Old 01-01-2015, 04:50 PM   #15
wparsons
wparsons's Avatar
Originally Posted by OmarGC View Post
2jzgte w/a very aggressive clutch/pressure plate is prone to crank walking eventually due to normal (dry) start and excessive pressure on the crank.
If depressing the clutch long enough to start it is going to hurt the engine, then so will shifting. You're far better off running a less aggressive clutch, or addressing the issue internally.
All that said, why not just wire up a different switch you can manually press instead of pushing in the clutch? Then you don't have to worry about what the ECU's will do thinking the clutch is constantly depressed.
flickr
OmarGC (01-01-2015)
Old 01-01-2015, 06:03 PM   #16
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Difference is far less lubrication across thrust/rod bearing surfaces when off/pressure applied vs. Running and surfaces being lubricated by the pickup. Again, this is about the bypass switch... don't expect to find a ton of jz knowledge/experience on the twin boards
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 01-01-2015, 06:43 PM   #17
wparsons
wparsons's Avatar
If you're already spending enough for the swap, why not go with a twin disc clutch and avoid the issue altogether? Better drivability too.
flickr
Old 01-01-2015, 07:18 PM   #18
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Define "enough" for the swap. Because I have less into this swap than most stock block fa20 turbo builds. Also, only twin disc for my future par setup is 14 weeks lead time
Omar GC
Instagram: 2jzus
Old 01-01-2015, 07:56 PM   #19
Dipstik-sportech
Dipstik-sportech's Avatar
What worries me is what will you do to trigger your launch control?
Old 01-01-2015, 08:22 PM   #20
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
No concern for LC, I don't drag race ^_^
Omar GC
Instagram: 2jzus
Old 01-01-2015, 09:41 PM   #21
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Works fine for me still. Nothing is different that I've noticed. It's been a few months
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
BRZ Nav Bypass lxsedan CANADA 43 03-30-2015 07:44 AM
Pressing/releasing clutch pedal - audible click sound (not the clutchs switch tanner BRZ First-Gen (2012+) — General Topics 26 06-03-2014 08:24 PM
Push-button start clutch switch mike the snake Engine, Exhaust, Transmission 8 04-14-2014 11:31 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
