Old 10-10-2014, 11:29 AM   #1
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
OFT newbie
Hey everyone,
I just got my oft and im trying to upload the new 2.0 maps but i cant figure it out. my CAL ends in A00C but all of the files on my oft end in A01c, so i have to upload the A01C file correct? Everytime i try to upload a A01C it fails, but if I upload a A00C it says the checksum of the file has been corrected. Are the A01C files in there just because I bought the oft used? I just dont want to ruin my ecu.
Also and anyone show me or point me in the right directions on how to use racerom. i saw shivs tutorial but idk what files to use or how to get started. dont worry i wont upload the files to my car i just want to learn
Thanks
David
drambo136 is offline   Reply With Quote
Old 10-10-2014, 11:31 AM   #2
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Look at this. Should answer most question you may have.
http://www.ft86club.com/forums/showthread.php?t=71157
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Old 10-10-2014, 12:53 PM   #3
drambo136
drambo136's Avatar
ok got a little farther. so i went into racerom. used the .xml from the 2.0 edit file. the go to open the stg 2 uel A00C file and it says
checksum no. 1 is invalid in table: checksum fix
the rom image may be corrupt or it has been hex edited manually.
the checksum can be corrected when the rom is saved
can anyone explain this to me
Old 10-10-2014, 01:39 PM   #4
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Ignore that RomRaider message. The OFT corrects for checksums automatically so there is no need to worry about that. We didn't write RomRaider. If we did, that message wouldn't exist
Old 10-10-2014, 01:47 PM   #5
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
Hey everyone,
Thanks
David
Always go by what your CAL ends in, so in your case A00C, it won't let you upload A01C or any other wrong one anyway. The files originally on the OFT when it reads your car for the first time are always 01C, but when you manually upload its 00C.
And like Shiv said, ignore the checksum messages that romraider gives you, they get autocorrected.
Enjoy your OFT
tdotBRZ is offline   Reply With Quote
Old 10-10-2014, 02:41 PM   #6
drambo136
drambo136's Avatar
thanks for the help guys. one more question. i dont see any option for ffs or lc
Old 10-10-2014, 03:45 PM   #7
tdotBRZ
tdotBRZ's Avatar
it's all the way at the bottom when you open the tune file with romraider. make sure you have the latest xml definitions applied.
Old 10-10-2014, 04:05 PM   #8
drambo136
drambo136's Avatar
ya i dont see it and im using the newest files
Old 10-10-2014, 04:25 PM   #9
tdotBRZ
tdotBRZ's Avatar
just checked A00C tune files (because im on B00C), and everything is still there. make sure you are using the latest updated xml definitions
Old 10-10-2014, 04:52 PM   #10
drambo136
drambo136's Avatar
Yep using ots v2.0. went to the ecu definition manager and used the supplied A00C.xml from the folder the opened the stg 2 uel 93oct image file
Old 10-10-2014, 05:03 PM   #11
drambo136
drambo136's Avatar
ok so i use the v1.59 bin and the xml from the romraider xml file....idk but w/e it works now
Old 10-10-2014, 06:04 PM   #12
drambo136
drambo136's Avatar
ok another question lol. I downloaded the new templates but i my datalogger is screwing up it gives a 4010 code and i cant see the icons on the left side
Old 10-10-2014, 06:12 PM   #13
steve99
NO never use the definition files from the romraider or github site to edit OFT tunes.
Always use the romraider definition from the OFT download page with OFT tunes files
Also always use the definition for the correct tunes you MUST match the V1.5x definitions and V1.5x bin tune files or use theV2xx definitions with the V2xx tune files.
lf you mix them up you Will brick your ecu.
Always look at some of the tables like the Base-timing-B or the Open Loop Fuel tables and make sure the table and values look ok, if they look weird or corrupted you have mismatched your bin and def files from a different tune revision.
Old 10-10-2014, 06:15 PM   #14
steve99
go to oft downloads page find the TEMPLATE FILE download it an apply it asper instructions
Newbie... exam2300 Forced Induction 16 11-14-2013 10:35 AM
Newbie amjadh Scion FR-S / Toyota 86 GT86 General Forum 30 11-12-2013 08:44 PM
Is the FR-S/BRZ for Me? (Newbie) mpdescha Scion FR-S / Toyota 86 GT86 General Forum 45 09-26-2013 01:23 PM
pls help a newbie :) abling2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-17-2013 06:21 AM
Newbie KiRiMa Scion FR-S / Toyota 86 GT86 General Forum 10 01-07-2010 05:39 AM
