Old 11-24-2014, 08:06 PM   #799
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Nice. I finally flashed to the Stage 1 91 octane after having my OFT sitting around unused for months. So far so good! Car definitely has noticeably stronger acceleration above 4k now!
One thing that was weird is that after the flash process when I turned the car back on, the door open indicator on the dash was lit, even though my doors were shut. I tried opening and shutting them again and the light stayed on, so I just drove for a bit, stopped and turned the car off, popped the trunk and then closed it and then closed the driver's door and the light went off. Strange.
Anyone know the ballpark # of miles I should expect to drive before the car "learns" the new tune?
Originally Posted by humfrz
I'm old and lazy
Old 11-24-2014, 08:16 PM   #800
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Did you follow the procedure for turning on your car after tuning? I noticed very little 'break in' time for my tune.
B-R-Z is offline   Reply With Quote
Old 11-24-2014, 08:29 PM   #801
Clipdat
Proud of BOXER
Clipdat's Avatar
I let it sit and idle for 30 seconds after turning the car back on, per the instructions here: http://openflashtablet.com/getting_started/
I'm old and lazy
Old 11-24-2014, 08:41 PM   #802
B-R-Z
B-R-Z's Avatar
There's another way that I used, I think steve99 posted it where you turn ignition on (not engine), let sit for 30 seconds, turn off, repeat, then turn on motor & let idle for x seconds. It's something like that but I don't remember specifics, search around you'll find it in one of the oft threads.. Or I'm sure someone will chime in here.
Old 11-24-2014, 08:45 PM   #803
tomaszjanczak
Drives: Silver Subaru BRZ
Steve99's method is to turn off ignition after a flash and then put it on position for 20 or so seconds, turn off, turn to on position for another 20 seconds then start engine and let it settle to normal idle RPM of 750 or so - ALL OF THIS WITHOUT TOUCHING THROTTLE PEDAL AT ALL.
This has always worked well for me.
tomaszjanczak is offline   Reply With Quote
The Following 2 Users Say Thank You to tomaszjanczak For This Useful Post:
B-R-Z (11-24-2014), Clipdat (11-25-2014)
Old 11-24-2014, 09:26 PM   #804
Clipdat
Proud of BOXER
Clipdat's Avatar
Cool, thanks guys. I'll try this tomorrow after I change my oil.
I'm old and lazy
Old 11-26-2014, 05:36 PM   #805
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Originally Posted by kidgogeta View Post
Thanks kinda agrees with what I''ve been reading, the car only had the pause the first time wot now its just the vvt
The tune Shiv did for the GrimmSpeed Intake def makes a lot of noise at 4k but I am slowly getting used to it. He said he could tone down that part of the tune but you would lose mid-range. I plan on a header soon so hopefully the sound will be more balanced and the torque/power should be better everywhere.I wonder if the stage 2 tune sound the same at 4k?
The orchestra is just not quite right yet...lol
F1fletch is offline   Reply With Quote
Old 11-26-2014, 06:42 PM   #806
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Stage 2 does not make the raspy noise since the header fills in that area of the torque dip and there's no reason to make the tune as aggressive. I certainly don't miss the rasp
Old 11-26-2014, 07:17 PM   #807
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
+1. I haven't noticed it at all since I installed the OFH and went stage 2
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 11-26-2014, 07:34 PM   #808
B-R-Z
B-R-Z's Avatar
+1. I have no rasp, 100% clean stage 2.
Old 11-26-2014, 09:46 PM   #809
Clipdat
Proud of BOXER
Clipdat's Avatar
Got a chance to log some miles on the tune today on some of my favorite driving roads. I planned a route that landed me at a gas station that offers fuels above 91 octane.
Wow, I thought that the car felt good with 91 in the tank - I was able to fit 4.5 gallons of 96 octane ($5.99/gal) in the car and this seemed to make it come alive even more. I guess this is because the reguar 91 still wasn't "enough" in a sense for the 91 tune.
Anyway, echoing what others have already said, but I'm loving the power below 4k now and I love that valve noise at 3.8-4k.
I'm old and lazy
Old 11-27-2014, 09:58 PM   #810
sirsol66
Drives: 2013 FRS- Hot Lava
Slightly strange situation: Stage 2 OFH+OFT (Not sure of exact version, purchased right before 2.0 was launched), stock otherwise. Car has been stage 2 for ~2 months now, no issues.
Yesterday leaving work I turned the car on and drove off the property (about 1/2 mile, 15mph cruising at little to no throttle); once I got on the main road accelerating about about 40-50% throttle the car had a hesitation right at ~2700rpm in 2nd, 3rd, and 4th gear. It didn't do it again after that very first time.
Tonight I drove the car home from the GF's parents house and again, it did the same thing but only in 2nd gear (couldn't feel it in 3rd or 4th). I'm going to try logging it next time to see, but anyone else experience this?
All I can think is that the car was very cold both of these times (all other times the car is stored in my heated garage, so it never gets driven with <30 degree starting), but again it has never done this before when stock. Thoughts?
sirsol66 is offline   Reply With Quote
Old 11-27-2014, 10:04 PM   #811
JB86'd
JB86'd's Avatar
Drives: JAWS
I bet the car is just cold. BUT you should flash the new version 2.0 tune and see if it does it again.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
sirsol66 (11-27-2014)
Old 11-27-2014, 10:09 PM   #812
sirsol66
That was my thought too, being an engineer I tend to overthink things (my GF reminds me of that everyday lol) so I'll just keep an eye on it.
Car is going away for winter anyways after this weekend when the salt starts flying, so I'll log it in the spring.
The Following User Says Thank You to sirsol66 For This Useful Post:
JB86'd (11-27-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
