#127 | |
#128 | |
Drives: BMW 120d
![]() Stock v's Turbo on the same dyno. No massive gains until the cam change, but once wound past 7000 the turbo & higher revving cam just rip the stock engine apart. That's exactly what I wanted because I normally ended up in the 7-7.5 thousand rpm range just as the car was straightened up. |
#129 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Didn't anyone notice that the Saab engine had a revolutionary hinged engine block? The cylinders and head would hinge out from the crankcase effectively lowering compression while retaining the same stroke and displacement. All they had to seal against was oil splash and crankcase pressure, so the seals didn't even have to be that stout. It's an ideal solution for an inline turbo, or super-charged engine, but not for the boxers, V4's, V6's, V8's, V10's, V12's, or V16's. In simple terms, it was actually lifting the top half of the engine up, on demand, and although the stroke and displacement remained the same, the compression ratio lowered because the pistons didn't rise as high up in the cylinders.
#130 |
Remember
Drives: 2015 Asphalt
#131 | |
Well at least Ubersurber can't start up on the topic again.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dipstik-sportech (11-26-2014) |
#132 |
Drives: Black Panda BRZ
It's a shame suberman has left the forum, I would love to see someone of his intellectual caliber argue this out with ubersuber.
#133 |
U know they're the same person right.......
#134 |
Were the same person! Past tense I hope! Haven't seen a third person that I suspect is yet the same so far.
#136 |
I am just about the total polar opposite of him!!!!
#137 | |
Assuming he comes back, he won't be able to help himself and he will blow his cover, again. |
| The Following User Says Thank You to jvincent For This Useful Post: | Tcoat (11-26-2014) |
#138 |
Well technically he's still out there somewhere so unless he met an untimely demise I'll stick with they are lol.
#139 |
Edit; I believe he's still on the subaru brzclub forum.....
#140 | |
Think we have stopped this thread from resurrecting any further yet? Is there anybody brave enough to say "Oh, but the SAAB engine is blah, blah, blah, bullshit, bullshit, bullshit (insert massive drawing here)"?
| Tags |
| uberstupid |
| Lug Nut Torque | Lunatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 07-30-2014 07:45 PM |
| Torque Pro | sav | AFRICA | 33 | 08-27-2013 07:31 AM |
| 500 hp & 550 lb/ft torque ? yes please | LS13 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-17-2013 12:48 PM |
| What torque dip? | pdreams | Engine, Exhaust, Transmission | 44 | 11-12-2012 06:56 PM |
| Torque App | ZetaVI | Other Vehicles & General Automotive Discussions | 4 | 12-02-2011 12:22 AM |
