Old 10-19-2014, 03:46 AM   #29
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by drambo136 View Post
ok so trying that rescaling tab. you suggest setting the max at 4.25v, but how about the min? I read the data and it send both high and low are unusable.
I sure then just change the number on the map and load it up right
Where does the MAF voltage sit at its slowest point of idle? Or what is the lowest voltage in your log? I would set the minimum just below that.
You would then just copy the new scale into your, obviously checking it looks right.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-05-2014, 08:51 PM   #30
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
SO have a question similar to the OPs. GOing to ask here instead of making a new thread.
I am having trouble loading tunes files to my OFT. CAl number ends in B01C. All the tunes on the table end with B01C. Trying to ditch stage 2 EL for stg 1 93 and it will not load. Says checksum invalid? Little help would be appreciated. I am reading like 7 threads and still cant figure it out
GotBRZ1691 is offline   Reply With Quote
Old 11-05-2014, 11:21 PM   #31
steve99
Drives: FT86
No editing of tune done ?
if no editing done and its just a supplied oft tune then not all oft tunes are checksum corrected just get ofm/oft to correct checksum and you will be ok.
Old 11-06-2014, 03:54 PM   #32
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
I have an oft on its way and I'm a noob too. I won't have a problem using the stage 1 91 octane tune with a drop in filter and cat back right? They advertise it saying even noobs can use it but I wouldn't know how to log and what took look for, check for knock, or all that stuff.
eSOLOR is offline   Reply With Quote
Old 11-06-2014, 04:40 PM   #33
steve99
Drives: FT86
On usa fuels you will be fine its only us aussies on our rubbish fuels that need to tweak tunes , also drop in filter and catback will be fine on stage 1 tune
read links below if you want to know more
eSOLOR (11-06-2014)
Old 11-07-2014, 03:21 PM   #34
GotBRZ1691
GotBRZ1691's Avatar
@steve99
One more question for you about knock. What is considered a bad knock? all knock?
While on the highway with cruise control on, I would get an occasional knock of .32 or .64
Every once in awhile there would be one up to -1.04, and once on my six hour trip it when over -2. All of this was while just cruising highway at a consistent speed.
Then got to the back mountain road and romped on it, and got no knock what so ever. And I mean romped on it. 1/4 of fuel on a ~35 mile stretch of road
Old 11-07-2014, 04:09 PM   #35
steve99
Drives: FT86
@steve99
yes rhat is pretty common lower rpm 1500-3500 high load knock especially in high gear.
you can pull a bit of timing in that area rpm/load points, or try different brands of fuel some better than others. did it cause iam drop. if you puul 0.7 degrees in that area should remove most of that knock with no noticable effects.
look like its all good higher rpm so thats good.
Newbie... exam2300 Forced Induction 16 11-14-2013 10:35 AM
Newbie amjadh Scion FR-S / Toyota 86 GT86 General Forum 30 11-12-2013 08:44 PM
Is the FR-S/BRZ for Me? (Newbie) mpdescha Scion FR-S / Toyota 86 GT86 General Forum 45 09-26-2013 01:23 PM
pls help a newbie :) abling2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-17-2013 06:21 AM
Newbie KiRiMa Scion FR-S / Toyota 86 GT86 General Forum 10 01-07-2010 05:39 AM
