term parking. Bleh.
Old 01-14-2015, 01:38 PM   #35
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Wait, what do you mean it's "dead"?
-Jack Burton
Old 01-22-2015, 12:48 AM   #36
quackman
Drives: 2014 WRB BRZ manual
Yeah, only shuts off the headlights.
The trunk button got pushed while in my pocket one evening just after I got mine.
Next day the battery was flattened by the trunk light.
It recovered with a battery tender and is still working fine today.
THANK YOU for posting this! I was so confused about why my battery was dead today even though I just drove it two days ago (and for quite a while that day). I went to my car and the trunk "opened" fine while I put some stuff in it.... but then the door wouldn't unlock, nor start, and the lights wouldn't work. I try opening the trunk again and it's not opening (I have keyless access). I chalked that up to "Oh, I guess I was able to open the trunk fine the first time bc that was the battery's last breath before dying." But, nope: it's because it wasn't fully closed from when I last used the car, which was to get groceries!
I close my trunk by pushing on the license plate to avoid touching the paint (it's failed to close properly at least once before, and the door-open light let me know after driving off a few minutes later). But now that I know the trunk's light can kill the battery if it's not closed properly.... I'll be touching my paint by closing the trunk normally--pushing straight down from the top.
quackman is offline   Reply With Quote
Old 01-22-2015, 03:11 PM   #37
Poodles
Drives: 2015 Series.Blue
Normal for any car...
Old 02-08-2015, 11:18 PM   #38
taiguy
Drives: 2013 Black BRZ Limited
So I finally got this taken care of. It was a tremendous amount of frustration and effort for what was just a dead battery. The subaru dealership wanted the entire car to be brought in, not just the battery. Subaru roadside assistance sent the wrong tow truck twice (our cars need wheel lifts and dollies). I did learn that keyless entry is nice until your battery dies and locks the steering column with it.
Finally the dealership sent a tech out with a new battery and we got the battery swapped and then drove the car along with both batteries to the dealership for testing.
At first they wanted to blame the dead battery on my audio amp. A quick test and some easy deduction showed that not to be the case. However, they were still stumped because the parasitic draw was over 100mA while most other cars in the shop (imprezas, forester, etc.) were around 30mA.
They called Subaru up. Subaru said we don't have a spec for the BRZ but pointed the tech to a published guideline of less than 70mA. After enough fuse pulling they tested a showroom BRZ and it was drawing 150mA. They deemed my 120mA to be "under spec" according to this and ended up replacing the battery.
The lesson here is our cars seem to draw significantly more current than other vehicles while off. If you're going to leave it for the winter, it's best to put the battery on a float charger. I now have a pigtail running out the hood into the garage to keep things topped off.
Here's the official write up.
taiguy is offline   Reply With Quote
Old 02-10-2015, 12:21 AM   #39
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Not sure if your battery draw would qualify it for this TSB but it sounds like it:
Service Bulletin # 07-85-14
Bulletin Description: This bulletin will provide the proper procedure for measuring Dark Current (parasitic battery draw) along with the specification for maximum allowable limits. Customer concerns of batteries going dead over a period of time should be diagnosed using this procedure once any obvious contributing factors have been eliminated.
Got this from the following website: http://techinfo.subaru.com/search/index.html
Search Technical Service Bulletins. Unfortunately, the pdf requires a login/subscription to get the full pdf for the TSB.
PWBRZ is offline   Reply With Quote
Old 02-11-2015, 12:02 PM   #40
Turbowned
Turbowned's Avatar
I lefte mine for a couple weeks in a heated garage and it went dead. I brought it to work to charge and the smart charger apparently indicated a bad battery. I have to wait til Spring to get the car out of storage and warranty the battery.
Old 02-11-2015, 12:10 PM   #41
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I left my dome light on by accident for about 3 days in ~30 degree weather. Came back and battery wouldn't carry a load according to Autozone. Had the Toyota dealership warranty it and they gave me a different Toyota battery instead of the OEM one in the car.
Car was ~8 mo. old.
Jyn is offline   Reply With Quote
Old 02-11-2015, 01:55 PM   #42
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
stock battery is kinda suck. mine went out. no click whatsoever! i brought autozone to recharge it but they said they cannot. stupid autozone guy doenst know shiiiit sometimes.
i bought a battery charger and charged it myself at home and car started right up.
just drive or idle for 10-15 min per 3 days or 4 days.
Dead battery; starts up in limp mode kilrb Issues | Warranty | Recalls / TSB 15 01-04-2018 02:54 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Is there any know that how to open the truck when the battery is dead?????? wilson0326 Scion FR-S / Toyota 86 GT86 General Forum 31 07-06-2013 09:24 PM
Dead Battery BUT Honk Horn and it Turns on Car ScionFR-S Issues | Warranty | Recalls / TSB 9 06-11-2013 02:47 PM
Ignorance and a dead battery Red John Issues | Warranty | Recalls / TSB 9 03-02-2013 01:29 PM
