Old 10-18-2014, 04:38 AM   #141
diodelphi
diodelphi's Avatar
Drives: 86
EFR
Originally Posted by BRZGM3 View Post
Thank you very much, id rather the better response. So what would be a comparable turbo to the 7670, from Precision? And Garrett.
Excuse me BRZGM3 for my answer , i think EFR is the best between all turbo makers.
EFR 7163 is 500rpm sooner than GTX30 and 200rpm sooner than GTX28.
it's build quality is better and it's top end power is near GTX3076 A/R .82
diodelphi is offline   Reply With Quote
Old 10-18-2014, 09:30 AM   #142
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
Well I wish I could run it lol but my setup is made for a typical turbo not a Borg warner. I know its a great turbo, just hoping I can find something similar
BRZGM3 is offline   Reply With Quote
Old 10-21-2014, 04:04 AM   #143
diodelphi
diodelphi's Avatar
Drives: 86
Westigate
Originally Posted by Full-Race Geoff View Post
Yes -- EFR7670 is slotted right between the two. On E85 it will max out around 580whp, with response that is second to none. If you were targetting over 600+ then 8374 would be the call (I recommend 7670 however)
Dear Sir
for 9psi boost with single scroll EFR 7163 you recommend internal or external westigate and blow off valve for your kit?
Thanks
Old 10-24-2014, 12:39 PM   #144
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
I had your kit on my Rsx type-s back in the day and loved it. Top notch for sure. I can't wait to see what you have for this platform now!
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 10-24-2014, 12:48 PM   #145
BRZGM3
BRZGM3's Avatar
Full race, have you guys tried using FP's HTA series turbo's with your kit?
Old 10-24-2014, 01:07 PM   #146
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
They probably havent, but seeing as how borg warner turbos usually are bigger in size than most other turbos is a hint that they would need to use a slightly different configuration than that of their standard BW setup, probably not just an adaption to the manifold, probably another manifold all together.
Old 10-25-2014, 10:08 AM   #147
diodelphi
diodelphi's Avatar
Drives: 86
7163 vs 6758
at 9psi, i would go internal WG/bov and really consider 6758 unless a built motor was in the near future.
http://blog.perrinperformance.com/bo...test-and-tune/
perrin shows 7163 is better than 6758 in both low and top.
Old 10-25-2014, 12:13 PM   #148
bakerr6
Drives: 2013 raven black fr-s
Look at the footnotes and you will see why the 6758 was being outperformed on the lower end. Theorywise, the 6758 has lower rotational mass and therefore should spool faster, with all other variables the same.
bakerr6 is offline   Reply With Quote
Old 10-25-2014, 12:35 PM   #149
xwd
Here is a long NASIOC thread with quite a few results and lots of EFR info if you want to wade through the many pages of it.
http://forums.nasioc.com/forums/show....php?t=2394879
I'm not sure what was up with the Perrin results but real-world the 7163 isn't going to spool faster than the 6758, especially if you are using the .64A/R housing on the 6758 which is what I would definitely use on this car. The 6258 really has more than enough power in it to get people in trouble and will spool super fast.
Old 10-25-2014, 02:03 PM   #150
bakerr6
Iirc I'm running the 6758
Old 10-25-2014, 02:04 PM   #151
diodelphi
diodelphi's Avatar
Drives: 86
jet like
brz is jet like driving experience with increasing torque at increasing rpm and speed .
i never had any practical experience with these turbos and my idea is just theorical.
hope to see result of who drieved brz with both turbos
Old 10-25-2014, 06:41 PM   #152
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Technically, thats also taking into effect the CR of the STi that was using the 7163. The higher the CR the higher hp per PSI youll get from a turbo. So stock internals i wouldnt be surprised to see the 6758 spool about 2-300 rpm faster than the 7163, but loose about 20-30whp uptop.
Old 10-26-2014, 12:54 AM   #153
diodelphi
diodelphi's Avatar
Drives: 86
I agree FA20 CR let us use bigger turbo
wrx CR is less than brz
Old 10-26-2014, 12:58 AM   #154
BRZGM3
BRZGM3's Avatar
So when we drop the CR to 10:1 with a forged motor, is the change really going to cause that much of a difference in response / spool?
>>Circuit Motorsports - Full Performance Shop - Central FL / Orlando - 86 Specials << Circuit Motorsports Southeast 204 10-05-2016 01:27 PM
Full Blown Motorsports Base Turbo Kit with e85 Upgrade TyperRspec789 Engine, Exhaust, Bolt-Ons 24 07-12-2013 04:58 PM
Full Blown Motorsports Turbo Kit INSTALLATION at Real Auto Dynamics! Kevin@RAD Forced Induction 70 04-24-2013 08:47 PM
Indy Car and Grand Am Race at Barber Motorsports Park naikaidriver Southeast 5 04-07-2013 05:05 PM
Shannonville Motorsports Park Full Track August 11, 2012 funcheung CANADA 5 08-13-2012 11:54 AM
