Old 11-23-2014, 02:27 PM   #99
shif7i7down
Erected Member
Drives: frs
You guys ever tried this with a turbo or sc kit installed?
shif7i7down is offline   Reply With Quote
Old 01-10-2015, 07:25 PM   #100
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Did this last night and drove around a little with it. It does back fire which is pretty cool and I think it scared a few cars around me as well as myself in the beginning.
At low speed the car does jerk around a little more than normal. Or maybe the ecu is still learning the new tune. Wish it didn't jerk at low speeds, maybe it will go away after the ecu learns?
Sweet spot is when your cruising and then slowing down and hold the throttle a little bit and it will just pop like popcorn!
Anyone know if there are any negatives to this? Bad for injectors, headers, exhaust pipes, or anything else? I don't want to cause excessive wear on things. Any ideas would be helpful!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 01-15-2015, 08:41 AM   #101
Wyattkb
Drives: 2014 Whiteout FRS
Whatever happened to @Shiv@Openflash making a tune file for this?
Wyattkb is offline   Reply With Quote
Old 01-15-2015, 09:43 AM   #102
SoCalArgento
Drives: 2014 Argento FRS
^ same thought
SoCalArgento is offline   Reply With Quote
Old 01-15-2015, 10:03 AM   #103
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Why would he help you burn your cat, valves and whatever else up? Do it yourself if you want it.
Old 01-15-2015, 10:05 AM   #104
Wyattkb
Thanks for the useless reply.
If you took time to read the thread you would read that he was going to release a tune including this.
Old 08-15-2015, 06:40 PM   #105
MoeVee
Drives: black customized Gt86
i just bought my oft tuner and i want to buy a good exhaust that gets backfire so what do you guys recommend.
MoeVee is offline   Reply With Quote
Old 08-15-2015, 07:09 PM   #106
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Tomei 60r
Old 08-15-2015, 07:33 PM   #107
SoCalArgento
Check out this thread:
http://www.ft86club.com/forums/showthread.php?t=61069
Old 08-15-2015, 11:02 PM   #108
DJCarbine
Thupercharged
DJCarbine's Avatar
The less resonators/cats the better. Even a Q300 style muffler can produce loud sharp pops. The Q300 on my FRS had a cat upstream, so it is quite mild.
The Q300 on my WRX wagon did not pop at all with factory cats in place, but once I got a catless downpipe it will produce ear splitting pops and flame.
Not sure what timing the FRS is running, but I have the WRX going as low as -15* timing as well as some tip in enrichment tweaks and adjusting the "in gear idle" timing
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 08-16-2015, 10:19 AM   #109
churchx
churchx's Avatar
Drives: 2014 GT86
Am i wrong that:
backfires/flames - dumping lot of unburnt fuel in exhaust.
unburnt fuel @ cats - high temps there, easily melting that ceramic mesh.
Unless one wants intentionally to damage cats, i fail to find why this should be tried on car that still has cats (be those stock or aftermarket ones).
Old 12-22-2016, 11:44 PM   #110
TheMedakaBox
[EUROBEAT INTENSIFIES]
TheMedakaBox's Avatar
Drives: 2015 Scion FR-S Steel
Looks like Shiv never got that tune
TheMedakaBox is offline   Reply With Quote
Old 12-23-2016, 05:39 AM   #111
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
That'd be the best, but it won't happen. I have no clue about tuning and i am not going to touch the files myself it'd be nice if we had a library of tune files. But that isn't going to happen either.
guybo is offline   Reply With Quote
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
R/T Tuning & R/T Tuning Speed Shop Review Thread R/T Tuning User/Vendor/Sponsor Reviews, Feedback, Comments 37 10-03-2014 03:23 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 03:12 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 07:33 PM
