CANADA Canada
Old 11-17-2014, 03:40 PM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Drain STA-BIL gas after storing for winter?
Fellow Canadians,
Going to be storing my 86 for the first time (and first stored car ever, for that matter). I'm going to add some sta-bil and top off my gas before the snow starts to settle.
I'm curious as to how many people pump their gas our (drain) after storing for the winter (with stabil) or whether it's fine to just consume the gas through regular driving.
I also plan to drive the car for a few minutes every 2 weeks or so as I park in a condo with a fairly expansive indoor parking lot (5KPH lapping!)
Thanks in advance.
1Cor10:23 is offline   Reply With Quote
Old 11-17-2014, 04:24 PM   #2
wbradley
Sarcastic SOB
wbradley's Avatar
I have no idea why you would think that you need to drain the fuel that has stabilizer added for storage. The purpose of stabilizer is to keep the fuel from going bad (oxidizing), so that is usable in the spring.
Where would one dispose of drained fuel anyway?
Old 11-17-2014, 04:25 PM   #3
1Cor10:23
1Cor10:23's Avatar
@wbradley I've seen a few people suggest it on other forums - they would pump out the "stabilized" / stored fuel and put it into other small motor equipment or cars that are less temperamental about fuel quality.
Old 11-17-2014, 04:52 PM   #4
df.dima
Drives: FR-S and Mazda 3 Sky
Stored for 2 winters, never drained. Doing same thing this year.
df.dima is offline   Reply With Quote
The Following User Says Thank You to df.dima For This Useful Post:
1Cor10:23 (11-17-2014)
Old 11-17-2014, 05:44 PM   #5
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
To be safe, just behave yourself in the spring as you burn through the tank. Much easier said than done, however. That first drive in the spring is like driving it for the first time all over! Tears of joy may or may not have been shed.
BatStig is offline   Reply With Quote
The Following User Says Thank You to BatStig For This Useful Post:
Old 11-17-2014, 08:06 PM   #6
Faccck
Faccck's Avatar
Drives: 2014 Scion FRS
op, fill up tank with fuel and then add bottle of stable and then run the car for 5mins so that the stable can get into the entire fuel line. When the warmer weather arrives, just drive the car around until you empty the tank. Make sure you cover your exhaust tips up with steel wool too to keep the rodents out.
Faccck is offline   Reply With Quote
The Following User Says Thank You to Faccck For This Useful Post:
Old 11-17-2014, 08:27 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
Hmmm seems like a waste of effort to drain and store 55L of Ultra 94 to run in my lawn mower. I'd be lucky to burn 10L/ year.
The purpose of stabilizer is to ensure the fuel is still good to use in 6 months, otherwise it serves no purpose.
If in an unheated garage where theres a power receptacle, its best to keep a battery tender hooked up and never start the car until you take it out. In a warm condo garage perhaps start it every week to 10 days just to keep the battery from discharging. Running at idle 5 to 10 mins should do the job. Rolling forward or back slightly will help avoid flat spots on tires.
The Following User Says Thank You to wbradley For This Useful Post:
Old 11-17-2014, 10:45 PM   #8
df.dima
^ about flat spots and tires, recommendations are to fill air to max psi, but last year I forgot. I never move the car, but it was ok last winter with regular mid 30 psi...
Let's say all winter I was a bit concerned about driving on square tires soon . It was fine.
Old 11-18-2014, 04:22 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
To avoid, I kept mine at ma (42 PSI I think). Apparently the flat spots usually work their way out after 1/2 hr of driving.
Old 11-18-2014, 06:35 PM   #10
Thorpedo
The SquadWhisperer
55L?!!! You add an extra fuel tank?
Yeah the Sta-bil is specifically designed to prevent you from having to drain the fuel. Don't bother. If the car is stock then I wouldn't worry about driving it hard on the first tank either.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 11-18-2014, 11:25 PM   #11
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
I honestly been storing my subaru for 6 years now and i don't do anything. No PSI increasing, no stabilizer fuel...all i do is warm it up and sometimes on dry winter days take it around the block. Doing the same for the FRS.
I guess if your paranoid you can do all those steps, but I've never done them and never had issues. Just my .02 cents
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following User Says Thank You to Mr.Impreza For This Useful Post:
FRSNewb (02-27-2015)
Old 11-19-2014, 09:20 AM   #12
RFB
RFB's Avatar
Drives: FRS
A trusted mechanic - racer buddy of mine believes gas will last 1 year.
I have routinely stored cars for a year, no gas stabilizer, full tank, a couple of bottles of methyl hydrate (gas line anti freeze) and have had no problems.
With my twin, I tried storing with and without stabilizer and noticed no difference .
Perhaps the problem of winter condensation in the tank and lines adding water to the fuel is more of a problem than gas going bad - ?
RFB is offline   Reply With Quote
Old 11-19-2014, 10:26 AM   #13
Thorpedo
The SquadWhisperer
http://www.fuel-testers.com/expirati...hanol_gas.html
Straight gasoline has a shelf life of years, but with the addition of ethanol it drops significantly (3 months) due to ethanol's tendency of absorbing water and subsequently separating which has huge effects on octane rating.
I always cringe when I see "my mechanic buddy said". Five &*%^%^ minutes of googling will result in better info. A lot of people don't take into account that things might not be the same now as they were 30 years ago.
Old 11-19-2014, 11:55 AM   #14
RFB
RFB's Avatar
Drives: FRS
Lol ! I know what you mean !
Since he has been wrenching and racing for 40 years, as well as other very hi tech activities, I always try his techniques based on his experience.
He was talking from practical experience obviously, and the reason for the methyl hydrate is to address exactly what you correctly state.
I use non ethanol fuel, with methyl for storage for condensation - it worked.
Did the same with ethanol 94, it worked. If OFT shows knocking after storage a gallon of race gas or Torco would bring the octane backup.
CERBERUS
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Storing for a year dragonwiddd Scion FR-S / Toyota 86 GT86 General Forum 13 03-05-2014 09:12 AM
Storing Car For 9 Months Touge86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 11-11-2013 11:21 AM
Storing my car SmsAlSuwaidi Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 06-22-2013 07:38 PM
Storing an unused car? #87 Off-Topic Lounge [WARNING: NO POLITICS] 10 02-21-2012 11:51 PM
