Old 09-04-2014, 07:07 PM   #127
Originally Posted by stonenewt View Post
Ah, you see I learn about stuff. Get hold of the hard bits to make (eg. a turbo) then sit down to design an intake & exhaust manifold to get the thing to fit. Find a fabricators to make it. Then bolt it all together. Rough tune in on the road. Finally go to my local RR to get it all polished & enjoy for a while.
Problem is this tends to turn you into a nerd who does argue, sorry discuss, tolerances etc.
OK If that is the case I am back to being on your side!
Old 09-05-2014, 01:53 PM   #128
stonenewt
Drives: BMW 120d
Originally Posted by Ubersuber View Post
That wasn't a factory turbo I assume since Toyota supercharged that engine I had thought.
The naturally aspirated version of that engine was a screamer, didn't it rev to 8,000 or somewhere near there, from the factory?
Unless the dyno graph was adjusted differently than standard to show "true" torque that Toyota engine had lower peak torque than the BRZ. If I read correctly it also produced less power at 7,000 rpm than our Subie boxer, but that would be the 10% approx smaller displacement effect I expect.
Stock v's Turbo on the same dyno. No massive gains until the cam change, but once wound past 7000 the turbo & higher revving cam just rip the stock engine apart. That's exactly what I wanted because I normally ended up in the 7-7.5 thousand rpm range just as the car was straightened up.
stonenewt is offline   Reply With Quote
Old 11-26-2014, 01:11 PM   #129
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Didn't anyone notice that the Saab engine had a revolutionary hinged engine block? The cylinders and head would hinge out from the crankcase effectively lowering compression while retaining the same stroke and displacement. All they had to seal against was oil splash and crankcase pressure, so the seals didn't even have to be that stout. It's an ideal solution for an inline turbo, or super-charged engine, but not for the boxers, V4's, V6's, V8's, V10's, V12's, or V16's. In simple terms, it was actually lifting the top half of the engine up, on demand, and although the stroke and displacement remained the same, the compression ratio lowered because the pistons didn't rise as high up in the cylinders.
KoolBRZ is offline   Reply With Quote
Old 11-26-2014, 01:51 PM   #130
Defuser
Remember
Defuser's Avatar
Drives: 2015 Asphalt
Defuser is offline   Reply With Quote
Old 11-26-2014, 02:00 PM   #131
Dude...really.... Did you read any of this thread? Did you not notice that it degenerated to meaningless drivel? There was a reason for that! Then you felt the need to resurrect it?
Well at least Ubersurber can't start up on the topic again.
Dipstik-sportech (11-26-2014)
Old 11-26-2014, 06:30 PM   #132
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
It's a shame suberman has left the forum, I would love to see someone of his intellectual caliber argue this out with ubersuber.
jonboy99 is offline   Reply With Quote
Old 11-26-2014, 06:31 PM   #133
Dipstik-sportech
Dipstik-sportech's Avatar
U know they're the same person right.......
Old 11-26-2014, 06:42 PM   #134
Were the same person! Past tense I hope! Haven't seen a third person that I suspect is yet the same so far.
Old 11-26-2014, 07:31 PM   #135
jonboy99
jonboy99's Avatar
On my phone I read that as
We're the same person
Almost gave me a heart attack
The Following User Says Thank You to jonboy99 For This Useful Post:
Tcoat (11-26-2014)
Old 11-26-2014, 07:34 PM   #136
I am just about the total polar opposite of him!!!!
Old 11-26-2014, 07:38 PM   #137
jvincent
jvincent's Avatar
Most likely to be found in the suspension forum and winter tire threads.
Assuming he comes back, he won't be able to help himself and he will blow his cover, again.
The Following User Says Thank You to jvincent For This Useful Post:
Tcoat (11-26-2014)
Old 11-26-2014, 08:32 PM   #138
Dipstik-sportech
Well technically he's still out there somewhere so unless he met an untimely demise I'll stick with they are lol.
Old 11-26-2014, 08:33 PM   #139
Dipstik-sportech
Edit; I believe he's still on the subaru brzclub forum.....
Old 11-26-2014, 08:39 PM   #140
Good place for him/them.
Think we have stopped this thread from resurrecting any further yet?
Is there anybody brave enough to say "Oh, but the SAAB engine is blah, blah, blah, bullshit, bullshit, bullshit (insert massive drawing here)"?
uberstupid
Lug Nut Torque Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-30-2014 07:45 PM
Torque Pro sav AFRICA 33 08-27-2013 07:31 AM
500 hp & 550 lb/ft torque ? yes please LS13 Scion FR-S / Toyota 86 GT86 General Forum 3 06-17-2013 12:48 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 06:56 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
