Old 12-03-2014, 01:34 PM   #15
conedodging
conedodging's Avatar
Drives: '14 BRZ
Originally Posted by BlaineWasHere View Post
In our non-humid climate I don't think a oil cooler is needed for autoX IMO.
Speaking of, how are the temps at Crow's in April? Much cooler than June I hope?
conedodging is offline   Reply With Quote
Old 12-03-2014, 02:57 PM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yeah, should be mucb cooler. Here in the valley we get pretty big temps swings between seasons.
I've been looking at oil pans and baffling lately. Seems like its only needed in sustained high Gs but is also cheap insurance. I think that and pulleys would be the best things while the motor is out
Old 12-03-2014, 04:01 PM   #17
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
So I ended up popping my motor in my FR-S (I know FML!) so I am going to be dropping a lightly used motor in (my car has 80K miles on it).
Anyway I was thinking of doing a clutch for sure (which clutch?) while the motor is out but are there any other STX mods I should do while I have the motor out? Mounts? Baffled oil pan? Thanks for the help guys! Wish me better luck on the next motor!
Any idea what happened?
2superblus is offline   Reply With Quote
Old 12-03-2014, 04:53 PM   #18
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Did you even read... it's in the first 2 posts after the OP...
tigermack is offline   Reply With Quote
The Following User Says Thank You to tigermack For This Useful Post:
BlaineWasHere (12-03-2014)
Old 12-03-2014, 08:23 PM   #19
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Necessary? I wouldn't know, I've only owned one for 4 months, and I'm just starting to dig deep in to STX prep.
BUT, it is a lot easier to do some of that stuff (oil pan) with a motor that is off the car. So if it's in budget, why not?
It's not in the budget because I'm buying a used motor but I think this will help the car a lot and maybe help avoid whatever happened to me!
Old 12-03-2014, 09:54 PM   #20
xwd
Which oil cooler is that with the shroud?
I did a RacerX oil pan and am still in STX. The windage tray is bolted to the block. I am not sure that Moroso baffle plate is legal.
Old 12-03-2014, 09:59 PM   #21
mike the snake
Will that oil cooler shroud work on a BRZ? I just got an oil cooler and don't want to install in in front of my radiator and intercooler. I'd rather have it off to the side/sacrifice a fog light.
Old 12-03-2014, 10:26 PM   #22
conedodging
Drives: '14 BRZ
I think the moroso bolts to the pan without any other modification... so, okay?
Old 12-03-2014, 10:39 PM   #23
BlaineWasHere
Grip>Drift
Drives: FRS
What's the best solution of the oil pan?
Old 12-04-2014, 10:58 AM   #24
conedodging
Drives: '14 BRZ
Best solution is probably the RacerX pan. It has baffling, and adds 1L of capacity, helping with temps. Downside is you have to trim or remove stock header heat shield (fine in stx).
The Moroso is cheaper, works in the stock pan. Up to you, I think. Not sure who else makes them, yet.
Old 12-04-2014, 04:00 PM   #25
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
So what is happening with the junk motor then?
Old 12-04-2014, 04:33 PM   #26
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
No motor is "junk".
I prefer to think of them as racing hondas in another dimension!
-Jack Burton
Old 12-09-2014, 05:38 PM   #27
xero404
Its a Blitz cooler. Its overpriced but i like how it mounted and had metal braided lines cut to length with AN fittings already put on the hose. Moroso is sandwiched between the oil pan and block and doesn't modify anything so it should be legal.
xero404 is offline   Reply With Quote
Old 12-11-2014, 02:39 PM   #28
APEXIT53
Drives: 17 Camaro SS
oh man! What happened? Glad you found a replacement so fast. Oil coolers are now ok for ST classes and thats awesome. If I had my engine out I would do that and an oil pan. Mounts also, why not?
APEXIT53 is offline   Reply With Quote
K2 Motor? Ronin Sascha Engine, Exhaust, Transmission 8 08-16-2014 06:51 PM
Does every motor say #1 sosick Engine, Exhaust, Transmission 21 05-05-2014 09:28 AM
anyone want a new FA20 motor?? bacon_cheese_beer Scion FR-S / Toyota 86 GT86 General Forum 22 10-07-2013 10:43 AM
Heubergers Motor vho User/Vendor/Sponsor Reviews, Feedback, Comments 1 09-04-2013 09:42 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
