#15 |
Drives: '14 BRZ
#16 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I've been looking at oil pans and baffling lately. Seems like its only needed in sustained high Gs but is also cheap insurance. I think that and pulleys would be the best things while the motor is out |
#17 | |
Drives: 13 BRZ WRB
Any idea what happened? |
#18 |
STX 188
Did you even read... it's in the first 2 posts after the OP...
| The Following User Says Thank You to tigermack For This Useful Post: | BlaineWasHere (12-03-2014) |
#19 | |
Grip>Drift
Drives: FRS
It's not in the budget because I'm buying a used motor but I think this will help the car a lot and maybe help avoid whatever happened to me!
#20 |
Which oil cooler is that with the shroud?
I did a RacerX oil pan and am still in STX. The windage tray is bolted to the block. I am not sure that Moroso baffle plate is legal. |
#21 |
Will that oil cooler shroud work on a BRZ? I just got an oil cooler and don't want to install in in front of my radiator and intercooler. I'd rather have it off to the side/sacrifice a fog light.
#22 |
Drives: '14 BRZ
#23 |
Grip>Drift
Drives: FRS
What's the best solution of the oil pan?
#24 |
Drives: '14 BRZ
Best solution is probably the RacerX pan. It has baffling, and adds 1L of capacity, helping with temps. Downside is you have to trim or remove stock header heat shield (fine in stx).
The Moroso is cheaper, works in the stock pan. Up to you, I think. Not sure who else makes them, yet.
#25 |
Drives: 13 BRZ WRB
So what is happening with the junk motor then?
#26 |
So elite I'm 1338
Drives: WRB Subaru BRZ
No motor is "junk".
I prefer to think of them as racing hondas in another dimension!
-Jack Burton |
#27 |
Its a Blitz cooler. Its overpriced but i like how it mounted and had metal braided lines cut to length with AN fittings already put on the hose. Moroso is sandwiched between the oil pan and block and doesn't modify anything so it should be legal.
#28 |
Drives: 17 Camaro SS
oh man! What happened? Glad you found a replacement so fast. Oil coolers are now ok for ST classes and thats awesome. If I had my engine out I would do that and an oil pan. Mounts also, why not?
| K2 Motor? | Ronin Sascha | Engine, Exhaust, Transmission | 8 | 08-16-2014 06:51 PM |
| Does every motor say #1 | sosick | Engine, Exhaust, Transmission | 21 | 05-05-2014 09:28 AM |
| anyone want a new FA20 motor?? | bacon_cheese_beer | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 10-07-2013 10:43 AM |
| Heubergers Motor | vho | User/Vendor/Sponsor Reviews, Feedback, Comments | 1 | 09-04-2013 09:42 PM |
| Motor swaps.. | Brian S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-19-2012 04:18 PM |
