Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 11-05-2014, 02:16 AM   #15
BentAnat
Drives: 2013 86 STD SPW
I will post this here, since it's some questions that are quite probably really really stupid, but it occurred to me this morning:
My 86 is pretty accurately a year old, and I would like it to be serviced regularly.
1) Does this car have a service light/indicator of sorts, or do I simply have to remember myself? (probably a retarded question, but hey)
2) I want to change oil(s). Motor Oil and (if needed - not sure about this at all, maybe someone can enlighten me - gearbox oil as well). How do I ensure that our (frankly piss-poor) Toyota dealership puts the right oil in the parts?
BentAnat is offline   Reply With Quote
Old 11-05-2014, 02:26 AM   #16
Die$eL
Die$eL's Avatar
Drives: Toyota MR2 Spyder Turbo
1) No it doesnt. You need to remember. If its a year old and has not had a service, take it in. Mileage does not matter. If you leave it too long, you will need to pay for the service.
2) Ask the dealership to give you the empty containers
Die$eL is offline   Reply With Quote
Old 11-05-2014, 02:32 AM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
Yes, check after a few minutes. If I check right after turning off the engine it will not even register the first dot on the dipstick. If I wait a couple minutes it reads correctly, for me about halfway between the 2 dots.
They probably use bulk oil so no containers.
Old 11-05-2014, 03:09 AM   #18
Freedom
Freedom's Avatar
Drives: PEARL WHITE GT86 TRD
The oil comes in 1L bottles. I have not seen bigger. So you should always get containers as well as a bottle with a little extra inside...
Freedom is offline   Reply With Quote
Old 11-05-2014, 03:21 AM   #19
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Yep, it only comes in 1 Lt bottles, see http://www.ft86club.com/forums/showp...8&postcount=17
Fish Eagle is offline   Reply With Quote
Old 11-05-2014, 03:42 AM   #20
WesleyG
Drives: 2014 Satin White Pearl GTS auto
psssssshhh check oil and water? one of the perks of having a brand new car is not to worry about these things.
I save that energy for working on the MR
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 11-05-2014, 03:48 AM   #21
ZionsWrath
Thanks
ZionsWrath's Avatar
Even the pre delivery inspection states to check fluid level.
But hey, if you trust the dealer jockeys to do everything right and your car to be perfect more power to you.
The Following User Says Thank You to ZionsWrath For This Useful Post:
qbzee007 (11-05-2014)
Old 11-06-2014, 12:04 AM   #22
BentAnat
Thanks, @Die$eL.
I thought that the empty container was the answer, but wasn't sure abotut he huge bottles and all.
Thanks again!
Old 11-06-2014, 12:46 AM   #23
WesleyG
Yeah I know, sometimes these things may get forgotten or misfilled at the factory, remember we may be enthusiasts and these things will seem important, but for the other 99% of normal people out there theres nothing to check they just get in and drive, I would obviously make sure a day before i track the car etc, but for a vehicle with 6000kms and hasnt even been for its first service, Its not something im concerned about on a day to day basis.
My fiance had a mercedes A class for 6 years, not once did it ever cross my mind to check the oil and that car was perfectly fine, hell on my daily driver where i do 4000kms a month and drive it like i stole, it, its not something im concerned about, if everything is within factory spec then you shouldnt have a problem,
Have theses cars been noted for oil consumption in mass numbers? not that I know off,
Now my MR2 with the original 1zz engine was, that I checked fluids etc regularly, and now that i fitted a 2zzge crate motor to it, I still do it because its modified, and if something had to go wrong it would actually be my problem and not a warranty claim.
Dont get me wrong I plan to keep the 86 long term, but when its older and out of warranty etc. then I will worry
I dont expect a new factory stock car to take oil or water and if it did, then theres warranty for that, if you are supercharged or did some mods then by all means I agree, check everything for peace of mind.
2014 37J 86 Auto
The Following User Says Thank You to WesleyG For This Useful Post:
Dammod (06-25-2015)
Old 11-06-2014, 01:34 AM   #24
CWP68
CWP68's Avatar
Drives: Toyota 86 Supercharged
I did that once and nearly shat myself!
CWP68 is offline   Reply With Quote
The Following User Says Thank You to CWP68 For This Useful Post:
ZionsWrath (11-06-2014)
Old 06-17-2015, 09:11 AM   #25
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
Blue Coolant Part number: 08889-01203
My coolant levels were at the min level this weekend,
I went to the dealership that I purchased my vehicle from: McCarthy Toyota Gateway (Umhlanga)
They insisted that the Toyota 86 uses the red coolant, they then said I must call Subaru and ask them for the "Blue coolant" that I requested.
Called Subaru Dbn: They said they use Red coolant in all their BRZ's
I then drove the Gateway Toyota (Who still denied there being a Toyota Blue Coolant in existence) and called Imperial Toyota Randburg (Infront of the Gateway Toyota Parts manager) who assisted me with the following part number: (Blue coolant part number)
08889-01203
Toyota Gateway parts said its the first time they heard about this coolant - Not sure if it was ignorance or stupidity.
I then drove to Durban South Toyota to buy it as they where the closest dealer in KZN to have stock.
Not sure if this is the correct coolant or not
But my car hasnt exploded as yet lol so it should be fine...
Cost R311.48 (Excluding VAT) - 4L
FT_86_SM_GP is offline   Reply With Quote
Old 06-17-2015, 10:13 AM   #26
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
08889-01203
Attachment 112697
Looks like that can has stood the test of time.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
sav (06-25-2015)
Old 06-17-2015, 10:40 AM   #27
FT_86_SM_GP
Drives: Lawn moweR
Lol the coolant was still fresh ...despite the possible expired 'use by' date in Japanese
Durban South Toyota provided an 8% discount as well (I guess coz its old stock)
Old 06-17-2015, 11:18 AM   #28
LostSalad
Drives: Toyota 86 - Charcoal Grey
That's such a specific number. I wonder how they sucked an 8% instead of just giving you a round 10%. Anyway, mine's definitely blue.
LostSalad is offline   Reply With Quote
Coolant, Anyone tried this?? stevo_12v Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-27-2016 04:50 PM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Where did my coolant go? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 1 11-02-2013 11:46 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
