| Software Tuning Discuss all software tuning topics. |
#99 |
Erected Member
Drives: frs
You guys ever tried this with a turbo or sc kit installed?
#100 |
Drives: 2013 FR-S Whiteout MT
Did this last night and drove around a little with it. It does back fire which is pretty cool and I think it scared a few cars around me as well as myself in the beginning.
At low speed the car does jerk around a little more than normal. Or maybe the ecu is still learning the new tune. Wish it didn't jerk at low speeds, maybe it will go away after the ecu learns? Sweet spot is when your cruising and then slowing down and hold the throttle a little bit and it will just pop like popcorn! Anyone know if there are any negatives to this? Bad for injectors, headers, exhaust pipes, or anything else? I don't want to cause excessive wear on things. Any ideas would be helpful!
When in doubt, throttle out!
#101 |
Drives: 2014 Whiteout FRS
Whatever happened to @Shiv@Openflash making a tune file for this?
#103 |
Drives: Toyota 86 GTS
Why would he help you burn your cat, valves and whatever else up? Do it yourself if you want it.
#104 |
#105 |
Drives: black customized Gt86
i just bought my oft tuner and i want to buy a good exhaust that gets backfire so what do you guys recommend.
#106 |
Drives: 10 Series #974 6m/t
#107 | |
Drives: 2014 Argento FRS
Check out this thread: http://www.ft86club.com/forums/showthread.php?t=61069 Sent from my iPhone using Tapatalk |
#108 | |
Thupercharged
The Q300 on my WRX wagon did not pop at all with factory cats in place, but once I got a catless downpipe it will produce ear splitting pops and flame. Not sure what timing the FRS is running, but I have the WRX going as low as -15* timing as well as some tip in enrichment tweaks and adjusting the "in gear idle" timing
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#109 |
Drives: 2014 GT86
Am i wrong that:
backfires/flames - dumping lot of unburnt fuel in exhaust. unburnt fuel @ cats - high temps there, easily melting that ceramic mesh. Unless one wants intentionally to damage cats, i fail to find why this should be tried on car that still has cats (be those stock or aftermarket ones). |
#111 | |
Huge E85 fan!
Drives: 2016 Scion FRS
| Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1213 | 06-17-2025 04:02 PM |
| R/T Tuning & R/T Tuning Speed Shop Review Thread | R/T Tuning | User/Vendor/Sponsor Reviews, Feedback, Comments | 37 | 10-03-2014 02:23 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 02:12 PM |
| Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
