Old 12-02-2014, 12:09 AM   #57
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Originally Posted by Grip Ronin View Post
I believe the fa20T is a bit tougher from the heavier weighted internals. FA20 pistons coming in at 311.2g, rods being 346.8g and cap at 112.3g.
The fa20T pistons being 360g, rods coming in at 370.9g and cap at 120.7g. As per Tomei not my own observations.
That's a good bit of info. I had no idea
Kronos is offline   Reply With Quote
Old 12-02-2014, 12:25 AM   #58
s2d4
s2d4's Avatar
Or is it because the NA needs higher/free rev response so they've done more engineering to shave the weight on the internals?
Old 12-02-2014, 01:04 PM   #59
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Its probably both. Less cost for less material too
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 12-05-2014, 06:35 PM   #60
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
Originally Posted by Reaper View Post
One of them is on stock tires too. Syncros failed.
Synchro failure has nothing to do with power or torque. Their sole purpose is to match gear speeds while shifting.
Caspeed is offline   Reply With Quote
Old 12-05-2014, 07:00 PM   #61
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Stock block C38 KW supercharger at 19 psi, should be over 400hp, it gets dyno next week.. should be because the other KW C38 was doing 408 at 16 psi and i easily pulled on him.. both on E85 he had over 10k miles until a meeting with a K barrier ended everything, im over 5k so far no issues
Thomas
86SPEED is offline   Reply With Quote
The Following 3 Users Say Thank You to 86SPEED For This Useful Post:
Dream20b (01-08-2015), Enders FRS (04-12-2015), hmong337 (12-06-2014)
Old 12-05-2014, 07:17 PM   #62
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Your barking up the wrong tree. I have a case open pending legal action right now about a failed syncro warranty claim that was denied because a dealer claimed it was because of hp. I'm fully aware hp doesn't kill syncros.
Old 12-06-2014, 09:44 AM   #63
Caspeed
Caspeed's Avatar
What is failing in the boxes that you have replaced?
Old 12-06-2014, 01:46 PM   #64
Reaper
Reaper's Avatar
Drives: violent
I either shear 4th gear, or a syncro goes out. I've seen/replaced transmissions in other cars for a sheared 4th gear and a worn out 5th syncro and a worn out 2nd gear syncro. Same problems as me/fullblown/element tuning/don/synack and the list goes on.
The Following User Says Thank You to Reaper For This Useful Post:
Bonburner (04-08-2015)
Old 12-06-2014, 01:48 PM   #65
Reaper
Reaper's Avatar
Drives: violent
I'm running an oil cooler now but I don't see temps hot enough for it to turn on.
Old 12-09-2014, 11:40 AM   #66
blown
Drives: ft86
http://www.synchrotech-transmissions..._Synchros.html
maybe these guys can make some synchros for our gearbox?
blown is offline   Reply With Quote
Old 12-09-2014, 01:39 PM   #67
Reaper
Reaper's Avatar
Drives: violent
You'll still shear 4th gear off
And most of those are single cone honda replacements. Hence why they don't make one for the ap1 triple cone. It would cost more then what I paid for a used transmission.
Old 12-09-2014, 03:37 PM   #68
Pkush
I would love to get an update on how that turns out!
Pkush is offline   Reply With Quote
Old 12-09-2014, 04:11 PM   #69
blown
Drives: ft86
how much wheel tq do you have?
Old 12-09-2014, 04:17 PM   #70
raven1231
build thread shows 379
WTB FA20 Stock Cross Want-To-Buy Requests 22 08-19-2014 02:59 PM
WTB FA20 Stock Cross Want-To-Buy Requests 1 08-01-2014 06:47 PM
Stock FA20/trans, never modified 9k miles ATM - April/May slicktop Engine, Exhaust, Bolt-Ons 2 02-24-2014 07:44 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
Stock AISSIN Transmission Power Capacity Don@Accelerated Forced Induction 37 07-03-2013 10:15 PM
