Old 11-12-2014, 07:14 PM   #15
Koa
Strong contender for..
Most Ghetto award 2014
The Following 4 Users Say Thank You to Koa For This Useful Post:
chaoskaze (11-13-2014), pushrod (11-13-2014), Struckbylitenin (11-12-2014), SubiePig (11-13-2014)
Old 11-12-2014, 07:30 PM   #16
Foobar
SLO NO MO
Foobar's Avatar
I see OP has the OpenFlash Tablet. That being the case, forget this ghetto rig and just modify these three tables with RomRaider: http://i.imgur.com/ZBR0Bl6.jpg
Old 11-12-2014, 07:33 PM   #17
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
My solution was to connect a 2.5" diameter rubber tube from my straight pipe through the stock muffler for morning start-ups. I guess this works too, but I'd be worried about creating too much back pressure.
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
radroach (11-12-2014)
Old 11-12-2014, 07:36 PM   #18
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Originally Posted by WNDSRFR View Post
But I don't like the sound they make in my garage first thing in the morning. And neither do my neighbors. The noise only lasts for about a minute but that's long enough to piss off a lot of people. .
I feel your pain. However, I kind of like that it pisses off the neighbors, that means my car is just loud enough! It's especially bad that my house and the neighbors acts as a wind tunnel...
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 11-12-2014, 08:48 PM   #19
BRZ?
Drives: 2014 SWP 6MT BRZ
disable your cold start via OFT or get an exhaust with a respectable db volume
2014 SWP 6MT BRZ Limited
Diode Dynamics Door, Trunk, Dome, Vanity, License Plate and Side Marker LEDs
GrimmSpeed Plate Relocation
BRZ? is offline   Reply With Quote
Old 11-12-2014, 09:12 PM   #20
raven1231
I tried running RomRaider to do this and it keeps saying a java exception error has occurred, and won't let me run the program...
Old 11-12-2014, 09:44 PM   #21
Foobar
SLO NO MO
Foobar's Avatar
Make sure you have the latest Java runtime environment for 32bit on your machine, even if it's a 64bit OS. I think I read somewhere that RomRaider needs that.
The Following User Says Thank You to Foobar For This Useful Post:
raven1231 (11-13-2014)
Old 11-12-2014, 10:34 PM   #22
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Doesn't the cold start stop if you just put it into gear and gently drive away? If it was causing such a problem with neighbors I would just start it up and then just immediately put it into first and exit the garage and go.
Originally Posted by humfrz
I'm old and lazy
Old 11-12-2014, 11:05 PM   #23
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Best analog solution: move.
2nd best analog solution: be mindful of your neighbors and modify your car accordingly.
Maybe I'm a prick, but I judge neighborhoods and the associated property (in part) by the cars driven by the current inhabitants. As an enthusiast, I'm semi-understanding of this stuff, but only to a point. I imagine non-enthusiasts are far more critical. At best, you're developing a negative reputation amongst your peers; at worst, you're devaluing their property.
sdemo is offline   Reply With Quote
Old 11-12-2014, 11:37 PM   #24
evan
Drives: fr-s
Straight pipe will fix it
evan is offline   Reply With Quote
Old 11-13-2014, 12:47 AM   #25
Decay107
Decay107's Avatar
My neighbors love my car's straight pipe.
Old 11-13-2014, 05:19 AM   #26
mike7792
mike7792's Avatar
Drives: 2014 Scion FR-S
I'm confused by your pictures... is your car silver or white?
1st pic is white car with missing ceiling and then the rest are silver car
just curious
mike7792 is offline   Reply With Quote
Old 11-13-2014, 06:06 AM   #27
raven1231
just curious
My guess would be silver and the lighting just makes it appear white in the first picture
Old 11-13-2014, 07:26 AM   #28
rlpaul
Drives: point A to point C. Screw point B!
Am I the only one who thought he was going to sound insulate his garage when they saw the insulation photo, only to be erm... surprised by the 'solution'?
rlpaul is offline   Reply With Quote
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Loud misfires upon cold start connorlug Issues | Warranty | Recalls / TSB 42 03-31-2016 04:43 PM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
