Old 12-08-2014, 08:16 PM   #1
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
Pop, loud whirring no power to the wheels
As of two days ago, as I was driving up my work place parking garage I hear a loud pop and lost power to the wheels.
The car starts no signs of leaking of smoke. But the car in neutral does make a whirring noise that coincides with engine rpm, ie low rpm low noise, high rpm loud noise. The car won't move and it seems it's coming from the rear right. Also the car won't move in gear, and to add the noise gets louder when in gear even tho the car is in complete stop.
Thanks. Oh and this happened on my birthday
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
mr. slim is offline   Reply With Quote
Old 12-08-2014, 08:31 PM   #2
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
MT or AT? Put the car jackstands. Look under the car and if there isn't anything obviously broken start it up and parking brake off and put it in gear (being very careful) look under the car. Is the driveshaft spinning? If yes, check the diff and axles. If no, your problem is the clutch or something in the trans.
Amaya is offline   Reply With Quote
The Following User Says Thank You to Amaya For This Useful Post:
mr. slim (12-08-2014)
Old 12-08-2014, 08:34 PM   #3
mr. slim
SoCal86
mr. slim's Avatar
I'll be doing that Wednesday, finals are a priority ATM
Thanks for the help
It's a MT
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
Old 12-08-2014, 08:39 PM   #4
Amaya
Amaya's Avatar
No problem. I'm curious to see what broke and why, I've heard the transmissions are a weak point on these cars. Is the car stock or are you pushing some extra power through it?
Old 12-08-2014, 08:40 PM   #5
mr. slim
SoCal86
mr. slim's Avatar
Oft/pulley/headers/drop-in/exhaust
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
Old 12-08-2014, 08:53 PM   #6
Amaya
Amaya's Avatar
Hmmm, maybe just over revved the clutch? Have you put the car in a lower gear than the engine could handle if you released the clutch? Like say your doing sixty coming up on a stop and you throw it in first with the clutch in without having slowed down much. My sister did that when she was first learning to drive, the clutch just exploded into tons of dust.
Note: the clutch doesn't always explode immediately, it can just be weakened enough that after a while it falls apart under normal driving.
Old 12-08-2014, 09:15 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Clutch/throwout bearing/flywheel assembly, or a busted input shaft on the transmission.
-alex
Old 12-08-2014, 09:22 PM   #8
mr. slim
SoCal86
mr. slim's Avatar
I was going up a helix. Lol
Uhh I clutch kick to induce a drift, so maybe?
Would it be covered by warranty??
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
Old 12-08-2014, 09:23 PM   #9
mr. slim
SoCal86
mr. slim's Avatar
-alex
Thanks hopefully I'll really know by Wednesday. What would the warranty cover from those you listed?
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
Old 12-08-2014, 11:31 PM   #10
mav1178
mav1178's Avatar
All or none, depending on what the dealership says.
You need a mod-friendly dealer, but it's hard to say what is broken until the car is on a lift and parts are taken apart.
-alex
Old 12-08-2014, 11:55 PM   #11
I'm going to guess the right side output shaft popped. Outer CV joint.
Old 12-09-2014, 01:38 AM   #12
mr. slim
SoCal86
mr. slim's Avatar
-alex
Cool thanks! Going to Longo Toyota
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
Old 12-09-2014, 06:54 PM   #13
Ozzman
Drives: old
I'm betting you broke an axle.
Ozzman is offline   Reply With Quote
The Following User Says Thank You to Ozzman For This Useful Post:
mr. slim (12-09-2014)
Old 12-09-2014, 07:00 PM   #14
stugray
Drives: 2013 GBS BRZ Limited
You dont even need to jack it up, just look under the rear while someone is trying to drive it forward in gear.
Bet is that one of the halfshafts is spinning because its broken at the outer joint.
perrin catback resonated - loud enough or too loud? theflathead Engine, Exhaust, Transmission 33 01-22-2018 05:46 PM
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
Whirring Noise When Shifting? Joe-G Issues | Warranty | Recalls / TSB 3 03-01-2015 01:23 AM
Something of a Whirring noise coming from resonance tube after trd intake install? Waffles Issues | Warranty | Recalls / TSB 4 03-15-2014 10:35 PM
Whirring/Whizzing/Whining from Interior Fan/Blower aghuman Issues | Warranty | Recalls / TSB 5 12-03-2013 10:23 PM
