#169 | |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
- AdrianG |
#170 |
Drives: 2014 Pearl BRZ Limited
Any updates of these updated xml's with the MAF tables added? I'm on B01C and absolutely have to get this idle down. I have no cats in my exhaust, and it's STUPID loud. Sounds like the car is going to blow up LMAO!
I've set the timing from -15 to 0, and its 'better' but still idles high as hell..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
| The Following User Says Thank You to edeekeos For This Useful Post: | akahenry (04-30-2015) |
#171 | |
Drives: 2012 Toyota 86
#172 |
First Class Speeder
Drives: Silent and Quick
lol tell me about it cold start at 330 am in a basement parking garage with a check engine light = 2200 rpm for 30 seconds with Buddy Club No resonator Header back catless...
#174 |
Living in what is about to become a very cold climate, seeing these huge mods at the low end kind of freaks me out. I imagine that while these table are likely very effective at heating up cats, they might also have something to do with keeping an extremely cold engine going.
I changed it to be much less aggressive than the above recommendations until it gets to 50 degrees: MAF Correction After Start (Neutral): 40 20 11 10 10 9 9 9 9 8 8 Ignition Timing Post Start: -15.07 -15.07 -15.07 -15.07 -15.07 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 -8.04 I left MAF Correction After Start (In-Gear) as stock because I have a remote starter installed and by the time I get into gear, it's warm.
#175 | |
Drives: GBS BRZ
I will here shortly. I currently don't have an exhaust on so it wouldn't do much good hah. Have you checked if the tables are in the definitions? I know at least my tune is pretty old and before some of the stuff was mapped out. |
#176 |
SLO NO MO
I'm using the RR_ZA1JA00C.xml definition from the OFT site and it doesn't appear to have these tables. Is it safe to use anyone's definition file for this CALID or do I have to get one specifically for the OFT?
#177 |
Be very careful, because OFT's CALIDs are different. Most of the 2.0x ROMs are actually version B01 masquerading as something else. Using the wrong def could result in you bricking an ECU.
| The Following User Says Thank You to phrosty For This Useful Post: | Foobar (11-10-2014) |
#178 |
SLO NO MO
Roger that - I'll reach out to Shiv to see if he can send me the def file that he's been using.
#179 |
SLO NO MO
OK, thanks to all the contributors in this thread. I successfully made this change on my OFT300 tune. Shiv confirmed it was a 1.x definition so I worked with the OFT 1.x XML file and added the tables documented in this thread using TD-D's version in github. I didn't take his entire file in case my OFT one had some specific values it needed.
Sent from my Nexus 5 using Tapatalk |
#181 | |
SLO NO MO
#182 |
According to this thread, I should have the tables "MAF Correction After Start (In Gear)" and "MAF Correction After Start (Neutral)" in the "Mass Airflow / Engine Load" folder of the .bin file.
I am using OFT v2.06 A01C bin file (Stg 2 E85) and these tables are not present. There's a lot of talk about what to do/not to do to add these using definition files from romraider, github, etc... Can Shiv or someone else confirm what is needed to get these two tables in the v2.06 A01C bin file? Thanks! Update: i tried adding the text listed earlier in this thread, without any success. It seems that there is another section in the definition file that is required, as the text (in the blue image) is added to the file, but the new tables do not show up in RomRaider. The text (in the red image) is present for all other tables, so it seems this is also required for the tables to appear. Does anyone know this text and can post it here? Thanks. Last edited by acj47; 12-10-2014 at 11:22 AM. |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-12-2015 11:53 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 06:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 01:35 PM |
