Old 07-30-2014, 08:50 AM   #1
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Lug Nut Torque
I just got new APR extended wheel studs and Blox AL 7075 lug nuts from FT-86 Speed Factory. Neither cam with torque specs.
I called FT-86 and left a message, which they have not called back.
I e-mailed FT-86 and so far they have not replied to that either.
Anyone know what the torque should be using this combination with Enki RPF-1's?
Lunatic is offline   Reply With Quote
Old 07-30-2014, 09:24 AM   #2
jvincent
jvincent's Avatar
I can't see a reason why it wouldn't use the normal torque settings, 89 ft/lb.
Old 07-30-2014, 03:18 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yep, same as stock like Jvince said.
Old 07-30-2014, 03:44 PM   #4
wparsons
wparsons's Avatar
My Muteki lugs said 70-80ft/lbs, I went with 80.
Do both the BRZ and FRS list the stock torque spec as 89? I know lots of WRX's are as low as 72, and it's the same rotors/studs.
flickr
Old 07-30-2014, 03:57 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Factory spec is 89, I end up with around 80 usually without issue after many track events.
-alex
Old 07-30-2014, 03:59 PM   #6
Sportsguy83
Drives: Limited BRZ
I do 90
Old 07-30-2014, 07:45 PM   #7
Lunatic
Lunatic's Avatar
Sounds good to me, thank you all.
Torque Pro sav AFRICA 33 08-27-2013 07:31 AM
500 hp & 550 lb/ft torque ? yes please LS13 Scion FR-S / Toyota 86 GT86 General Forum 3 06-17-2013 12:48 PM
torque mrnibbs Scion FR-S / Toyota 86 GT86 General Forum 21 05-13-2013 09:37 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 06:56 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
