Old 09-23-2014, 05:46 PM   #1
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
wheel and tire size questions
I'm looking to get Enkei Kojin 18 x 8.5 et45 front and 18 x 9.5 et45 rear
I'll be running stock suspension for the time being to stay in my autocross class (i'll be switching to stock wheels for c street)
for tires I was thinking 235/45 for the front and 255/40 for the rear
The reason I want these sizes is to get as much sidewall as possible to fill the wheel gap
So i have two questions (hopefully someone can answer):
1. Will these wheels fit without hitting the stock springs?
2. The overall diameter of the two tires will be off by 7mm (1/4''). Will this effect abs/tc?
thanks
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
Old 09-23-2014, 05:49 PM   #2
gramicci101
Off Topic
If you're getting 235's on the front, get 265's on the rear. If you're getting 255's on the rear, get 225's on the front. The OD of these pairs of tires line up much better.
Check out the meaty tire thread for fitting 255's or 265's under your car. They've got the info you need.
The Following User Says Thank You to gramicci101 For This Useful Post:
BRZ21 (09-23-2014)
Old 09-23-2014, 06:00 PM   #3
gramicci101
Off Topic
Also, don't get 235/45-18's, get 235/40-18's. They're 25.4" OD vs. 26.3" OD for the /45's. The OEM tire is only 24.6" OD. Match them with 265/35-18's.
BRZ21 (09-23-2014)
Old 09-23-2014, 06:33 PM   #4
BRZ21
i kill cones.
BRZ21's Avatar
Thank you sir.
I also asked my question in the meaty tire thread
The Following User Says Thank You to BRZ21 For This Useful Post:
gramicci101 (09-23-2014)
Old 09-26-2014, 12:15 AM   #5
brzerk1
brzerk1's Avatar
Drives: SWP BRZ LIMITED
I run a 245/35/18 front and 265/35/18 rear
Raijin same exact sizes and offset
no suspension mods and no rubbing. Hankook V12 all tires brands are little different though.
Hope this helps
brzerk1 is offline   Reply With Quote
The Following User Says Thank You to brzerk1 For This Useful Post:
NWFRS (10-23-2014)
Old 09-28-2014, 12:06 PM   #6
BRZ21
i kill cones.
BRZ21's Avatar
Attachment 91923
Attachment 91924
Hope this helps
Wow car looks great. Thanks man.
You just sealed the deal for me
Old 09-28-2014, 01:09 PM   #7
brzerk1
brzerk1's Avatar
Post pics once you get them.
BRZ21 (10-01-2014)
Old 10-22-2014, 08:45 PM   #8
BRZ21
i kill cones.
BRZ21's Avatar
Here they are. Finally.
Old vs New
They fit as perfect as I could hope for
brzerk1 (10-22-2014)
Old 10-22-2014, 08:50 PM   #9
BRZ21
i kill cones.
BRZ21's Avatar
Next time I'll get a little more tire... I should've went with 235/40 265/35 but overall I'm pleased
Old 10-22-2014, 09:24 PM   #10
sirsol66
Drives: 2013 FRS- Hot Lava
Old vs New
What tire size did you end up with? Stock suspension still? No rub at all?
sirsol66 is offline   Reply With Quote
Old 10-22-2014, 09:54 PM   #11
BRZ21
i kill cones.
BRZ21's Avatar
225/40f 255/35r
Stock suspension.
No rubbing (at least not yet). I have just less than a finger width between the front spring and tire.
Next time I'll get 235/40 265/35
Old 11-02-2014, 03:46 AM   #12
flat486
flat486's Avatar
Drives: 2015 brz limited 6speed manual DGM
How would these fit with rsr super downs?
flat486 is offline   Reply With Quote
Wheel size questions WallsAndFoundations Scion FR-S / Toyota 86 GT86 General Forum 1 06-30-2014 01:13 AM
Help with wheel\tire size for a DD on Pro Kit B-R-Z Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-08-2014 01:06 PM
Wheel + tire: size vs weight vs confusion horrorbiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-14-2013 12:48 PM
Help me decide on tire/wheel size... wparsons Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 01-17-2013 03:45 PM
Best wheel and tire size without upsetting balance ngabdala Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-11-2012 12:27 PM
