Old 12-10-2013, 07:44 PM   #1
Barbecue
Drives: Slow
Coilover spring rates for comfort
I am having my coilovers built and can choose any spring rate I want. Is 5k/6k good for comfort or too soft? I care more about comfort than track performance.
I have 17x9 +35 TC105N and will be using 245 or 255 Michelin Pilot Super Sports
I have the following installed.
Whiteline front lower control arm bushings
WL front caster bushings
WL rear upper adjustable camber bushings
WL rear subframe bushings
WL rear trailing arm bushings
Barbecue is offline   Reply With Quote
Old 12-10-2013, 07:51 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Valving would make a bigger difference than spring rate, but 6k or under would be best.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
koevasi (12-25-2013), ZDan (12-10-2013)
Old 12-10-2013, 09:38 PM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I thought the standard springs/dampers were quite comfortable @ 2.7k/3.5k f/r (BRZ)
Old 12-11-2013, 01:12 AM   #4
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Funny thing is that with my 3.8/4.5K Swift springs the ride is a bit better than factory.
It has more to do with having the damping match the spring rates than just going for softer springs.
Intent > Content
Old 12-11-2013, 01:34 AM   #5
Captain Snooze
Drives: Red Herring
Sure sure understood. I was just suggesting to the op that the standard springs are "comfortable". What I don't understand is if the op is having the dampers built why is s/he now asking about springs.
Old 12-11-2013, 01:36 AM   #6
solidONE
solidONE's Avatar
He is getting coilovers with custom rates. Which one's, he did not say. @Barbecue?
Intent > Content
Old 12-11-2013, 01:47 AM   #7
Barbecue
Drives: Slow
I am getting the coilovers from AMR Engineering. I am going to call them to send me a final invoice so I can pay and they can start building them. Their current lead time is only 2-3 weeks.
The Following User Says Thank You to Barbecue For This Useful Post:
solidONE (12-11-2013)
Old 12-11-2013, 02:22 AM   #8
fatoni
I imagine it has more to do with not riding the bump stops under normal circumstances
Old 12-11-2013, 02:45 AM   #9
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Valving makes up 95% of the comfort. We run 10k/12k springs and it rides more comfortable than the other kits out on the market.
CounterSpace Garage is offline   Reply With Quote
The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post:
Dave-ROR (12-11-2013), ZDan (12-11-2013)
Old 12-11-2013, 07:57 AM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Damping controls comfort as noted above. Substandard dampers with soft springs will ride like crap, excellent dampers with a good digressive curve that bleeds off at higher speeds will ride like a dream.
Spring rate should be chosen based on intended usage. Street only? Street/AutoX, Street/track? Biased for daily-driving on the street with occasional track/autoX, or for weekend street driving and heavy track/autoX?
Suberman (12-12-2013)
Old 12-11-2013, 08:50 AM   #11
Suberman
Drives: Subaru BRZ Sport Tech Satin White
This thread may be illuminating:
http://www.ft86club.com/forums/showthread.php?t=52061
If this is fact, and I have not tried to check the length of the bump stops myself, then steel spring rate on these cars may not be very relevant to how coilovers might change ride and handling.
The bump stops on the coilover dampers would also need to be compared to stock bump stop rates and lengths.
If bump stops are being "tuned" by the factory to add to the steel spring rate then how the coilovers are treating the same issue would be important.
For example, if the coilovers don't rely on contacting the bump stops the higher stated spring rate might not be too much different from stock.
Bear in mind that the BRZ comes from the factory with fixed height coilovers.
Suberman is offline   Reply With Quote
Old 12-11-2013, 05:45 PM   #12
fatoni
yeah that thread is pretty much what im thinking. its a really common practice, especially on smaller cars. i dont think its a concern in the aftermarket though because companies can typically use shortened shock bodies. there are companies like fatcat motorsports who have a whole line of bumpstops for the miata for different applications. its proven how significant that kind of thing is with other models and im sure we could see the same here.
Old 12-11-2013, 07:29 PM   #13
raytrix
Drives: Series 10 FR-S
All in the valving. My Stance Pro Comp 2 are 8k/9k and runs smooth like butter.
raytrix is offline   Reply With Quote
The Following User Says Thank You to raytrix For This Useful Post:
Old 12-11-2013, 08:05 PM   #14
The quality of the damper (and the valving) is what really matters. Higher spring rates WILL contribute to a harsher ride, but not as much as people think.
Going from a 5k spring to a 10k spring does not mean the ride will be twice as harsh.
FT86Z (07-01-2018), Suberman (12-12-2013)
Spring Rates - Track / Autocross Dave-ROR Tracking / Autocross / HPDE / Drifting 83 05-16-2023 04:56 PM
Best Coilover Closest to Stock Ride Comfort? taimysho0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 09-04-2013 01:19 PM
Need Coilover Advice for combined Street Comfort + Track Use distracteddev Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-23-2013 04:15 PM
Spring rates for Super charged FRS jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-21-2013 09:32 PM
Weird GT 86 factory spring rates in GT5? Spec-Al Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 03-27-2012 02:30 PM
