Old 01-25-2014, 11:35 PM   #1
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
Whirring Noise When Shifting?
Has anyone else noticed this? I haven't had this happen to me in any other vehicle I've had, but it seems a bit pronounced on the FRS.
Shifting from 1-2, or 2-3 at speeds around 20-40km/h, I can hear a sort of metallic whirr while clutching in/disengaging from gear. It only lasts for that quick second after clutching out to shift gears.
Is that normal? Or am I hearing things?
Joe-G is offline   Reply With Quote
Old 01-26-2014, 01:13 AM   #2
Deathreaper
Drives: 2013 Scion FRS
Pretty sure that's the synchromesh. Mine also does it, doesn't seem to be an issue.
Deathreaper is offline   Reply With Quote
Old 03-03-2014, 08:41 PM   #3
JB86'd
JB86'd's Avatar
Drives: JAWS
I have the same thing..sounds like a mechanical whoosh..kinda metallic and harsh. Synchromesh was my first thought. It happens when I'm driving hard and shift quickly. Glad I'm not the only one.
Old 03-01-2015, 01:23 AM   #4
bottle
Old post but didn't want to start a new thread.
My issue is similar, but my conditions are a bit different.
The sound appears to be a result of the ECU holding the acceleration for a split second, causing the clutch to slip during disengagement. It does not happen when the car is cold (when the RPMs drop quickly). Also does not happen at high RPM since ECU also drops the revs quickly.
This happens for me when I shift below 4K rpm, most pronounced at 2K-2.5K, when the car is warmed up.
If I push in the clutch too quickly at 2-3K RPM (even after letting go of the accelerator completely) the RPMs may jump up slightly. I have to wait a millisecond or so at lower rpms to prevent this noise, which may result in a slight jerk as the engine braking commences.
Upshifting only, no issues on downshift. Does not happen if car is already engine braking.
To be clear, the sound is a result of the clutch pedal actuation (disengagement specifically), NOT the shift itself.
I figure this may just be a normal sound, but I haven't heard it before on other cars. Anyone else experiencing this?
bottle is offline   Reply With Quote
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
Abnormal noise when throttle blip or WOT shifting evo4g63 Issues | Warranty | Recalls / TSB 48 10-16-2014 08:42 AM
Noise during shifting caused by Acceleration Pedal jflogerzi Issues | Warranty | Recalls / TSB 8 10-10-2013 11:50 PM
A clunck noise when shifting jflogerzi Issues | Warranty | Recalls / TSB 3 09-09-2013 12:16 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
