Old 04-21-2014, 10:27 AM   #113
w00t692
Drives: 2008 Civic Si
I love how people speculate these things don't work well early in the thread. Honda puts one stock on the K20Z3/A2/Z1 engines. They ABSOLUTELY work. I didn't realize it was a question hehe
w00t692 is offline   Reply With Quote
Old 09-16-2014, 08:14 AM   #114
EZx2
Drives:
Hi,
.will 21311AA170 sandwitch (compl. oil cooler from 2002-2007 Subaru Impreza WRX/STi ) work?
EZx2 is offline   Reply With Quote
Old 11-11-2014, 12:56 AM   #115
bakilman
bakilman's Avatar
Drives: White FR-S
I have the intercooled Innovate S/C kit on my car. Would it make sense to run that coolant system through the oil cooler? With these cooler temps those hoses are cool to the touch. I'd imagine I could get a noticeable drop in oil temps by doing so. Comments and concerns??
bakilman is offline   Reply With Quote
Old 11-11-2014, 05:32 AM   #116
s2d4
s2d4's Avatar
No, unless you want even higher IAT.
Old 11-11-2014, 08:36 AM   #117
nunonuna
nunonuna's Avatar
Did anyone try to replicate plumbing as Cusco oil cooler yet?
nunonuna is offline   Reply With Quote
Old 11-11-2014, 09:48 AM   #118
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by Kostamojen View Post
Took 6 months, but finally have proof the oil cooler does something:
Ran the same road 6 month ago without the oil cooler and again today. Both times temps were in the low 70's. I've done a bit to the car since then, but nothing in terms of power. With the tires I have now, I could actually push the car A LOT harder and I even ran it with the A/C on just to make sure I was running the car as hard as possible.
Might be hard to see the video, but the Oil temps are now running 15-20 degrees cooler. At some points the car was running 260 degrees or higher before, now they never exceed 245ed degrees. Thats a HUGE improvement IMO!
What engine oil are you using? before and after the change ..
Old 11-13-2014, 12:47 PM   #119
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
The cooler definitely does work but what ive noticed on track is that oil temps will still peak 240ish on a hot day but will cool down really fast when you back off the rpm. In 1 lap on a average small track it will cut to maybe 220s.
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 09-10-2019, 06:28 AM   #120
dkostesk
Drives: 2013 Toyota 86 - Supercharged
Originally Posted by regal View Post
This is awesome stuff, nothing worse than an air to liquid oil cooler on a street car. The Subaru engineers chose this method because it makes most sense.
However I don't think your proposed coolant flow will work well because there isn't a pressure gradiant, you have to force the coolant thru the cooler because its a constriction. With your proposal you would want to eliminate the elbow instead of bypassing it.
Hey not sure if you ended up going ahead with this. I'm thinking of doing something similar on a sprintex supercharged 86.
I'm thinking of connecting it to the upper end of the water bypass pipe which runs water from the throttle body.
Does anyone know whether it would get much coolant flow that way?
dkostesk is offline   Reply With Quote
BRZ wheels on Forester XT sea otter 99 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2017 07:56 PM
Wheel Directory: OEM Subaru Forester STi (2005) 18x7.5 +48 Surok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-24-2015 08:42 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 04:35 PM
OEM Forester All Weather floormats Laika Cosmetic Modification (Interior/Exterior/Lighting) 2 01-14-2013 10:19 PM
1998 Forester on BRZ/FRS Rims :) Meeners BRZ Photos, Videos, Wallpapers, Gallery Forum 11 11-23-2012 09:45 PM
