Old 11-17-2014, 02:59 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Help On Deciding Spring Rates
I'm trying to determine what spring rates to get on my next dampers.
Atm I have 6k springs front and rear with Eibach sways. The front sways are rated at 10k and the rear at 6k. I find the ride acceptable with this set up even on crappy roads. I am guessing that the sway bar rates cannot be just added to the spring rates to get an equivalent spring rate without the sways. I am intending to put the original sways back on but they are rated so low (2.5k/2k) as to be not as significant with higher spring rates.
I know that CSG's car is running 10k/12k () and Mike and others says the ride is surprisingly compliant given those rates.
Things that come to mind.
1/ People's idea of comfortable is subjective.
2/ My car is a daily driver that I track, not the other way around.
3/ Everything's a compromise.
With no opportunity to have a ride in a car with decent dampers I am unsure on what rates to get. I was originally intending to get 8k/9k (1.4k difference at the wheels) but I wonder if 9k/10k (1.7k difference) would be acceptable. These rates keep the front/rear ratio close to 6k/6k (1.56k). The thought of 10k/12k (1.32k) just plain scares me even though I've been never in such an equipped car.
Could people tell me their experiences with their well damped highly sprung cars?
Old 11-17-2014, 03:03 AM   #2
CSG Mike
CSG Mike's Avatar
Our 10k/12k is more compliant than stock, per 3d accelerometer readings on our AIM solo DL.
Damping has more to do with ride comfort than raw spring rate.
There's gotta be SOMEONE in your area with nice dampers. Even if it's a different car, get a ride. Your mind will be blown.
We run 16k and 18k square on our S2ks.
@ImperiousRex is on 9k/11k, but has a rear aero bias. It'll still rotate at high speed
CSG Mike is online now   Reply With Quote
Old 11-17-2014, 03:18 AM   #3
Captain Snooze
Drives: Red Herring
I think I need new glasses. I swear you have written 16k and 18k there.
I will go damper hunting at the next track day
Old 11-17-2014, 08:48 AM   #4
Racecomp Engineering
No need to get new glasses. It's not worth quoting spring rates from another car...they are not directly comparable without knowing the motion ratio. Then you can look at wheel rates.
From a quick google search, the motion ratio for S2ks are around 0.7 front and 0.67 rear.
16 * 0.7^2 = 7.84
18 * 0.7^2 = 8.82
So that's not that bad at all.
What kind of tires do you run?
Very stiff rates on lower grip street tires will not make you faster and will make the car hard to drive.
- Andy
Old 11-17-2014, 02:04 PM   #5
CSG Mike
CSG Mike's Avatar
16 * 0.7^2 = 7.84
18 * 0.7^2 = 8.82
- Andy
Hows 14k/16k on our WRX? Geometry is almost the same as the FRS
Old 11-17-2014, 02:11 PM   #6
That's pretty firm.
- Andy
Old 11-17-2014, 03:04 PM   #7
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
I'm always going to defer to CSG_Mike on this stuff, but since OP asked me to post my thoughts here, here's my take in layman's terms.
You need to figure out which damper you're going to get first before you should worry about the spring rate values. Every damper is different and every manufacturer is going to have a different valving based on their target application of the product.
Mike's 10/12k set up is on Tein SRC with their custom valving. My 9k/11k set up is on JRZ RS with settings for my driving style. I'm sure Andy has his own thoughts with the RCE set ups.
I will say that my JRZ's came default with 10k/11k springs and after driving for several months with that set up, I found that the car would be easier to drive with a rear that has a little more progressive oversteer bias. So with that in mind, we've found that having a stiffer spring ratio in the rear is better for high speed transitions and we can tweak with tire pressures/sway bar settings for fine tuning on specific tracks. And we softened the front rather than going stiffer in the rear just for a little more street compliance but I think the coilovers could've been set up to work either way.
Your driving style will dictate what will work best for you.
ImperiousRex is offline   Reply With Quote
Old 11-17-2014, 04:30 PM   #8
Captain Snooze
Drives: Red Herring
I am using Kumho 225 V710 on track. My concern is/was about running 10k/12k for daily driving.
Yeah, pardon me. CSGMike had already read a previous post of mine where I was asking about AST 5200s so I didn't think to re-post that info here.
Aaaarrrrggghhhhhh!
Old 11-17-2014, 04:44 PM   #9
Captain Snooze
Drives: Red Herring
What did you think of those rates for street driving at sedate speeds?
Old 11-17-2014, 05:15 PM   #10
CSG Mike
CSG Mike's Avatar
You'll likely have a different set of damper settings for street driving, but once you dial it in for ~1.5 oscillations, you'll have a surprisingly smooth ride.
I wish you were local; we have a LOT of high end damper users in SoCal. It only takes one ride to be convinced that it's money well spent.
Old 11-18-2014, 03:20 AM   #11
M23
Drives: 86
Just get really stiff 18k springs. Then, if you want to adjust to softer rates and a lower height, cut coils off..two birds in one stone and super versatile! Boom! Top secret trick bro.
M23 is offline   Reply With Quote
Old 11-18-2014, 10:02 AM   #12
I think the 9k/10k with stock sways that you're thinking of will work well. If you feel you need more roll resistance, you can think about adding your aftermarket sways back on.
I think we were running 9k springs on our RS1s when we were testing them for JRZ....they were VERY smooth. AST 5200 probably won't be quite as smooth, but they are quality dampers.
- Andy
Old 11-18-2014, 10:51 AM   #13
Kayshart
How about STi Pinks? Are they any good?
Kayshart is offline   Reply With Quote
Old 11-18-2014, 02:18 PM   #14
ImperiousRex
Track Junkie
You would never guess that the spring rates were that high - it almost feels like stock. You can feel a little stiffness on impact with speed bumps and what not but the car settles very quickly. On the freeway it's very comfortable.
2015 FRS spring rates? Ubersuber Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-05-2015 08:27 PM
Anyone With Custom Spring Rates? Sprinter Tracking / Autocross / HPDE / Drifting 3 05-13-2014 12:12 AM
Coilover spring rates for comfort Barbecue Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-12-2013 11:09 PM
Spring rates for Super charged FRS jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-21-2013 09:32 PM
Weird GT 86 factory spring rates in GT5? Spec-Al Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 03-27-2012 02:30 PM
