Old 06-07-2013, 09:15 PM   #1
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Exclamation Dead Battery BUT Honk Horn and it Turns on Car
hey guys just wanted to know if this has happened to anyone else or if you may know what happened... so i turn on my car, well i try to at least, in the middle of this tropical storm NY is getting now and it doesnt work. the battery light just flashes and car doesnt do anything... the dome light does but thats about it. i try and use my remote start and just the radio, radar detector and light go on and then shut off... i then honk my horn and BOOM all the gauges go on and everything but still no ignition start... i then try and use my remote start again to turn on the car and it works. i shut off the car and then use my key to start it and NOW it works. WTF !! what do you think may have happened ? is this a problem and i should have it checked out ? the car is fine now thank sweet jesus
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 06-07-2013, 09:37 PM   #2
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
I would get it checked out.... Hope you don't some sort of network problems... Or rats...
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 06-07-2013, 10:28 PM   #3
cnk
Drives: '13 DGM BRZ Limited
Since you mention you have remote start, I would start by checking the wiring for that. Maybe a loose wire or bad module somewhere.
cnk is offline   Reply With Quote
Old 06-07-2013, 10:46 PM   #4
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
make sure your battery terminals are tight
LavosTRD is offline   Reply With Quote
Old 06-07-2013, 10:49 PM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Sounds like alarm issue causing the ignition cut. Check out the alarm wiring.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-10-2013, 11:14 AM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think what happened is you installed an aftermarket alarm. Personally, I think it is a problem and would have it removed versus just checked out.
Old 06-11-2013, 01:38 PM   #7
ScionFR-S
ScionFR-S's Avatar
the alarm was put on by the dealership... i have aftermarket stuff on the car but what would void the warranty of the alarm ?
Old 06-11-2013, 01:45 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I don't think that any of these items:
Automative Motion Bright White LED's on License Plate Dome Light and Trunk Light, HID_Powerhouse 6000K PlatinumR HID Kit, 20% Tint, Five Axis Spoiler
Would void the warrany on an aftermarket alarm.
Old 06-11-2013, 02:15 PM   #9
suaveflooder
It's your alarm. Mine acts up every once in awhile and kills my ignition. I pull the key back out, hit unlock (even though the car isn't unlocked) and it fires right up! Good luck!
suaveflooder is offline   Reply With Quote
Old 06-11-2013, 02:47 PM   #10
Razz
Razz's Avatar
Drives: Fast
Does not make a difference if dealer installed.
Check the Alarm.
Razz is offline   Reply With Quote
Beeping after ignition turns off.. chadstyle BRZ First-Gen (2012+) — General Topics 45 07-20-2020 01:53 PM
Moving in neutral....Engine turns off? deedz Issues | Warranty | Recalls / TSB 23 04-23-2013 09:23 PM
Ignorance and a dead battery Red John Issues | Warranty | Recalls / TSB 9 03-02-2013 01:29 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
FR-S: Highbeam turns on lowbeam, how to disable? civicdrivr Cosmetic Modification (Interior/Exterior/Lighting) 6 07-03-2012 07:08 PM
