Old 10-31-2013, 04:54 PM   #99
CARNZ
CHECK ENGINE
Drives: 2004 STi
Done, and done.
http://www.ft86club.com/forums/showt...90#post1305990
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 10-31-2013, 05:13 PM   #100
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
looking forward to seeing some before and after results of this setup.
Definitely a good option using OEM parts, not screwing with oil pressures and not having to worry about exposed oil lines and potential failure/leak points.
smbstyle is offline   Reply With Quote
Old 10-31-2013, 06:32 PM   #101
Kostamojen
Originally Posted by CARNZ View Post
Woot, thanks for getting this done! I'm ordering my parts today
Old 10-31-2013, 06:41 PM   #102
CARNZ
CHECK ENGINE
Drives: 2004 STi
No prob
Been wanting to do this, and once I saw this thread I finally got off my ass and got it done lol.
You going to go with my parts list or the stuff you had listed? I saw some of your numbers were different. I used all the early production FXT numbers
Old 01-01-2014, 03:52 PM   #103
Urmyson
Hey i just had an idea, not sure if it will work. Could you remove the coolant lines from the throttle body and move them to the sandwich plate? I understand you might have to use new, longer lines. But if you wanted to bypass throttle body warmer anyways it seems like it might be a good idea. I think it would be a little cheaper since you would only be buying the sandwich Plate and some hose.
Let me know what you guys think that have already done this.
Urmyson is offline   Reply With Quote
Old 01-01-2014, 03:58 PM   #104
wootwoot
Drives: FRS
Great idea my man!
I will have to pop my hood and take a look at that. Good thinking.
Old 01-01-2014, 03:59 PM   #105
Trac Toy
Trac Toy's Avatar
This has already been discussed, the lines to the throttle body were decidedly smaller than the sandwich plate. Therefore reduced cooling capacity.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 01-01-2014, 04:16 PM   #106
Urmyson
Any idea of the id of the throttle body hoses vs the sandwich plate? I'm more or less just wanting to warm the oil up faster. The cooling would just be an added benefit or me.
Old 03-23-2014, 09:26 AM   #107
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Originally Posted by Kostamojen View Post
So I popped the hood on a Forester XT with the 2.0DIT boxer engine at the dealer today and the first thing I noticed was the factory oil cooler...
Anyone care to test one of these out on a Twin?
Doesn't appear to be thermostat equipped like mocal sandwich
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 03-23-2014, 09:53 AM   #108
Malt
Drives: 2015 WRX
Why would you need it to be equipped with a thermostat? The beauty of this setup is that it uses the coolant to heat up the oil when the oil is cold and then uses the coolant to cool it off when its hot. I don't have an actual data on before and after as I didn't have the PID setup in torque before I did this mod, but my oil temps have never gone above 200 since I did this.
Malt is offline   Reply With Quote
Old 03-23-2014, 10:02 AM   #109
CARNZ
CHECK ENGINE
Drives: 2004 STi
Sums it up pretty well.
Guess he didn't feel like reading this thread or the other thread about it.
Old 03-23-2014, 10:12 AM   #110
kiichiro
Thanks, makes total sense
Wasn't taking a stab at it really, looks good.
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 04-20-2014, 11:05 PM   #111
Kostamojen
Took 6 months, but finally have proof the oil cooler does something:
[ame]http://youtu.be/VnGKGTCsca8[/ame]
Ran the same road 6 month ago without the oil cooler and again today. Both times temps were in the low 70's. I've done a bit to the car since then, but nothing in terms of power. With the tires I have now, I could actually push the car A LOT harder and I even ran it with the A/C on just to make sure I was running the car as hard as possible.
Might be hard to see the video, but the Oil temps are now running 15-20 degrees cooler. At some points the car was running 260 degrees or higher before, now they never exceed 245ed degrees. Thats a HUGE improvement IMO!
Old 04-21-2014, 05:49 AM   #112
troek
troek's Avatar
Drives: 2012 Toyota 86
wow, im glad i didnt have an oil gauge when i ran fuji with out an oil cooler, i see 250 now with one, hate to imagine how hot it got before.
troek is offline   Reply With Quote
BRZ wheels on Forester XT sea otter 99 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2017 06:56 PM
Wheel Directory: OEM Subaru Forester STi (2005) 18x7.5 +48 Surok Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-24-2015 07:42 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
OEM Forester All Weather floormats Laika Cosmetic Modification (Interior/Exterior/Lighting) 2 01-14-2013 09:19 PM
1998 Forester on BRZ/FRS Rims :) Meeners BRZ Photos, Videos, Wallpapers, Gallery Forum 11 11-23-2012 08:45 PM
