#141 | |
Drives: 86
EFR
EFR 7163 is 500rpm sooner than GTX30 and 200rpm sooner than GTX28. it's build quality is better and it's top end power is near GTX3076 A/R .82 |
#142 |
Drives: CBS brz limited
Well I wish I could run it lol but my setup is made for a typical turbo not a Borg warner. I know its a great turbo, just hoping I can find something similar
#143 | |
Drives: 86
Westigate
Dear Sir for 9psi boost with single scroll EFR 7163 you recommend internal or external westigate and blow off valve for your kit? Thanks |
#144 |
Drives: 2013 Raven FR-S
I had your kit on my Rsx type-s back in the day and loved it. Top notch for sure. I can't wait to see what you have for this platform now!
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
#145 |
Full race, have you guys tried using FP's HTA series turbo's with your kit?
#146 |
Junior
Drives: a car
They probably havent, but seeing as how borg warner turbos usually are bigger in size than most other turbos is a hint that they would need to use a slightly different configuration than that of their standard BW setup, probably not just an adaption to the manifold, probably another manifold all together.
#147 | |
Drives: 86
7163 vs 6758
perrin shows 7163 is better than 6758 in both low and top. |
#148 |
Drives: 2013 raven black fr-s
Look at the footnotes and you will see why the 6758 was being outperformed on the lower end. Theorywise, the 6758 has lower rotational mass and therefore should spool faster, with all other variables the same.
#149 | |
http://forums.nasioc.com/forums/show....php?t=2394879 I'm not sure what was up with the Perrin results but real-world the 7163 isn't going to spool faster than the 6758, especially if you are using the .64A/R housing on the 6758 which is what I would definitely use on this car. The 6258 really has more than enough power in it to get people in trouble and will spool super fast. |
#150 |
Iirc I'm running the 6758
#151 | |
Drives: 86
jet like
i never had any practical experience with these turbos and my idea is just theorical. hope to see result of who drieved brz with both turbos |
#152 |
Junior
Drives: a car
Technically, thats also taking into effect the CR of the STi that was using the 7163. The higher the CR the higher hp per PSI youll get from a turbo. So stock internals i wouldnt be surprised to see the 6758 spool about 2-300 rpm faster than the 7163, but loose about 20-30whp uptop.
#153 | |
Drives: 86
wrx CR is less than brz |
#154 |
So when we drop the CR to 10:1 with a forged motor, is the change really going to cause that much of a difference in response / spool?
| >>Circuit Motorsports - Full Performance Shop - Central FL / Orlando - 86 Specials << | Circuit Motorsports | Southeast | 204 | 10-05-2016 01:27 PM |
| Full Blown Motorsports Base Turbo Kit with e85 Upgrade | TyperRspec789 | Engine, Exhaust, Bolt-Ons | 24 | 07-12-2013 04:58 PM |
| Full Blown Motorsports Turbo Kit INSTALLATION at Real Auto Dynamics! | Kevin@RAD | Forced Induction | 70 | 04-24-2013 08:47 PM |
| Indy Car and Grand Am Race at Barber Motorsports Park | naikaidriver | Southeast | 5 | 04-07-2013 05:05 PM |
| Shannonville Motorsports Park Full Track August 11, 2012 | funcheung | CANADA | 5 | 08-13-2012 11:54 AM |
